VideoOS.Platform.EnvironmentManager Class Referenceabstract
The EnvironmentManager is the top class for the MIP Environment. The class can always be accessed though: EnvironmentManager.Instance As it is a singleton. More...
Public Types
enum  MessageReceiverHint { None , AvoidAsync }
 Gives a hint about how to call the message receiver method. More...
Public Member Functions
void ExceptionDialog (String nameOfClass, String where, Exception exception)
 Opens an ExceptionDialog to the user with a formatted layout of the exception itself.
void ExceptionDialog (String where, Exception exception)
void ExceptionHandler (String nameOfClass, String where, Exception exception)
 Common exception handler. Logs the incident into the Log and opens the ExceptionDialog to the user.
void ExceptionHandler (String where, Exception exception)
void FireEnvironmentOptionsChangedEvent ()
 Applications changing the EnvironmentOptions dictionary, should call this method.
virtual Item GetSiteItem (FQID fqid)
 Get the Item representing a specific site / island. The fqid is the id of a XProtect Management server.
virtual Item GetSiteItem (Guid id)
 Get the Item representing a specific site / island. The id is the id of a XProtect Management server.
virtual bool HasCapability (String capability)
 Can be used to check if the product supports a given capability Check EnvironmentCapabilities for available capabilities.
virtual void Log (bool error, String where, [Localizable(false)] String text)
 Logs a message.
virtual void Log (bool error, String where, [Localizable(false)] String text, object[] args)
 Logs a message.
virtual void Log (String nameOfClass, bool error, String where, [Localizable(false)] String text, object[] args)
 Logs a message in a Debug log.
virtual void PostMessage (Message message)
 Overloaded method if both destination and sender == null.
virtual void PostMessage (Message message, FQID destination)
 Overloaded message if sender == null.
void PostMessage (Message message, FQID destination, FQID sender)
 Post a Message. Similar method as SendMessage except that there is not result value.
object RegisterReceiver (MessageReceiver messageReceiver, MessageFilter messageFilter)
 Register a method to receive messages.
virtual object RegisterReceiver (MessageReceiver messageReceiver, MessageFilter messageFilter, MessageReceiverHint hint)
 Register a method to receive messages with a hint about how to launch the message.
virtual Collection< object > SendMessage (Message message)
 Overloaded method to be used if both destination and sender == null.
virtual Collection< object > SendMessage (Message message, FQID destination)
 Overloaded method to be used if sender==null.
Collection< object > SendMessage (Message message, FQID destination, FQID sender)
 Send a Message. All receivers will be called before the call returns. Message id's and formatted Data field are found in namespace VideoOS.Platform.Messaging for the Milestone defined messages.
void UnRegisterReceiver (object registeredReceiver)
 UnRegister a MessageReceiver.
Protected Member Functions
virtual void Init ()
 Initializes the environment.
virtual void Init (IDictionary< string, Color > brandColors)
Properties
virtual List< PluginDefinition > AllPluginDefinitions [get]
 Returns a list of all loaded MIP Plug-ins.
bool ApplicationLoggedOn [get]
 Indicate if the application is currently logged on.
virtual FQID CurrentSite [get]
 Get the Item that represent the server currently selected (May only be relevant for XProtect management client)
bool DebugLoggingEnabled = false [get, set]
 Tells whether debug logs (log commands with error == false) should be written to the log file. Default is false.
bool DebugTelemetryLoggingEnabled = false [get, set]
 Tells whether telemetry debug logs should be written to the log file. Default is false.
virtual bool EnableConfigurationChangedService [get, set]
 Set this if you want to receive the Messaging.MessageId.Server.ConfigurationChangedIndication messages. When this is true, a service will poll the plug-in configuration server every 60 second for changes and send the message if anything changed in plug-in configurations.
The message being sent is Messaging.MessageId.Server.ConfigurationChangedIndication, where the Message.RelatedFQID contains the top node of what was changed. Often you can just check if the Message.RelatedFQID.Kind matches one of your kinds.
virtual Dictionary< string, string > EnvironmentOptions [get]
 Used to control specific environment behavior. For dynamic options, call the FireEnvironmentOptionsChangedEvent method to let the system know it was changed.
virtual String EnvironmentProduct [get]
 Identifies the current product executing.
virtual EnvironmentType EnvironmentType [get]
 Identifies the current executing Environment.
static EnvironmentManager Instance [get, set]
 This Singleton item of this class. Only the 'get' access should be used.
virtual License.LicenseManager LicenseManager [get]
 Helps the plug-in with checking current use of licenses.
virtual String LoginAuthType [get, set]
 Defines the type of authentication stored in the LoginNetworkCredential property.
This property can be used to construct a credentialCache.
Values are defined in VideoOS.Platform.Login.AuthenticationType:
"Negotiate" for Active Directory, Windows and local system defined users
"Basic" for basic users
"External" for user defined on an external IDP, e.g. 3rd party OAuth service
virtual ICredentials LoginCredentialCache [get, set]
 The Credential cache for all types of authorizations.
Notice: Only valid in Smart Client from version 7.0b.
virtual NetworkCredential LoginNetworkCredential [get, set]
 The credential used when connecting with Windows, WindowsDefault or basic user authorization.
virtual FQID MasterSite [get]
 Get the Item that represent the server that was logged in to.
bool MeasureSendPostHandlers [get, set]
 Creates an ElapseTimer class and measures how much time each message handler is using. (Implemented for Event Server only in 2019 R3)
The MIP SDK Tray Manager can display the results.
List< String > MessageIdList [get]
 List of all known MessageIds. This includes all the message id's defined by the PlatformPlugin and environment as well as for all loaded plug-ins.
virtual Mode Mode [get, set]
 The Mode the environment is executing right now.
bool PluginInitializationInProgress [get, set]
 Identifies if the plugin load process in progress.
virtual bool SmartClientInOfflineMode [get, set]
 Determines if the Smart Client is executing after an export, and therefor is running in Offline mode. In Offline mode, it will not be possible to contact any servers for additional information. Make sure to export all relevant material during the Export process.
virtual string SmartClientOfflineDirectory [get, set]
 When Smart Client is running in offline mode, this property defines the root directory for the exported data.
virtual SystemLicense SystemLicense [get]
 SystemLicense contains general information about the license for the XProtect system.
bool TraceFunctionCalls [get, set]
 Set this bool if you like to have a line of trace written for all calls to all plug-ins. The trace lines are written to the respective debug logs for the environment.
bool TraceMessageCommunication [get, set]
 Set this bool if you like to have a lot of trace lines about how message communication works. The trace lines are written to the respective debug logs for the environment.
bool TracePlaybackDetails [get, set]
 Make deeper log entries for playback (MIPSDK 2016 - just for stand alone MIP Environment)
bool TraceSendDetails [get, set]
 Make deeper log entries for send message / post message (MIPSDK 2016 - just for stand alone MIP Environment)
static bool UsingUserContext [get, set]
 This field identifies if the current stand alone environment is using multi-user context.
Events
EventHandler EnvironmentOptionsChangedEvent
 This event is used for components that need to change behavior when an option has been modified.
Detailed Description
The class has identification information of the current environment executing. When executing in XProtect Management Client, the Event Server and the Smart Client, the EnvironmentManager is created by the main application, while when executing in a stand-alone application, the SDK version of the EnvironmentManager needs to be instantiated by the standalone application.
Please check out the SDK instantiation notes for a complete description of SDK startup.
Member Enumeration Documentation
◆ MessageReceiverHint
Enumerator
None
No hint at all, this is the default value.
AvoidAsync
Indicates that the message receiver method shoud not be called in a new thread.
Member Function Documentation
◆ ExceptionDialog() [1/2]
void VideoOS.Platform.EnvironmentManager.ExceptionDialog ( String nameOfClass,
String where,
Exception exception )
abstract
Parameters
nameOfClassThe class being worked on, when the exception happened
whereWhere the Exception happened
exceptionThe Exception itself
◆ ExceptionDialog() [2/2]
void VideoOS.Platform.EnvironmentManager.ExceptionDialog ( String where,
abstract
Parameters
◆ ExceptionHandler() [1/2]
void VideoOS.Platform.EnvironmentManager.ExceptionHandler ( String nameOfClass,
String where,
abstract
Parameters
nameOfClassThe class being worked on, when the exception happened.
◆ ExceptionHandler() [2/2]
void VideoOS.Platform.EnvironmentManager.ExceptionHandler ( String where,
abstract
Parameters
◆ FireEnvironmentOptionsChangedEvent()
void VideoOS.Platform.EnvironmentManager.FireEnvironmentOptionsChangedEvent ( )
inline
◆ GetSiteItem() [1/2]
virtual Item VideoOS.Platform.EnvironmentManager.GetSiteItem ( FQID fqid)
inlinevirtual
Parameters
fqid
Returns
◆ GetSiteItem() [2/2]
virtual Item VideoOS.Platform.EnvironmentManager.GetSiteItem ( Guid id)
inlinevirtual
Parameters
id
Returns
◆ HasCapability()
virtual bool VideoOS.Platform.EnvironmentManager.HasCapability ( String capability)
inlinevirtual
Supported from 2016
◆ Init() [1/2]
virtual void VideoOS.Platform.EnvironmentManager.Init ( )
inlineprotectedvirtual
◆ Init() [2/2]
virtual void VideoOS.Platform.EnvironmentManager.Init ( IDictionary< string, Color > brandColors)
◆ Log() [1/3]
virtual void VideoOS.Platform.EnvironmentManager.Log ( bool error,
String where,
[Localizable(false)] String text )
inlinevirtual
Logs a message.
Parameters
errorTrue if this is an error
whereWhere the this is coming from, provide class name and method
textThe message
◆ Log() [2/3]
String where,
object[] args )
inlinevirtual
Logs a message.
Parameters
textThe message
argsAny relevant parameters
◆ Log() [3/3]
virtual void VideoOS.Platform.EnvironmentManager.Log ( String nameOfClass,
bool error,
String where,
object[] args )
inlinevirtual
Parameters
nameOfClassThe class being worked on.
textThe message
◆ PostMessage() [1/3]
virtual void VideoOS.Platform.EnvironmentManager.PostMessage ( Message message)
inlinevirtual
Parameters
message
◆ PostMessage() [2/3]
virtual void VideoOS.Platform.EnvironmentManager.PostMessage ( Message message,
FQID destination )
inlinevirtual
Parameters
message
destination
◆ PostMessage() [3/3]
FQID destination,
FQID sender )
abstract
Parameters
messageThe message to send
destinationThe destination FQID, if relevant
senderThe sender, if known
◆ RegisterReceiver() [1/2]
object VideoOS.Platform.EnvironmentManager.RegisterReceiver ( MessageReceiver messageReceiver,
MessageFilter messageFilter )
abstract
Parameters
messageReceiverThe method to be called
messageFilterThe filter to be used
Returns
The object to be used for UnRegister method
◆ RegisterReceiver() [2/2]
virtual object VideoOS.Platform.EnvironmentManager.RegisterReceiver ( MessageReceiver messageReceiver,
MessageReceiverHint hint )
virtual
Parameters
hintHint to be used when calling the messageReceiver
Returns
◆ SendMessage() [1/3]
virtual Collection< object > VideoOS.Platform.EnvironmentManager.SendMessage ( Message message)
inlinevirtual
Parameters
message
Returns
◆ SendMessage() [2/3]
virtual Collection< object > VideoOS.Platform.EnvironmentManager.SendMessage ( Message message,
FQID destination )
inlinevirtual
Parameters
message
destination
Returns
◆ SendMessage() [3/3]
FQID destination,
FQID sender )
abstract
Parameters
Returns
A Collection of the result each receiver returns. null result are filtered off.
◆ UnRegisterReceiver()
void VideoOS.Platform.EnvironmentManager.UnRegisterReceiver ( object registeredReceiver)
abstract
Parameters
registeredReceiverThe object returned from the RegisterReceiver call
Returns
Property Documentation
◆ AllPluginDefinitions
virtual List<PluginDefinition> VideoOS.Platform.EnvironmentManager.AllPluginDefinitions
get
◆ ApplicationLoggedOn
bool VideoOS.Platform.EnvironmentManager.ApplicationLoggedOn
getabstract
◆ CurrentSite
virtual FQID VideoOS.Platform.EnvironmentManager.CurrentSite
get
◆ DebugLoggingEnabled
bool VideoOS.Platform.EnvironmentManager.DebugLoggingEnabled = false
getset
Only affects standalone SDK.
◆ DebugTelemetryLoggingEnabled
bool VideoOS.Platform.EnvironmentManager.DebugTelemetryLoggingEnabled = false
getset
◆ EnableConfigurationChangedService
virtual bool VideoOS.Platform.EnvironmentManager.EnableConfigurationChangedService
getset
◆ EnvironmentOptions
virtual Dictionary<string, string> VideoOS.Platform.EnvironmentManager.EnvironmentOptions
get
◆ EnvironmentProduct
virtual String VideoOS.Platform.EnvironmentManager.EnvironmentProduct
get
◆ EnvironmentType
virtual EnvironmentType VideoOS.Platform.EnvironmentManager.EnvironmentType
get
◆ Instance
EnvironmentManager VideoOS.Platform.EnvironmentManager.Instance
staticgetset
◆ LicenseManager
virtual License.LicenseManager VideoOS.Platform.EnvironmentManager.LicenseManager
get
◆ LoginAuthType
virtual String VideoOS.Platform.EnvironmentManager.LoginAuthType
getset
◆ LoginCredentialCache
virtual ICredentials VideoOS.Platform.EnvironmentManager.LoginCredentialCache
getset
◆ LoginNetworkCredential
virtual NetworkCredential VideoOS.Platform.EnvironmentManager.LoginNetworkCredential
getset
NOTE: From 2022 R1, this property may be null when the user is using OAuth 2.0 tokens. Try always to use the LoginSettings class instead and check the IsOAuthIdentity == false, before using the NetworkCredential there.
◆ MasterSite
virtual FQID VideoOS.Platform.EnvironmentManager.MasterSite
get
◆ MeasureSendPostHandlers
bool VideoOS.Platform.EnvironmentManager.MeasureSendPostHandlers
getset
◆ MessageIdList
List<String> VideoOS.Platform.EnvironmentManager.MessageIdList
getabstract
A plug-in should add any plug-in defined messages to the plug-ins own PluginDefinition
◆ Mode
virtual Mode VideoOS.Platform.EnvironmentManager.Mode
getset
◆ PluginInitializationInProgress
bool VideoOS.Platform.EnvironmentManager.PluginInitializationInProgress
getset
◆ SmartClientInOfflineMode
virtual bool VideoOS.Platform.EnvironmentManager.SmartClientInOfflineMode
getset
◆ SmartClientOfflineDirectory
virtual string VideoOS.Platform.EnvironmentManager.SmartClientOfflineDirectory
getset
◆ SystemLicense
virtual SystemLicense VideoOS.Platform.EnvironmentManager.SystemLicense
get
◆ TraceFunctionCalls
bool VideoOS.Platform.EnvironmentManager.TraceFunctionCalls
getsetabstract
◆ TraceMessageCommunication
bool VideoOS.Platform.EnvironmentManager.TraceMessageCommunication
getset
◆ TracePlaybackDetails
bool VideoOS.Platform.EnvironmentManager.TracePlaybackDetails
getset
◆ TraceSendDetails
bool VideoOS.Platform.EnvironmentManager.TraceSendDetails
getset
◆ UsingUserContext
bool VideoOS.Platform.EnvironmentManager.UsingUserContext
staticgetset
Event Documentation
◆ EnvironmentOptionsChangedEvent
EventHandler VideoOS.Platform.EnvironmentManager.EnvironmentOptionsChangedEvent
Applications changing the EnvironmentOptions dictionary, should call the FireEnvironmentOptionsChangedEvent method.
