class | Group |
| Contains constants defining the different type of logs. More...
class | LogClient |
| This class is used for storing log messages in the server side logs. Currently only supported in standalone and Management Client environment. More...
class | LogMessage |
| Contains one log message. More...
class | LogMessageDictionary |
| Represent a set of log messages that a MIP plugin would like to define in the log system. Used when using the LogClient to register messages for later use. More...
class | PermissionState |
| Used when performing audit logging - specify result of an permission check. More...
class | Severity |
| Contains constants definining the severity levels available. More...
class | Status |
| Contains constants defining if a message also should be considered to change a state. More...
