A Message contains information send from a sender to one or multiple receivers. It is identified by a String, the well known messages created and send by the MIP Environment are defined in class VideoOS.Platform.Messaging.MessageId.
The fields may be filled out or not filled out depending on the MessageId. The MessageId is the identification of the message, a plugin can use any MessageId they choose of additional communication.
The field Reason - is a string containing why this message has been send, could be the name of a rule, a black list, or simply a user action. The RelatedFQID is used for some Messages – see documentation for each MessageId. The Data field is simply an object relevant to the specific MessageId.
More...
| | Message (String messageId) |
| | The Message contains a singe string as the ID.
| | Message (String messageId, FQID relatedFQID) |
| | The Message contains a single string as the ID. The message relates to the relatedFQID.
| | Message (String messageId, FQID relatedFQID, object data) |
| | Message (String messageId, FQID relatedFQID, object data, String reason) |
| | Message (String messageId, object data) |
| | The Message contains a singe string as the ID and a Data object. T.
| object | Data [get, set] |
| | The data can be any object as defined by the MessageId. Built-in messages uses a name format for the Data field like the messageId appended with 'Data'.
| FQID | ExternalMessageSourceEndPoint [get, set] |
| | If this message originated from another application, this FQID will identify the Source EndPoint's FQID.
This can be used for the destinationEndPoint if you need to replay back in the MessageCommunication.Transmit method.
| String | MessageId [get] |
| | The identification of the message begin sent. Built-in message id's are located in class Messaging.MessageId Plugin defined messages are suggested to be of a namespace format with the plugin type as the initial name. e.g. "MyPlugin.Info.PayAttention".
| String | Reason [get, set] |
| | The Reason is an informative field that can be used to display or trace additional reason for the Sending of this message.
| FQID | RelatedFQID [get, set] |
| | The RelatedFQID identifies an Item that subject to an action/event, e.g. as a parameter. The destination FQID on the SendMessage is usually the one receiving the message and RelatedFQID.
◆ Message() [1/5]
| VideoOS.Platform.Messaging.Message.Message |
String | messageId | ) |
inline |
- Parameters
◆ Message() [2/5]
String | messageId, |
FQID | relatedFQID ) |
inline |
- Parameters
| messageId | The Id of the message |
| relatedFQID | FQID of a related Item to the Destination FQID |
◆ Message() [3/5]
object | data ) |
inline |
- Parameters
| data | Can contain data to be send with the message, or data where fields can be filled by receiver |
◆ Message() [4/5]
FQID | relatedFQID, |
object | data ) |
inline |
- Parameters
◆ Message() [5/5]
object | data, |
String | reason ) |
inline |
- Parameters
| reason | Explain why this message is being sent |
◆ Data
| object VideoOS.Platform.Messaging.Message.Data |
getset |
◆ ExternalMessageSourceEndPoint
| FQID VideoOS.Platform.Messaging.Message.ExternalMessageSourceEndPoint |
getset |
◆ MessageId
| String VideoOS.Platform.Messaging.Message.MessageId |
get |
◆ Reason
| String VideoOS.Platform.Messaging.Message.Reason |
getset |
◆ RelatedFQID
| FQID VideoOS.Platform.Messaging.Message.RelatedFQID |
getset |
