Classes | |
| class | AddToExportCommandData |
| This class is used with the MessageId.SmartClient.AddToExportCommand message. More... | |
| class | AnalyticsMessageData |
| Contains a definition of one analytics event. More... | |
| class | AnyFilter |
| This MessageFilter will match any messages. More... | |
| class | ApplicationControlCommandData |
| A set of const strings to defined available values for the ApplicationControlCommand message. More... | |
| class | ChangedAlarmData |
| This class is contained on the Server.ChangedAlarmIndication. The content identifies what changes has been made. When changes only involved a single alarm, the ChangeHint is ChangeHintSingleAlarm and the AlarmId can be used to get the alarm again. When changes involves a number of alarms on a specific source, the ChangeHint is ChangeHistMassUpdateForSource, and the SourceId can be used to run though alarms for that source and check the changes. More... | |
| class | ChangedAlarmHistoriesData |
| This class is contained on the Server.ChangedAlarmHistoryIndication. The content identifies the changes made to alarm history. E.g. changing state or changing assignee on an alarm. More... | |
| class | ChangedAlarmHistoryData |
| This class contains a single AlarmUpdateActivity, and is part of ChangedAlarmUpdateActivitiesData. See class AlarmUpdateKey for possible AlarmUpdateKeys. More... | |
| class | ClearIndicatorCommandData |
| This class contains the commands to control clearing the red, yellow indicators on top of the Camera images. More... | |
| class | CommunicationIdFilter |
| The CommunicationIdFilter is used to identify what messages to subscribe to, on another machine. It is used in the Messaging.MessageCommunication class. More... | |
| class | ConnectionStateChangedEventArgs |
| Identifies the server wre the connection state has changed. More... | |
| class | ConnectionStateEventArgs |
| Is send on the ConnectionStateChangedEvent. More... | |
| class | DriverCommandData |
| Use with MessageId = DriverCommand. More... | |
| class | DriverResponseData |
| The response coming back from sending a message with MessageId = DriverCommand. More... | |
| class | EndPointIdentityData |
| Contains the FQID and the username used for login at that EndPoint identified by the EndPointFQID. This class is used in conjunction with the WhoAreOnlineResponse and NewEndPointIndication messages. More... | |
| class | ExternalMessage |
| A ExternalMessage contains information send from a sender to one or multiple receivers. It is identified by a String, the well known messages created and send by the MIP Environment are defined in class VideoOS.Platform.Messaging.MessageId. The fields may be filled out or not filled out depending on the MessageId. The MessageId is the identification of the message, a plugin can use any MessageId they choose for additional communication. The field Reason - is a string containing why this message has been send, could be the name of a rule, a black list, or simply a user action. The RelatedFQID is used for some Messages – see documentation for each MessageId. The Data field is simply an object relevant to the specific MessageId. More... | |
| interface | IMessageClient |
| Messages (through WebSockets) is a BETA API. Future releases might break backwards compatibility of the API and the clients. More... | |
| interface | IMessageReceiverArgs |
| Interface holding received message parameters like topic and data. More... | |
| class | IsDirectInputHIDHandledByPlugInRequestData |
| This class is used to identify a DirectInput device found by the DirectInput HID plugin. The class represents the Data object of the MessageId.SmartClient.IsDirectInputHIDHandledByPlugInRequest message. More... | |
| class | ItemState |
| Defines the current state a given Item has. This class is used in conjunction with the ProvideCurrentStateResponse message. More... | |
| class | KindFilter |
| The KindFilter can filter on Messages. This class will match the message.RelatedFQID to the Guid parameter on the constructor and return true if there is a match. More... | |
| class | LensCommandData |
| A set of const strings to defined available values for the LensCommand message. More... | |
| class | MapRequestData |
| Class filled when sending a GetMapRequest. More... | |
| class | MapResponseData |
| Is part of the Message.Data field for a GetMapResponse message. More... | |
| class | MapResponseDataInstance |
| Short identification of a map. More... | |
| class | Message |
| A Message contains information send from a sender to one or multiple receivers. It is identified by a String, the well known messages created and send by the MIP Environment are defined in class VideoOS.Platform.Messaging.MessageId. The fields may be filled out or not filled out depending on the MessageId. The MessageId is the identification of the message, a plugin can use any MessageId they choose of additional communication. The field Reason - is a string containing why this message has been send, could be the name of a rule, a black list, or simply a user action. The RelatedFQID is used for some Messages – see documentation for each MessageId. The Data field is simply an object relevant to the specific MessageId. More... | |
| class | MessageClientManager |
| class | MessageCommunication |
| Communication between EventServer and all other MIP Environments can be done via this class. Each starting application or service will have one EndPoint ( Unique for each execution ), and a EndPointType. The EventServer is defined as a EndPointType.Server and all other MIP Environments are in this context a EndPointType.Client. Any MIP plug-in can get a list of all currently executing MIP Environments and store their EndPointFQID for communication purpose. For each EndPoint is is possible to get hold of the EndPointIdentityData class to identify the login user name for a given EndPoint. See the WhoAreOnlineRequest and WhoAreOnlineResponse MessageId's for more on this. This class is created through the MessageCommunicationManager static class. More... | |
| class | MessageCommunicationManager |
| The MessageCommunicationManager holds MessageCommunication classes for each EventServer it has connection to. The EventServers are identified by the ServerId.Id of their owning Management Server. More... | |
| class | MessageFilter |
| This class is the base class for classes that can assist in filtering messages. The MessageIdFilter matches on the MessageId itself. The AnyFilter is an always-true filter – most useful for debugging. A plugin can create own filters as appropriate for matching and filtering on specific combination the available fields. More... | |
| class | MessageId |
| The MessageId class contains the definitions of all the system defined messages. More... | |
| class | MessageIdAndRelatedKindFilter |
| The MessageIdFilter will match on the provided MessageId and kind. Only messages send with a specific messageId and where the message.RelatedFQID matches the given kind will be passed through the filter. The matching string for the messageId may contain a '' as the last character to allow for multiple matches, e.g. 'Control.PTZ' will match almost all PTZ operations going on. This filter is especially useful for the MessageId.Server.ConfigurationChangedIndication message. More... | |
| class | MessageIdFilter |
| The MessageIdFilter will match on the MessageId itself. Only messages send with a specific messageId will be passed through the filter. The matching string may contain a '' as the last character to allow for multiple matches, e.g. 'Control.PTZ' will match almost all PTZ operations going on. More... | |
| class | MessageIdListFilter |
| This class will match the messageId of a message with a list of messageId's, if a match exists for one of these, the message is passed through the filter. The '*' character cannot be used for this class. More... | |
| class | MoveCommand |
| The commands available for the SetSelectedViewItemData message. More... | |
| class | MultiWindowCommand |
| A set of const strings to defined available values for the MultiWindowCommandData structure Please note this class has same name as a command, but should be used in the MultiWindowCommandData.MultiWindowCommand field. More... | |
| struct | MultiWindowCommandData |
| The data structure filled when sending the MultiWindowCommand message. More... | |
| class | MyKeyValue |
| KeyValue to be used for serialization. More... | |
| class | MyRectangle |
| Defines a version of rectangle that can be serialized. More... | |
| class | PlaybackCommandData |
| A class specifying how to start PlayBack. Used by the PlaybackCommand for instructing the Smart Client, and by the PlaybackIndication when the Smart Client informs of user or other program commands. More... | |
| class | PlaybackControllerFilter |
| This class can be used to filter messages coming from playbackcontrollers. By using this filter, only messages from the defined playbackcontroller will be received. More... | |
| class | PlaybackControllerReceiverFilter |
| Used internally to match for receiver == playbackController. More... | |
| class | PlaybackData |
| Contains the possible values to be filled in the PlaybackCommandData.Command field. This class is send as Data in messages with MessagesIds SmartClient.PlaybackCommand and SmartClient.PlaybackIndication. More... | |
| class | PlaybackPlayModeData |
| class of strings specifying the playback modes More... | |
| class | PlaybackTimeInformationData |
| A class holding information about the currently received data to display. This class is sent to the PlaybackController to keep it updated with available data and possible skipping of gaps. More... | |
| struct | PTZAUXCommandData |
| A struct specifying the AUX specifics for the PTZAUXCommand message, used in the message's Data field. More... | |
| struct | PTZCenterCommandData |
| Defines a rectangle in witch to center and zoom. More... | |
| struct | PTZGetAbsoluteRequestData |
| A struct defining the PTZ values returned by the PTZGetAbsoluteRequest message. The values for Pan an Tilt are between -1..1 The value for Zoom are in interval 0..1, where 0=full zoom out; 1=full zoom in;. More... | |
| struct | PTZMoveAbsoluteCommandData |
| A struct specifying the PTZ and speed of a PTZMoveAbsoluteCommand message, used in the message's Data field. More... | |
| class | PTZMoveCommandData |
| A struct specifying the PTZ Move command of a PTZMoveCommand message, used in the message's Data field. More... | |
| struct | PTZMoveStartCommandData |
| A struct specifying the PTZ and speed of a PTZMoveStartCommand message, used in the message's Data field. More... | |
| struct | PTZMoveStartCommandData2 |
| struct | PTZRectangleCommandData |
| Defines a rectangle to be displayed. All values are in pixels. More... | |
| class | RecorderErrorIndicationData |
| Describes in detail the error. More... | |
| class | RestrictedMediaCreateRestrictionCommandData |
| This class is used with the MessageId.SmartClient.RestrictedMediaCreateRestrictionCommand message. | |
| class | SetCameraInViewCommandData |
| This structure is used when sending the SetCameraInViewCommand to tell the Smart Client what camera to insert in what position on current displayed view. More... | |
| class | SetSelectedViewItemData |
| This class is used by the SetSelectedViewItemCommand message id. It describes what view item should be selected within the currently selected window. More... | |
| class | ShowCamerasInFloatingWindowData |
| Defines the state of a floating window and the cameras it contains. Fill this class when sending a message with id SmartClient.ShowCamerasInFloatingWindowCommand. More... | |
| class | SmartClientMessageData |
| Contains a single message to be displayed in the message area of the Smart Client. This class is used to display new messages in the message area of the Smart Client, as well as changing or removing existing messages. Fill this class when sending a message with id SmartClient.SmartClientMessageCommand. More... | |
| class | SmartClientTextToastData |
| Specialization of SmartClientToastData that represents a text toast message. A text toast message contains an icon, primary text, secondary text and a count text. All are optional but it is recommended that at least a primary text is always provided. More... | |
| class | SmartClientToastData |
| Abstract base class for the available toast message types. Use the specialized implementations to fill in information about the toast message to display. More... | |
| class | SmartMapGetPositionRequestData |
| This class is used with the MessageId.SmartClient.SmartMapGetPositionRequest message. More... | |
| class | SmartMapGoToAreaCommandData |
| This class is used with the MessageId.SmartClient.SmartMapGoToAreaCommand message. More... | |
| class | SmartMapGoToLocationCommandData |
| This class is used with the MessageId.SmartClient.SmartMapGoToLocationCommand message. More... | |
| class | SmartMapGoToPositionCommandData |
| This class is used with the MessageId.SmartClient.SmartMapGoToPositionCommand message. More... | |
| class | SmartMapNavigateToCameraData |
| This class is used with the MessageId.SmartClient.SmartMapNavigateToCamera message. More... | |
| class | SmartMapNavigateToDeviceData |
| This class is used with the MessageId.SmartClient.SmartMapNavigateToDevice message. More... | |
| class | SmartMapPositionData |
| This class is used with the MessageId.SmartClient.SmartMapPositionChangedIndication or MessageId.SmartClient.SmartMapGetPositionRequest message. More... | |
| class | SmartMapSelectItemCommandData |
| This class is used with the MessageId.SmartClient.SmartMapSelectItemCommand message. More... | |
| class | SystemConfigurationChangedDetails |
| Class defines one change, used by SystemConfigurationChangedDetailsIndicationData More... | |
| class | SystemConfigurationChangedDetailsIndicationData |
| This class is coming with the MessageId.System.SystemConfigurationChangedDetailsIndication message. More... | |
| class | TalkToSpeakerData |
| The class send as data when sending a command to start or stop the 'talk' button. The command TalkToSpeakerCommand with this Data is implemented in the Smart Client. More... | |
| class | VideoWallApplyXmlCommandData |
| Contains information for what to change on a video wall. The listed devices (cameras) are removed from the monitor. More... | |
| class | VideoWallIndicationData |
| Contains description of a change on a video wall. More... | |
| class | VideoWallRemoveCamerasCommandData |
| Contains information for what to change on a video wall. More... | |
| class | VideoWallSetCamerasCommandData |
| class | VideoWallSetLayoutAndCamerasCommandData |
| class | VideoWallSetLayoutCommandData |
| class | VideoWallShowTextCommandData |
| Contains information for what to change on the Video Wall. More... | |
| class | ViewItemControlCommandData |
| A set of const strings to defined available values for the ViewItemControlCommand message. More... | |
| class | ViewItemInformation |
| Contains description of one ViewItem. The class is used by the VideoWallIndicationData class to inform about VideoWall View changes. More... | |
| class | WindowFilter |
| This class can be used to filter messages, so only relevant messages from a window is received. More... | |
| class | WindowStateChangedIndicationData |
| A set of const strings to define available values for the WindowStateChangedIndication message. More... | |
Enumerations | |
| enum | ChangeType { Added , Updated , Deleted } |
| Indicate what type of change has been performed. More... | |
| enum | ClientState { Connecting , ReconnectingWithSession , ReconnectingWithoutSession , Closing , Connected , Closed } |
| enum | EndPointType { Server = 1 , Client = 2 , Any = 99 } |
| Defines the possible EndPointType's available. More... | |
| enum | PlaybackSkipModeData { Noskip , Skip , StopAtSequenceEnd } |
| The PlaybackSkipMode instruct the PlaybackController what to do when reaching a gap in the video. More... | |
| enum | PtzErrorDetail { None = 0 , DeviceNotFound = 1 , DeviceNotReady = 2 , PtzNotSupported = 10 , PresetNotSupported = 11 , PtzRequestPriorityTooLow = 20 , PtzRequestQueueTooLong = 21 , PtzSessionNoneActive = 30 , PtzSessionNotActive = 31 , PtzSessionAlreadyStarted = 32 , PtzSessionNotRunning = 33 , PatrollingNoSession = 40 , PatrollingResumedWhileNotPaused = 41 , PatrollingSessionAttemptedReleased = 42 , PatrollingSessionHasHigherPriority = 43 , PatrollingSchemaNotFound = 50 , InsufficientPermission = 60 , AlreadyReserved = 70 , PtzSessionIsReserved = 80 , OtherUserManualSessionAttemptedReleased = 90 } |
| enum | RecorderWebInterfaceErrorCode { None = 0 , GeneralError = 10000 , SoapVersionMismatchError = 10001 , InvalidSoapError = 10002 , UnknownSoapVersionError = 10003 , TokenError = 20001 , MediaNotReady = 30001 , MethodHandlingError = 40000 , PtzError = 40295 } |
| Error codes for SOAP and web connection interfaces. More... | |
| enum | SmartClientMessageDataPriority { High , Normal , Low } |
| The priority of the message. Used by SmartClientMessageData. The content is currently not used by the Smart Client. More... | |
| enum | SmartClientMessageDataTaskState { Pending , Running , Complete , Canceled , Failed } |
| The state of a job. Used by SmartClientMessageData. The content is used control the visual appearance of the task progress in the Smart Client. More... | |
| enum | SmartClientMessageDataType { None , Warning , Error , Task , Confirmation } |
| The type of the message. Used by SmartClientMessageData. The content is used to show an icon beside the message. More... | |
Functions | |
| delegate void | ConnectionStateChangedEventHandler (object sender, ConnectionStateChangedEventArgs connectionStateChangedEventArgs) |
| The handler called by the ConnectionStateChangedEvent. | |
| delegate Task | MessageReceiverAsync (IMessageReceiverArgs message) |
| Messages (through WebSockets) is a BETA API. Future releases might break backwards compatibility of the API and the clients. | |
Messaging namespace contains the classes for working with messages: Message MessageId and MessageFilter related classes and const definitions.
Represents the state of the IMessageClient. Publishing and subscribing is only possible in the ClientState.Connected state.
| Enumerator | |
| High | |
| Normal | |
| Low | |
| Enumerator | |
| Pending | |
| Running | |
| Complete | |
| Canceled | |
| Failed | |
| Enumerator | |
| None | |
| Warning | |
| Error | |
| Task | |
| Confirmation | |
| delegate void VideoOS.Platform.Messaging.ConnectionStateChangedEventHandler | ( | object | sender, |
| ConnectionStateChangedEventArgs | connectionStateChangedEventArgs ) |
| sender | |
| connectionStateChangedEventArgs |
| delegate Task VideoOS.Platform.Messaging.MessageReceiverAsync | ( | IMessageReceiverArgs | message | ) |
A message receiver, attached to a topic subscription.
