VideoOS.Platform.EnvironmentCapabilities Class Reference
Used by the EnvironmentManager.Instance.HasCapability() method. More...
Static Public Attributes
const String DynamicSecurityActions = "DynamicSecurityActions"
 Defines if a plugin can add and remove SecurityActions over time. E.g. between releases. When this capability is not available, a MIP plugin should keep the same set of SecurityActions.
Detailed Description
Member Data Documentation
◆ DynamicSecurityActions
const String VideoOS.Platform.EnvironmentCapabilities.DynamicSecurityActions = "DynamicSecurityActions"
static
