Options available for the EnvironmentManager.Instance.EnvironmentOptions dictionary. More...
Static Public Attributes | |
const string | ApplicationDataFilePath = "ApplicationDataFilePath" |
Key for entry in the EnvironmentOptions specifying the absolute path to the location where plugins can store data locally. | |
const string | CompanyNameFolder = "CompanyNameFolder" |
Identify if product has been OEM'ed to another company. Used for building ProgramData\"CompanyNameFolder"\MIPSDK\ log files. | |
const string | ConfigurationChangeCheckInterval = "ConfigurationChangeCheckInterval" |
In seconds. | |
const string | ConnectionCheckTimeout = "ConnectionCheckTimeout" |
Timeout in seconds for connections to Identity Provider (IDP). | |
const string | DualItemHierarchy = "DualItemHierarchy" |
Key in EnvironmentOptions - reserved for internal use. | |
const string | HardwareDecodingMode = "HardwareDecodingMode" |
Specify if hardware decoding can be used. | |
const string | LogPrefix = "LogPrefix" |
Used by standalone application to name what it's log file should start with. | |
const string | Manufacturer = "Manufacturer" |
Key identifying VMS Manufacturer information in EnvironmentManager.EnvironmentOptions | |
const string | MulticastErrorRate = "MULTICASTERRORRATE" |
When added to EnvironmentManager.Instance.EnvironmentOptions, the value indicates when to switch from using multicast to unicast. Default is "0.25". | |
const string | MulticastLog = "MULTICASTLOG" |
When added to EnvironmentManager.Instance.EnvironmentOptions, multicast activity is logged on debug level. | |
const string | OptionHardwareDecodingModeAuto = "Auto" |
Value used on EnvironmentOptions, where key is HardwareDecodingMode. | |
const string | OptionHardwareDecodingModeAutoNvidia = "AutoNvidia" |
const string | OptionHardwareDecodingModeOff = "Off" |
const string | OptionHardwareDecodingModeOnlyIntel = "OnlyIntel" |
const string | OptionHardwareDecodingModeOnlyNvidia = "OnlyNvidia" |
const string | OptionNo = "No" |
Value used on EnvironmentOptions. | |
const string | OptionYes = "Yes" |
const string | PlayerDiagnosticLevel = "PlayerDiagnosticLevel" |
Set this value to number between "0" and "3", to display developer information on top of ImageViewerCOntrol. | |
const string | PtzReverseTiltForContinuesMoves = "PtzReverseTiltForContinuesMoves" |
This property controls if the continues move commands will have the tilt value multiplied with -1. Values can be "True", "False" - or not filled. | |
const string | RestApiCallerId = "RestApiCallerId" |
For Internal Use Only. | |
const string | ShortProductName = "ShortProductName" |
Key for entry in the EnvironmentOptions specifying the product name in a short form. | |
const string | SoftwareDecodingThreads = "SoftwareDecodingThreads" |
Defines the number of threads to be used while decoding. The value is formatted as: "4,1" - defining that 4 threads is to be used when just one stream is active, while 1 thread is used if more streams are active. | |
const string | ToolkitFork = "ToolkitFork" |
Key in EnvironmentOptions. Used by the standalone MIP Environment to define if live streams should be shared among multiple users, e.g. JPEGLiveSource, BitmapLiveSource - when possible. Default is "Yes". | |
const string | UseActiveX = "UseActiveX" |
Deprecated. Defines if the ImageViewer ActiveX should be used, or the hardware accellerated implementation should be used. | |
const string | UseControlForMessaging = "UseControlForMessaging" |
Key in EnvironmentOptions. Used by standalone MIP Environment to identify is sending and posting messages should be carried out on the top level user control. Default is "Yes". | |
const string | UsePing = "UsePing" |
Key in EnvironmentOptions. Used by standalone MIP Environment to identify is server identification should use Ping. For application connecting over the internet, this should be changed to a "No". Default is "Yes" from MIPSDK 4.0. | |
const string | UseRestApiCaching = "UseRestApiCaching" |
Used by the stand-alone MIP Environment to determine whether to use caching of the configuration. The default is "Yes". | |
const string | ViewControlSupportChangeLayout = "ViewControlSupportChangeLayout" |
Value used on EnvironmentOptions to indicate, that ViewControl supports change of layout. | |
static |
Only supported in Smart Client, Management Client and Event Server environments.
static |
static |
In seconds.
static |
Used by plug-in and standalone MIP Environments to get well known information provided by IDP. Used by standalone MIP Environment when checking connection to sites the user has access to.
Default value is "5".
static |
static |
Available options are:
"Auto" - The media toolkit selects the best way to decode, can be either using GPU or software.
"Off" - Do not utilize any hardware for decoding.
static |
Default is "MIP"
static |
static |
It represent the rate of errors compared to all frames, e.g. 0.25 signifies that when 25% of the frame are in error, swap to unicast.
Only supported in standalone environment.
static |
static |
static |
static |
static |
static |
static |
static |
static |
Value of "0" - No diagnostics
Value of "1", "2", "3" - Display more and more information about the video stream and the decoding details
If changing the value on the fly - call the EnvironmentManager.Instance.FireEnvironmentOptionsChangedEvent to have the ImageViewerControl pick up the change right away.
static |
Default is not filled (same as "False")
static |
static |
static |
Default for 32-bit application is: "4,1"
Default for 64-bit application is: "4,4"
static |
Default is "Yes".
static |
Default is "No".
Note: Valid from MIPSDK 2016 R3. Deprecated from MIPSDK 2019 R1.
static |
Default is "Yes".
static |
static |
static |
