VideoOS.Platform.Messaging.MessageCommunication Class Reference
Communication between EventServer and all other MIP Environments can be done via this class.
Each starting application or service will have one EndPoint ( Unique for each execution ), and a EndPointType.
The EventServer is defined as a EndPointType.Server and all other MIP Environments are in this context a EndPointType.Client.
Any MIP plug-in can get a list of all currently executing MIP Environments and store their EndPointFQID for communication purpose. For each EndPoint is is possible to get hold of the EndPointIdentityData class to identify the login user name for a given EndPoint.
See the WhoAreOnlineRequest and WhoAreOnlineResponse MessageId's for more on this.
This class is created through the MessageCommunicationManager static class. More...
Inheritance diagram for VideoOS.Platform.Messaging.MessageCommunication:
Public Member Functions
void Dispose ()
 Disposed internally.
object RegisterCommunicationFilter (MessageReceiver messageReceiver, CommunicationIdFilter communicationIdFilter, FQID endPoint, EndPointType endPointType)
 Register to receive specific messages, from the specified EndPoint and EndpointType.
If the EndPoint is null, all EndPoints are requested to transmit the specific messages.
The filter information is send to the EventServer, and again forwarded to relevant clients. This will allow message filtering to be done at the source of the messages and keep network transmission to a minimum.
Filters are stored in the EventServer in case of short network problems, and will be re-transmitted to clients that are re-connecting within 60 seconds. If a client is not connected for 60 seconds, all filters issued on other machines to that machine will be deleted (Unregistered).
object RegisterCommunicationFilter (MessageReceiver messageReceiver, CommunicationIdFilter messageFilter)
 Register to receive specific messages, from any other machine.
Please use this filter mechanism with care, as it can impact network traffic.
void TransmitMessage (Message message, FQID destinationEndPoint, FQID destinationObject, FQID source)
 Transmit a message. When destinationEndPoint is null, the message will be sent to the EventServer itself for processing, where the receiving message filters will be used to determine who should receive the message.
When the destinationEndPoint is filled, the message is first sent to the EventServer, that again will forward to the specified endpoint - without any validation of the message filters.
Use of the destinationEndPoint is a direct way for two clients to communicate with each other without any filters.
If the destinationEndPoint is filled with an ObjectId of Guid.Empty the message is considered a broadcast, and will be transmitted to all clients currently logged in.
void UnRegisterCommunicationFilter (object communicationFilterObject)
 To Unregister a previously registered filter.
void WaitForCommunicationFilterRegistration (CommunicationIdFilter messageFilter)
 Waits for the communication filter to be registered on server. Use the overload with timeout if you wish to limit the wait.
void WaitForCommunicationFilterRegistration (CommunicationIdFilter messageFilter, TimeSpan timeout)
 Waits for the communication filter to be registered on server Throws TimeoutException if the timeout is exceeded.
Static Public Attributes
const string EndPointCloseIndication = "MessageCommunication.EndPointCloseIndication"
 Send by the EventServer when new clients are logging out.
const string EndPointTableChangedIndication = "MessageCommunication.EndPointTableChangedIndication"
 A client connection has been opened or closed. The WhoAreOnlineRequest can be used to get a full list of online clients.
const string NewEndPointIndication = "MessageCommunication.NewEndPointIndication"
 Send by the EventServer when new clients are logging on.
const string ProvideCurrentStateRequest = "MessageCommunication.ProvideCurrentStateRequest"
 Used to get a the current state for Items. The response is returned as another message - see MessageCommunication.ProvideCurrentStateResponse.
This message should be used as few times as possible, as the result can be very large.
const string ProvideCurrentStateResponse = "MessageCommunication.ProvideCurrentStateResponse"
 The Data field contains a Collection<ItemState> with all known Items in one flat Collection.
const string WhoAreOnlineRequest = "MessageCommunication.WhoAreOnlineRequest"
 This request can be send to the Event Server to ask who is connected right now.
The response is coming in a message with id=WhoAreOnlineResponse.
const string WhoAreOnlineResponse = "MessageCommunication.WhoAreOnlineResponse"
 Contains a Collection of EndPointIdentityData for each connected user.
Protected Member Functions
virtual void Dispose (bool disposing)
Properties
static FQID BroadcastEndPointFQID [get]
 Get the FQID that can be used for broadcasting a message to all clients.
Note: Please use with care!
bool IsConnected [get]
 Returns the status of the communication to the EventServer's Communication service.
FQID ServerEndPointFQID [get]
 Get the FQID that identifies the EventServer instance.
ServerId ServerId [get]
 Provide the ServerId used during the Start operation.
Uri Uri [get]
 The Uri used for message communication.
Events
EventHandler ConnectionStateChangedEvent
 You can register on this event, if you need to know when the session to the Event Server is changing.
When receiving the event call, check the IsConnected property for the actual state.
Detailed Description
Member Function Documentation
◆ Dispose() [1/2]
void VideoOS.Platform.Messaging.MessageCommunication.Dispose ( )
inline
◆ Dispose() [2/2]
virtual void VideoOS.Platform.Messaging.MessageCommunication.Dispose ( bool disposing)
inlineprotectedvirtual
Parameters
disposing
◆ RegisterCommunicationFilter() [1/2]
object VideoOS.Platform.Messaging.MessageCommunication.RegisterCommunicationFilter ( MessageReceiver messageReceiver,
FQID endPoint,
EndPointType endPointType )
inline
Note: It can take 3-4 seconds before this registration takes effect!
Parameters
messageReceiverThe method to be called when a message matching the other parameters is received.
communicationIdFilterThe filter specifying the type of message to receive.
endPointA specific endpoint to receive messages from. If set to null messages from all endpoints will be received.
endPointTypeA specific type of endpoint to receive messages from. If set to null (along with endPoint parameter) messages from all endpoints will be received.
Returns
An object to be used for UnRegistrationCommunicationFilter
◆ RegisterCommunicationFilter() [2/2]
CommunicationIdFilter messageFilter )
inline
Note: It can take 3-4 seconds before this registration takes effect! Use WaitForCommunicationFilterRegistration(CommunicationIdFilter, TimeSpan) if you need to ensure it's registered
Parameters
messageReceiver
messageFilter
Returns
◆ TransmitMessage()
void VideoOS.Platform.Messaging.MessageCommunication.TransmitMessage ( Message message,
FQID source )
inline
For security reasons, a limitation has been put on the system types allowed to be used as the Message.Data content. See the "Introduction to MIP Message communication" for more details on the types allowed.
Parameters
messageThe actual message to be transmitted.
destinationEndPointIdentification of a specific client endpoint to receive the message. If null it will be sent to all.
destinationObjectId of a specific object within the receiving application, that is to receive the message.
sourceThe id of the sender (or null if the recipients doesn't care).
◆ UnRegisterCommunicationFilter()
void VideoOS.Platform.Messaging.MessageCommunication.UnRegisterCommunicationFilter ( object communicationFilterObject)
inline
Parameters
communicationFilterObjectThe object returned from the RegisterCommunicationFilter method
◆ WaitForCommunicationFilterRegistration() [1/2]
void VideoOS.Platform.Messaging.MessageCommunication.WaitForCommunicationFilterRegistration ( CommunicationIdFilter messageFilter)
inline
Parameters
messageFilterThe communication filter
◆ WaitForCommunicationFilterRegistration() [2/2]
void VideoOS.Platform.Messaging.MessageCommunication.WaitForCommunicationFilterRegistration ( CommunicationIdFilter messageFilter,
TimeSpan timeout )
inline
Parameters
timeoutMaximum timeout to wait, pass TimeSpan.Zero for unlimited waiting
Member Data Documentation
◆ EndPointCloseIndication
const string VideoOS.Platform.Messaging.MessageCommunication.EndPointCloseIndication = "MessageCommunication.EndPointCloseIndication"
static
◆ EndPointTableChangedIndication
const string VideoOS.Platform.Messaging.MessageCommunication.EndPointTableChangedIndication = "MessageCommunication.EndPointTableChangedIndication"
static
◆ NewEndPointIndication
const string VideoOS.Platform.Messaging.MessageCommunication.NewEndPointIndication = "MessageCommunication.NewEndPointIndication"
static
◆ ProvideCurrentStateRequest
const string VideoOS.Platform.Messaging.MessageCommunication.ProvideCurrentStateRequest = "MessageCommunication.ProvideCurrentStateRequest"
static
Sample - as part of some initialization code
_object = _messageCommunication.RegisterCommunicationFilter(ProvideCurrentStateResponseHandler,
try {
_messageCommunication.TransmitMessage(
} catch (MIPException ex)
EnvironmentManager.Instance.ExceptionDialog("Unable to get status", ex);
The EnvironmentManager is the top class for the MIP Environment. The class can always be accessed tho...
Definition EnvironmentManager.cs:33
virtual FQID MasterSite
Get the Item that represent the server that was logged in to.
Definition EnvironmentManager.cs:202
void ExceptionDialog(String where, Exception exception)
Opens an ExceptionDialog to the user with a formatted layout of the exception itself.
static EnvironmentManager Instance
This Singleton item of this class. Only the 'get' access should be used.
Definition EnvironmentManager.cs:47
ServerId ServerId
Id of the server that owns the item identified by the FQID. For cameras, microphones,...
Definition FQID.cs:57
The common Exception for all exceptions thrown by the MIP environment.
Definition MIPExceptions.cs:19
The CommunicationIdFilter is used to identify what messages to subscribe to, on another machine....
Definition CommunicationIdFilter.cs:17
Communication between EventServer and all other MIP Environments can be done via this class....
Definition MessageCommunication.cs:19
object RegisterCommunicationFilter(MessageReceiver messageReceiver, CommunicationIdFilter messageFilter)
Register to receive specific messages, from any other machine. Please use this filter mechanism with...
Definition MessageCommunication.cs:141
Used to get a the current state for Items. The response is returned as another message - see MessageC...
Definition MessageCommunication.cs:444
Definition MessageCommunication.cs:473
void TransmitMessage(Message message, FQID destinationEndPoint, FQID destinationObject, FQID source)
Transmit a message. When destinationEndPoint is null, the message will be sent to the EventServer its...
Definition MessageCommunication.cs:298
The MessageCommunicationManager holds MessageCommunication classes for each EventServer it has connec...
Definition MessageCommunicationManager.cs:20
static MessageCommunication Get(ServerId serverId)
Get the MessageCommunication class that communicates with a specific server, identified by ServerId....
Definition MessageCommunicationManager.cs:258
static void Start(ServerId serverId)
Will start message communication for the server identified by the ServerId.
Definition MessageCommunicationManager.cs:169
A Message contains information send from a sender to one or multiple receivers. It is identified by a...
Definition Message.cs:29
Definition AnyFilter.cs:6
Definition AddUserControl.cs:12
For asking for a set of Items, fill the Message.Data field with an array of guids (as String), like
new VideoOS.Platform.Messaging.Message(MessageCommunication.ProvideCurrentStateRequest, new String[] {item.FQID.ObjectId.ToString()}), null, null, null); <br>
To get the status of one specific item.
◆ ProvideCurrentStateResponse
const string VideoOS.Platform.Messaging.MessageCommunication.ProvideCurrentStateResponse = "MessageCommunication.ProvideCurrentStateResponse"
static
Sample handler code:
private object ProvideCurrentStateResponseHandler(VideoOS.Platform.Messaging.Message message, FQID dest, FQID source)
if (InvokeRequired)
{ // If we are doing UI updates, we better switch to our thread
BeginInvoke(new MessageReceiver(ProvideCurrentStateResponseHandler), message, dest, source);
} else
Collection\<ItemState\> result = message.Data as Collection\<ItemState\>;
if (result != null)
foreach (ItemState itemState in result)
Do something with itemState
return null;
The Fully Qualified ID contains a complete set of fields to contact a server and get further details....
Definition FQID.cs:50
Defines the current state a given Item has. This class is used in conjunction with the ProvideCurre...
Definition MessageCommunication.cs:514
delegate object MessageReceiver(Message message, FQID destination, FQID sender)
A method to receive Messages.
◆ WhoAreOnlineRequest
const string VideoOS.Platform.Messaging.MessageCommunication.WhoAreOnlineRequest = "MessageCommunication.WhoAreOnlineRequest"
static
◆ WhoAreOnlineResponse
const string VideoOS.Platform.Messaging.MessageCommunication.WhoAreOnlineResponse = "MessageCommunication.WhoAreOnlineResponse"
static
Property Documentation
◆ BroadcastEndPointFQID
FQID VideoOS.Platform.Messaging.MessageCommunication.BroadcastEndPointFQID
staticget
◆ IsConnected
bool VideoOS.Platform.Messaging.MessageCommunication.IsConnected
get
◆ ServerEndPointFQID
FQID VideoOS.Platform.Messaging.MessageCommunication.ServerEndPointFQID
get
◆ ServerId
ServerId VideoOS.Platform.Messaging.MessageCommunication.ServerId
get
◆ Uri
Uri VideoOS.Platform.Messaging.MessageCommunication.Uri
get
Event Documentation
◆ ConnectionStateChangedEvent
EventHandler VideoOS.Platform.Messaging.MessageCommunication.ConnectionStateChangedEvent
