This class is available in the Smart Client and the .Net Library.
Supported from Smart Client 2017 R3 It embeds and manages one ImageViewerWpfControl with the following key functions:
More...
Public Types | |
| enum | FpsRate { High = 1 , Medium = 2 , Low = 3 } |
| Defines how recorder should transcode video frames. Used on the SetVideoResolutionAndFPS method. More... | |
Public Member Functions | |
| void | ClearOverlay (int id) |
| Clear a specific overlay placed earlier. The id used during the SetOverlay() call is used in this method for clearing that overlay again. | |
| void | Close () |
| Should be called for the underlaying controls to clean up entirely. | |
| bool | ConfigureOverlayText (bool enable) |
| Controls how overlayed text is displayed for built-in messages. All built-in text messages are configured. | |
| bool | ConfigureOverlayText (OverlayTextId textId, bool enable) |
| Controls how overlayed text is displayed for built-in messages. The textId identifies the text / message being configured. | |
| bool | ConfigureOverlayTextAndImage (bool enable, bool blank) |
| bool | ConfigureOverlayTextAndImage (OverlayTextId textId, bool enable, bool blank) |
| void | Connect () |
| This method will connect the recording server owning the camera. The CameraFQID property must have been set, and the Initialize() method called before this method can be called. | |
| void | Disconnect () |
| Disconnect current session to the recording server. Following this call, the CameraFQID can be changed and a new session be established by a call to the Connect() method. | |
| void | Dispose () |
| System.Drawing.Bitmap | GetCurrentDisplayedImageAsBitmap () |
| Get the latest displayed Image including the overlays and privacy mask. Note that if no image has been received from the server, a null is returned. Important: If the returned Bitmap is used in a UserControl, like a PictureBox, the control will hold to the original Bitmap. This can cause issues when the original source of the Bitmap attempts to dispose it. Recommendation is to create another Bitmap directly upon calling this method, when passing it on to a PictureBox. | |
| System.Drawing.Bitmap | GetCurrentDisplayedImageAsBitmap (bool digitalZoomOnly) |
| Overloaded method to control if the original or the digital zoomed image is requested. | |
| ImageViewerWpfControl () | |
| Constructor. Can be used within Smart Client plug-ins and standalone application. | |
| ImageViewerWpfControl (WindowInformation windowInformation) | |
| Constructor. Only to be used within Smart Client. The WindowInformation class should be passed on from the ViewItemUserControl that this control will be added to. The main effect of adding the WindowInformation is that the ImageViewer will run in live and playback mode just like the Smart Client usually do, e.g. floating windows have different mode than the main window. | |
| void | Initialize () |
| Issue this method after the cameraFQID has been set to initialize the control. | |
| void | PtzCenter (int refWidth, int refHeight, int centerX, int centerY, int zoom) |
| Perform PTZ Center in the current mode. Either Digital zoom, PanoramicLens (Fisheye), or physical camera move. | |
| void | SetImageQuality (int percent) |
| Standalone SDK only. Tell the Recording Server how much to compress each JPEG. The value can be a number between 1..100. Or one of the special values: SuperHigh = 101 High = 102 Medium = 103 Low = 104 | |
| void | SetOverlay (System.Drawing.Bitmap bitmap, int id, bool keepAspectRatio, bool scaleWithDigitalZoom, bool scaleOverlay, double scaleFactor, VerticalAlignment verticalAlignment, HorizontalAlignment horizontalAlignment, double absolutePositionX, double absolutePositionY) |
| Place a Bitmap on top of the video being showed. Consider using ShapesOverlayAdd(List<Shape>, ShapesOverlayRenderParameters) and ShapesOverlayUpdate(Guid, List<Shape>) instead as they have better performance. After the bitmap has been set, it will remain on top of all following displayed video. The size of the bitmap can be any size that makes sense, when taking the quality into consideration. If a bitmap of e.g. (320,280) is used for creating the overlay, it can via the parameters be scaled up to the actual size of the video being displayed. Note: It is invalid set scale to true, while placing an overlay with absolute positions. Note: SetOverlay does not dispose the bitmap. It is up to the caller to call dispose when appropiate. | |
| bool | SetRenderingOptions (String xmlParameters) |
| Sets specific options for how to render video. The xmlParameter is forwarded to the ImageViewer presentation control. The document must have as its top element "<![CDATA[<RenderingOptions>]]>". | |
| void | SetVideoQuality (int smoothBufferSize, int cpusToUtilize) |
| Configure how decoding and display should work. This call represent the same functionality as the VideoQuality slider setup for a CameraViewItem. The change will take effect the next time a camera session is established. The smoothBufferSize parameter should have value in the range 1..100, where 1 is the lowest allowable quality and 100 is the highest allowable quality. The value represent how much of the maximum allocated buffer is used. When the smoothBufferSize is 0 - buffering will be turned off, and values will be the original defaults. | |
| void | SetVideoResolutionAndFps (Size resolution, FpsRate fpsRate) |
| Standalone SDK only. The FPSRate will be used to tell the server what to transmit to this client. For H.264, values of Medium and Low will be key-frames only. For H.265, values of Medium and Low will be key-frames only. For JPEG, a normal framerate of 25, will give 25 for High, 4 or 5 for medium, and 1 for low. | |
| void | SetVideoResolutionAndFps (Size resolution, int fps) |
| Obsolete. | |
| Guid | ShapesOverlayAdd (List< Shape > overlayShapes, ShapesOverlayRenderParameters renderParameters) |
| Method to add overlay shapes. | |
| void | ShapesOverlayRemove (Guid id) |
| Method to remove existing overlay shapes. | |
| bool | ShapesOverlayUpdate (Guid id, List< Shape > overlayShapes) |
| Method to update existing overlay shapes. | |
| bool | ShapesOverlayUpdate (Guid id, List< Shape > overlayShapes, ShapesOverlayRenderParameters renderParameters) |
| bool | ShapesOverlayUpdate (Guid id, ShapesOverlayRenderParameters renderParameters) |
| void | StartBrowse () |
| This method is only valid for DVR attached devices, as the playback and Live function is controlled by the ImageViewer for those. In the Smart Client and the .Net library the default implementation will ensure that a ImageViewerControl will follow the mode of the MIP environment, e.g. change mode to Live/Browse as this mode is changed by the user. In the Smart Client this means that it follows the normal rule for the window it resides on. The method should therefore only be used in the Smart Client if the control does not reside in a ViewItem. If it resides in a ViewItem, the SmartClient.ModeChangeCommand message should be used with EnvironmentManager.Instance.PostMessage/> instead. In the .Net library the mode is controlled by your application by setting the EnvironmentManager.Mode property. | |
| void | StartLive () |
| void | StartSetup () |
| This will set the ImageViewer in setup mode. Avoid using this, as it is normally controlled by the Mode set in the EnvironmentManager. | |
| void | UpdateStates () |
| When some of the 'Enabled' properties have been changed, this method will check for any changes and carry them out on the UI. | |
Properties | |
| bool | AdaptiveStreaming [get, set] |
| Determine the stream resolution should be adapted based on the view size. Only applicable in standalone SDK. In Smart Client adaptive streaming is controlled by the general Smart Client settings. | |
| FQID | CameraFQID [get, set] |
| Identifies the camera that is to be displayed in the control. This property needs to be set before the Initialize() method is called. | |
| bool | EnableBrowseMode [get, set] |
| Defines if this ImageViewerControl should be enabled in Browse (Playback) mode. If this property is false, the UserControl becomes disabled during Browse (Playback) mode. Default is true. | |
| bool | EnableDigitalZoom [get, set] |
| Defines if this ImageViewerControl allow the user to perform digital zoom operations. | |
| bool | EnableMouseControlledPtz [get, set] |
| Defines if mouse controlled PTZ should be possible. When set to true, the user can use click on video to do center-to-click and also right click and open a square of an area to zoom to. Default is true. | |
| bool | EnableMousePtzEmbeddedHandler [get, set] |
| Defines if mouse controlled PTZ should be handled automatically by this component. When set to true, the user actions will be handled automatically and no Messages or events will be issued to this class, but will be forwarded to the recording server that again will send to the camera. When set to false, the user selection will be send to the MIP Plugin or application via MIP Messages. Default is true. | |
| bool | EnableSetupMode [get, set] |
| Defines if this ImageViewerControl should be enabled in Setup mode. If this property is false, the UserControl becomes disabled during Setup mode. Default is true. | |
| bool | EnableVisibleCameraName [get, set] |
| Defines if the name of the camera is displayed in the header line. Default is true. | |
| bool | EnableVisibleHeader [get, set] |
| Defines if the blue header is displayed or not. Default is true. | |
| bool | EnableVisibleLiveIndicator [get, set] |
| Defines if the blinking green live indicator and the red motion indicator is visible. Default is true. | |
| bool | EnableVisibleTimestamp [get, set] |
| Defines if the timestamps should be shown in the top line during playback. | |
| bool | Hidden [get, set] |
| When another ViewItem is maximized, this property is set to true. | |
| Size | ImageSize [get, set] |
| Contains the size of the original image before it was scaled to available display area. | |
| String | InfoText [get, set] |
| Used for displaying a text when the ImageViewer ImageViewer is NOT shown. When the ShowImageViewer is set to false, the text stored in the InfoText field will be displayed. The text is displayed in Color.Black on a transparent background. | |
| bool | MaintainImageAspectRatio [get, set] |
| Flag to instruct the presentation of the video to be displayed with the original aspect ratio (Default), or to fill the entire viewable area. | |
| bool | Maximized [get, set] |
| Defines if this ImageViewerControl is currently in a Maximized ViewItem. This property cannot be used to maximize a ViewItem, use a SendMessage for that. | |
| Point | PaintLocation [get, set] |
| Contains the location of actual image within this usercontrol. | |
| Size | PaintSize [get, set] |
| Contains the size of the areas used for video. | |
| FQID | PlaybackControllerFQID [get, set] |
| Defines which PlaybackController is controlling this ImageViewer in Playback mode. The FQID used here is returned by the ClientControl.GeneratePlaybackController() method. | |
| bool | Selected [get, set] |
| Define if this ImageViewerControl is in the currently selected ViewItem. When set to true, the top bar of the ImageViewerControl will change color to a brighter color and digital zoom events like e.g. the scroll-wheel will be propagated to this control. This property cannot be used in the Smart Client to select your own ImageViewerControl, use a SendMessage for that. | |
| bool | ShowImageViewer [get, set] |
| This property can be used to control if the ImageViewer should be shown or not. This can for example be used to hide the ImageViewer when there is no camera defined yet. When the ImageViewer is not shown, the InfoText field is displayed instead. | |
| bool | ShowInitialImage [get, set] |
| Determine whether to send an initial image before the stream is started AND control how the "Camera feed has stopped" message is displayed Only applicable in standalone SDK. | |
| Guid | StreamId [get, set] |
| Identifies which stream to use. Use the StreamDataSource class to get a list of available streams. Note that multiple stream support is obly available on some Milestone products. | |
| bool | SuppressUpdateOnMotionOnly [get, set] |
| Defines whether the Update On Motion Only camera param is suppressed. | |
| bool | UsingMulticast [get, set] |
| Indicates if the video is received from the recording server via multicast. | |
Events | |
| EventHandler< ConnectResponseEventArgs > | ConnectResponseReceived = delegate { } |
| Register on this event to be called when a connection has completed. | |
| EventHandler< ImageDisplayedEventArgs > | ImageDisplayed = delegate { } |
| Called for every image being displayed, exactly when it is presented to the operator. The method registered on this event MUST be VERY short. | |
| EventHandler< ImageOrPaintInfoChangedEventArgs > | ImageOrPaintInfoChanged = delegate { } |
| Is fired when one of the these field has been changed: ImageSize, PaintSize, PaintLocation. | |
| EventHandler< LiveStreamInformationReceivedEventArgs > | LiveStreamInformationReceived = delegate { } |
| Register on this event to be called when the live stream XML information is available. | |
| EventHandler< RecordedImageReceivedEventArgs > | RecordedImageReceived = delegate { } |
| Register on this event to be called when a recorded image has been received. | |
inline |
inline |
| windowInformation |
inline |
| id |
inline |
inline |
| enable | When set to true, the text is displayed; when set to false the text is suppressed. |
inline |
| textId | Text id of the message to control, |
inline |
| enable | When set to true, the text is displayed; when set to false the etxt is suppressed. |
| blank | When set to false, the image is drawn; when set to true the image is not drawn. |
inline |
inline |
inline |
inline |
inline |
inline |
inline |
inline |
The zoom parameter can be -1 for no change, or a range from 0..1000, where 0 will zoom out completely. The other values are can be in any size and does not relate to the real resolution of the image.
Will zoom 50% and center around a point (25,50) to the left hand side of the image.
| refWidth | Reference width of center |
| refHeight | Reference height of center |
| centerX | |
| centerY | |
| zoom |
inline |
SuperHigh = 101
High = 102
Medium = 103
Low = 104
Note: Values below 100 are not supported.
| percent |
inline |
| bitmap | |
| id | |
| keepAspectRatio | |
| scaleWithDigitalZoom | |
| scaleOverlay | |
| scaleFactor | |
| verticalAlignment | |
| horizontalAlignment | |
| absolutePositionX | |
| absolutePositionY |
inline |
Example of a valid rendering options xml document: "<RenderingOptions><Deinterlacing><Method>BOB_TOP</Method></Deinterlacing></RenderingOptions>"
Deinterlacing options supported: "<Deinterlacing><Method>...</Method></Deinterlacing>" Where ... is one of
"DEFAULT": Set deinterlacing method to the legacy mode that may weave fields.
"BOB_TOP": Set deinterlacing method to bob. Preferently bob the top field.
"BOB_BOTTOM": Set deinterlacing method to bob. Preferently bob the bottom field.
"CONTENT_ADAPTIVE_VERTICAL_TEMPORAL": Set deinterlacing to content adaptive veritcal temportal (CAVT).
CAVT is a filter that suppresses interlacing artifacts by analysis of each frame (top + bottom field).
The CAVT deinterlacing variant accept a Threshold parameter in the range 0..255, eg. "<RenderingOptions><Deinterlacing><Method>CONTENT_ADAPTIVE_VERTICAL_TEMPORAL</Method><Threshold>20</Threshold></Deinterlacing></RenderingOptions>" Threshold default (used if element is not present) is 12. The threshold determines the level of vertical variation that causes the filter to kick in. Furthermore CAVT accept a PreferredField parameter (either "TOP" (default) or "BOTTOM") that controls the field to bob for low resolution rendering, e.g. "<RenderingOptions><Deinterlacing><Method>CONTENT_ADAPTIVE_VERTICAL_TEMPORAL</Method><PreferredField>BOTTOM</PreferredField></Deinterlacing></RenderingOptions>"
| xmlParameters |
inline |
| smoothBufferSize | The percent of buffer to utilize. A number of 100 will use all available buffer, e.g. 4 seconds |
| cpusToUtilize | The number of CPU cores to use during decoding |
inline |
| resolution | |
| fpsRate |
inline |
Obsolete.
inline |
The returned Guid is used to later modify and remove the overlays.
| overlayShapes | |
| renderParameters |
inline |
| id |
inline |
| id | |
| overlayShapes |
inline |
| id | |
| overlayShapes | |
| renderParameters |
inline |
| id | |
| renderParameters |
inline |
inline |
inline |
inline |
getset |
getset |
getset |
Default is true.
getset |
Note: When this flag is set to true, the EnableMousePtzEmbeddedHandler should also be true and in standalone mode Selected must also be set to true for the ImageViewer react to e.g. scroll-whell events.
Default is false.
getset |
Default is true.
Related property: EnableMousePtzEmbeddedHandler
getset |
getset |
Default is true.
getset |
Only supported in standalone.
getset |
getset |
Note: This flag was set as Obsolite in 2016R3, but has been re-instated from 2017R1
getset |
getset |
getset |
getset |
getset |
getset |
getset |
getset |
Top line and black filler areas are not included in this size.
getset |
getset |
getset |
getset |
true to send an initial image before the camera feed has started and show the "Camera feed has stopped" message on a transparent overlay;
false to disable sending an initial image and show the message on black overlay
getset |
getset |
Only supported in Smart Client.
getset |
Supported from 2016
| EventHandler<ConnectResponseEventArgs> VideoOS.Platform.Client.ImageViewerWpfControl.ConnectResponseReceived = delegate { } |
| EventHandler<ImageDisplayedEventArgs> VideoOS.Platform.Client.ImageViewerWpfControl.ImageDisplayed = delegate { } |
| EventHandler<ImageOrPaintInfoChangedEventArgs> VideoOS.Platform.Client.ImageViewerWpfControl.ImageOrPaintInfoChanged = delegate { } |
| EventHandler<LiveStreamInformationReceivedEventArgs> VideoOS.Platform.Client.ImageViewerWpfControl.LiveStreamInformationReceived = delegate { } |
| EventHandler<RecordedImageReceivedEventArgs> VideoOS.Platform.Client.ImageViewerWpfControl.RecordedImageReceived = delegate { } |
