VideoOS.Platform.UI Namespace Reference
Namespaces
namespace  Automation
namespace  Commands
namespace  Controls
namespace  Converters
namespace  Extensions
namespace  ItemPicker
namespace  Resources
namespace  Utils
Classes
class  DependencyObjectExtension
class  HelpUserControl
 This class can be used to display the general help or information page when the administrator selects the plug-in node. More...
class  ItemPickerForm
 This class is deprecated. Windows Forms controls are no longer supported. Use ItemPickerWpfWindow instead. A form used for selecting a single Item.
After this form has been created, the properties should be set, and the Init() method should ALWAYS be called.
More...
class  ItemPickerUserControl
 This class is deprecated. Windows Forms controls are no longer supported. Use ItemPickerWpfWindow instead. The ItemPickerUserControl is used to select one or multiple items. The control has a layout of a TreeView with items to select from and a ListView with the selected items.
Category and Kind dropdowns can be hidden.
This control requires a call to Init() for the Icons to show up correctly.
For adding this UserControl to a Form for selecting one or more cameras and one or more events, the following code could be used:
More...
class  ItemPickerWpfUserControl
 The ItemPickerWpfUserControl can be embedded into any custom WPF control you create, to allow selecting one or more Items from a list. It should be configured using its properties. More...
class  ItemPickerWpfWindow
 The ItemPickerWpfWindow can be used as a Dialog to allow the user to select one or more Items from a provided list. It should be configured using the properties. More...
class  ScrollableWindowsFormsHost
 This class is a Windows Forms host which supports being inside a scroll container. More...
class  TaggedItem
 For internal use only.
class  ThemeManager
class  Util
 A utility class to collect all Icons used in the system for both plug-ins and for the Environment.
Lookup to an Icon is done via KindToImageIndex, and KindToCategory can be used for the default Category if an Kind. More...
class  WaitCursor
 A simple class to be used around code taking a bit of time to execute. More...
class  WindowsFormsHostConstants
class  WpfWaitCursor
 A simple class to be used around code taking a bit of time to execute. This should be used in WPF application. More...
Enumerations
enum  SelectionModeOptions { SingleSelect = 1 , AutoCloseOnSelect = 2 , MultiSelect = 3 }
 Options. More...
Enumeration Type Documentation
◆ SelectionModeOptions
Options.
Enumerator
SingleSelect
Single selection.
AutoCloseOnSelect
Auto selection, works like single selection but where the item is auto selected.
MultiSelect
Multi selection.
