Introduction to MIP Message communication
The MIP Message communication service offers a simple method for transmitting and receiving messages across MIP applications and plugins executing on different machines.
The communication is controlled by the Event Server, as all messages are forwarded to the Event Server and used directly by the Event Server or by plug-ins in the Event Server, or is distributed to other MIP Environments requesting the messages.
A MIP application or plug-in must register a set of filters to define what messages to receive and from which source. Only messages that are requested by at least one MIP Environment will be transmitted from a given MIP Environment.
It is also possible to directly send a message to another MIP Environment, even if the other MIP Environment did not register a filter, provided that the sender knows the destination FQID of the receiving MIP Environment.
The Event Server acts as a MIP message router. MIP based applications may send/receive messages by establishing sessions to the Event Server (Gray arrows).
MIP Messages sent by an application (red arrows) will be filtered and forwarded by the Event Server.
Method of operation
Port used for MIP Message communication
The MIP Environment in the Event Server offers a web service located on default port 22333 (2 numbers higher than the Event Server port number). An application initiates the message communication in another MIP Environment by calling MessageCommunicationManager.Start(EnvironmentManager.Instance.MasterSite.ServerId)
The underlying MIP Environment will go through these steps to build the URL:
- Loop through existing
LoginSettingsCache
to find the server - Ask that server for what Registered Services are available
- Locate the Event Server definition
- Use the URL and add 2 to the port
The MIP Environment will now establish a slow polling thread to maintain a 2-way communication with a hanging call for receiving messages from the Event Server (and indirectly from other Environments) – and another specific web client for transmitting messages immediately to the Event Server.
Delayed Event Server communication
This section is not relevant anymore, earlier text removed - event server plugin can now initialize MessageCommunication
in their Init()
method as for all other environments.
Message filtering
Message filters are registered and un-registered by a given MIP plug-in. The registration can be performed immediately after startup, and will be cached in the MessageCommunicationManager
class. When the Environment has established the message exchange session with the Event Server it will forward all filters to the event server. The event server will then forward the filters to the relevant other MIP Environments. If, for example, you create a chat application you can listen to your own message id MyApp.ChatLine
sent from any one of the other MIP applications. To send a text line, simply issue a TransmitMessage
with the above message id and the text line in the content. The Event Server will then forward the same message to all MIP Environments listening to this message, for example a Smart Client having the chat plug-in loaded.
Error handling
Registered filter definitions are cached in the original MIP Environment as well as in the Event Server. This is to assist in re-establishing correct filters in case the MessageCommunication
web services are unavailable for a short while.
If the web service session is lost between a MIP Environment client and a given Event Server, an event is fired to notify the application or plug-ins. The following code will setup to get the event from the master site:
_messageCommunication = MessageCommunicationManager.Get(
EnvironmentManager.Instance.MasterSite.ServerId );
_messageCommunication.ConnectionStateChangedEvent += new
EventHandler(_messageCommunication_ConnectionStateChangedEvent);
You can now display the state or notify the user, when the event handler is called.
When the session is re-established after a failure, the filters are automatically sent again from the executing MIP Environment to the Event Server, and the Event Server will in turn also re-send all filters it has cached to the executing MIP Environment (when other Environments have registered filters relevant for your application).
Messages being send when the communication web service is down will throw a MIPException
for you to handle.
When a message has been sent correctly from one MIP Environment to the Event Server, but the Event Server does not currently have contact to the receiving MIP Environment, the message will be queue up for 60 seconds and transmitted to the receiving end if it comes online within this period.
For making guaranteed delivery communication, another layer of messages should be developed, so all senders will get a sort of “ACK” back from the receiving application.
Multiple Event Servers
When multiple Event Servers are involved, you call the MessageCommunicationManager.Start( serverId )
for each of the servers owning an Event Servers.
Afterwards, there is a MessageCommunication
instance handling the communication flow to and from each Event Server. It is accessed through:
This class is used for transmitting messages relevant for the applications connected to that Event Server.
The MessageCommunication
class also contains an FQID for the Event Server itself, used for sending the built-in messages.
When multiple Event Servers are active at one time, it is possible to receive messages from all Event Servers.
Built-in messages
The following messages assist in getting up and running:
WhoAreOnlineRequest
: This message can be send by an application to get a list of all the other MIP Environments currently communicating to the Event Server.WhoAreOnlineResponse
: The response to the above request, the Data field contains a list of EndPointIdentityData’sNewEndPointIndication
: Is sent by Event Server to all MIP Environments to notify about a new application logged on.EndPointTableChangedIndication
: Is send by Event Server when someone is logged on or off.
Notice that when new application is logging on both the NewEndPointIndication
and the EndPointTableChangedIndication
messages will be send, but when an application is logging off, only the EndPointTableChangedIndication
is sent.
A sample startup could be:
MessageCommunicationManager.Start(EnvironmentManager.Instance.MasterSite.ServerId);
_messageCommunication = MessageCommunicationManager.Get(EnvironmentManager.Instance.MasterSite.ServerId);
_obj1 = _messageCommunication.RegisterCommunicationFilter(WhoAreOnlineResponseHandler,
new VideoOS.Platform.Messaging.CommunicationIdFilter(
MessageCommunication.WhoAreOnlineResponse));
_obj2 = _messageCommunication.RegisterCommunicationFilter(NewEndPointHandler,
MessageCommunication.NewEndPointIndication));
_obj3 = _messageCommunication.RegisterCommunicationFilter(EndPointTableChangedHandler,
MessageCommunication.EndPointTableChangedIndication));
_obj4 = _messageCommunication.RegisterCommunicationFilter(ChatLineHandler,
new VideoOS.Platform.Messaging.CommunicationIdFilter(MessageIdChatLine));
EndPoint identification
To be able to send messages to specific applications or plug-ins, each MIP Environment has its own EndPoint FQID. The Event Server’s EndPoint is stored on the MessageCommunication class as ServerEndPointFQID, as it is the server side of the communication web service. While all other MIP Environments has one client FQID located in the MessageCommunicationManager class as EndPointFQID.
In a MIP .Net Library application accessing multiple Event Servers, such as in an MFA architecture, initialize the Message Communication client with the ServerId of the site you want to connect to; be aware that messages cannot flow between different sites.
A BroadcastEndPointFQID is located on the MessageCommunication that can be used for establishing contact.Please use this with care, as it will transmit the Message to all connected MessageCommunication clients.
The EndPointFQIDs are used when transmitting messages and for setting up filters by calling the RegisterCommunicationFilter method.
Security setting
The MessageCommunicationManager has a Security field containing the level of security the MIP Environment is in. The default setting is SecurityLevel.Normal.
The following security levels are defined:
- High – Ignore all incoming messages
- Normal – ignore incoming messages that ends with “Command”
- Low – accept all incoming messages
Regardless of the SecurityLevel it is always possible to transmit messages.
Notice that for Smart Client MIP Environment, setting this to SecurityLevel.Low will allow remote applications to control the Smart Client.
MIP Message content
Messages are contained in the ExternalMessage
class. It contains fields similar to the Message class used for Environment messaging and is extended with relevant information about EndPoints, e.g. the SourceEndPoint
and the SourceEndPointType
Messages are transmitted in a serialized format. You can define your own classes for containing information to be transmitted as long as all fields can be serialized; the Data
field is assigned to a specific class.
- Note:
- Do not override the
ExternalMessage
class.
When doing a request/response kind of operation, define one MessageId
for the request and another for the response. These need to be sent in two different operations.
Limitations on types allowed in the Message.Data
field
No instances of types defined in the Microsoft
namespace are allowed to be assigned to the Message.Data
field and only the following from the System
namespace are allowed:
System.String
System.Int16
System.Int32
System.Int64
System.Single
System.Double
System.Char
System.Boolean
System.DateTime
System.TimeSpan
System.Guid
System.Collections.ObjectModel.Collection
System.Collections.Generic.List
System.Collections.Generic.KeyValuePair
System.Collections.Generic.HashSet
System.Collections.Generic.Dictionary
If a message with a prohibited object is received by the Event Server, the message will be discarded and a log written to the Event Server MIP log.
If you have a plug-in or other integration that is using a prohibited class type, you can create a file named MessageCommunicationSettings.config
in the
Event Server installation folder, add content similar to the following to it, and restart the Event Server:
<?xml version="1.0" encoding="utf-8" ?>
<MessageCommunicationSettings>
<AdditionalAllowedTransmitTypes>
<AdditionalAllowedTransmitType message="MyMessageId" allowedTypes="System.Text.StringBuilder" />
</AdditionalAllowedTransmitTypes>
</MessageCommunicationSettings>
If multiple types are used with same message id, add them all to allowedTypes
separated by semicolon.
Types from plug-in defined namespace are allowed.
Relevant samples
Component integration
- Status Viewer: A standalone sample that receives all status information from the Event Server and displays it. Can be used for PSIM like solutions where the status and events is displayed in an application other than the Smart Client.
- Alarm and Event Viewer: A sample that can display the list of alarms, similar to the alarm overview in the Smart Client. It is updated directly from the Event Server when new alarms are created or old alarms are changed.
- Multi-Site Status Viewer
- Video Wall Controller
Plug-in integration
- Message Tester
- Chat: A sample plugin running in both the Smart Client and the Administrators. It can display currently connected list of users and transmit lines of text to the other users.
- Smart Client View and Window Tool
