VideoOS.Platform.Configuration Class Referenceabstract
Configuration provides access to all configuration objects within the Milestone Platform.
This covers well known Milestone objects like Cameras, Servers, Presets events etc, but also 3rd party plug-in objects can be accessed though this interface.
Access to this class is done via Configuration.Instance. More...
Classes
class  RegistrationServiceEndpoint
 Defines one individual endpoint, contained within some service. Multiple Endpoints are relevant for e.g. support of multiple Authentication types or multiple Uri's. More...
struct  ServiceURIInfo
 The information stored for each services. More...
Public Member Functions
virtual void BeginMassUpdate ()
 Calling this method will suspend updating the UI for every change done to the configuration. When issuing many SaveItemConfiguration or DeleteItemConfiguration, this method can be called to speed up the changes. Always call the EndMassUpdate() when complete to get the UI updated. This method is only relevant when executing in one of the administrator environments.
virtual void DeleteItemConfiguration (Guid platformDefinitionId, Item item)
 Delete configuration for one Item.
virtual void DeleteItemConfiguration (ServerId serverId, Guid platformDefinitionId, Item item)
virtual void EndMassUpdate ()
 Is called when updated of many items is complete. The UI will be refreshed to reflect the changes been done while the BeginMassUpdate has been called.
virtual VideoOS.Platform.Admin.AssociatedProperties GetAssociatedProperties (Item item, Guid pluginId)
 Get the properties that is associated with item, for the pluginId.
Item GetItem (FQID fqid)
 Get one specific item by its fully-Qualified ID.
Item GetItem (Guid objectId, Guid kind)
 Get one specific Item, based on its ObjectId (the Guid), and the Kind of Item. The Kind is supplied to speedup the lookup method.
Item GetItem (ServerId serverId, Guid objectId, Guid kind)
 Get one specific Item, based on its ObjectId (the Guid), the Kind of Item, and the Server it is located on. The Kind and ServerId is supplied to speedup the lookup method.
virtual void GetItemAsync (FQID fqid, AsyncItemHandler asyncItemHandler, Control control, object callerReference)
 Lookup one specific item by its fully-Qualified ID.
virtual Item GetItemConfiguration (Guid pluginDefinitionId, Guid itemKind, Guid objectId)
 Retrieve one item of a specific Kind and with a specific objectId. Also see comment on GetItemConfiguration about converting to own class.
virtual Item GetItemConfiguration (ServerId serverId, Guid pluginDefinitionId, Guid itemKind, Guid objectId)
virtual long GetItemConfigurationDataVersion (Guid itemKind)
 Return the DataVersion of the currently loaded configuration for a given Kind.
If it is not loaded, then 0 is returned.
virtual long GetItemConfigurationDataVersion (ServerId serverId, Guid itemKind)
virtual DateTime GetItemConfigurationLastModified (ServerId serverId, Guid kind)
 Get the DateTime for the latest update to a given kind.
virtual List< Item > GetItemConfigurations (Guid pluginDefinitionId, Item parentItem, Guid itemKind)
 Retrieve a list of items with a specific Kind and located under a specific parentItem. If the parentItem is null, then all Items of this Kind is returned.
It should be noted that the returned Items are constructed from the base Item class. If your implementation needs its own Item classes, you need to convert the result to your type of class. For example:
virtual List< Item > GetItemConfigurations (ServerId serverId, Guid pluginDefinitionId, Item parentItem, Guid itemKind)
 Retrieve a list of items with a specific Kind and located under a specific parentItem. This overloaded method loads the configuration from a specific server as identified by the ServerId.
List< Item > GetItems ()
 All Items configured on this server. Only top nodes are returned initially. All the top level Items can be retrieved through the GetItem and GetItemAsync methods.
virtual List< Item > GetItems (ItemHierarchy itemHierarchy)
 All Items configured on this server. Only top nodes are returned initially. This method may take some time to perform, and should not be called from a UI thread.
virtual void GetItemsAsync (AsyncItemsHandler asyncItemsHandler, Control control, object callerReference)
 All Items configured on this server. Only top nodes are returned initially, with items matching ItemHierarchy.UserDefined. If the control parameter is supplied, the asyncItemsHandler is Invoked on that control, ensuring that the called method is executing on the correct Thread.
Parameters
asyncItemsHandlerThe handler to be called with the result
controlIf supplied, the UI Control to execute the asynchronous handler on
callerReferenceAny object the caller may need to interpret the result.
List< Item > GetItemsByKind (Guid kind)
 Return the top level list of items having the specified Kind. The returned list will often contain Server Items or folder type Items, as they in turn contain Items of the specified Kind.
virtual List< Item > GetItemsByKind (Guid kind, ItemHierarchy itemHierarchy)
 Return the top level list of items having the specified Kind. the ItemHierarchy specify which hierarchy to return, user defined groups or physical hierarchy.
List< Item > GetItemsByKindSorted (Guid kind)
 As GetItemsByKind(kind) sorted by item.Name;.
List< Item > GetItemsByKindSorted (Guid kind, ItemHierarchy itemHierarchy)
 As GetItemsByKind(kind,itemHierarchy) sorted by item.Name;.
virtual List< Item > GetItemsBySearch (String searchText, int maxCount, int maxSeconds, out SearchResult searchResult)
 Initiates a search for Items that can match a text. Generally the name and properties will be searched. These methods will perform a slow search through all Items to identify the ones matching the search text. If the number of matches exceeds the specified limit, or if the elapsed time is exceeded the return handler will be called with a result indicating the reason for stopping. If a successful number of Items are found within a reasonable time, the handler is called with a result of OK.
virtual void GetItemsBySearchAsync (String searchText, int maxCount, int maxSeconds, AsyncItemsSearchHandler asyncItemsHandler, Control control, object callerReference)
 Initiates a search for Items that can match a text. Generally the name will be searched. These methods will perform a slow search through all Items to identify the ones matching the search text. If the number of matches exceeds the specified limit, or if the elapsed time is exceeded the return handler will be called with a result indicating the reason for stopping. If a successful number of Items are found within a reasonable time, the handler is called with a result of OK.
List< Item > GetItemsSorted ()
 As GetItems() sorted by item.Name;.
List< Item > GetItemsSorted (ItemHierarchy itemHierarchy)
 As GetItems(itemHierarchy) sorted by item.Name;.
virtual XmlNode GetOptionsConfiguration (Guid optionsDialogId, bool userPrivate)
 This method returns the configuration created in the Smart Client’s options dialog.
It is intended to be used together with Client.OptionsDialogPlugin class to get previous defined configuration.
The configuration can be saved for use by all users or be saved for each user. One plug-in can store as many sets of configuration as it needs by defining and using multiple guid’s.
The actual configuration is stored on the server the smart client or the SDK, is currently logged into.
Note that option dialogs are now supported with MIP v3 in the administrators, and that these dialogs can choose to use the GetOptionsConfiguration and SaveOptionsConfiguration methods. When doing so, please ALSO add the guids used in this call on the PluginDefinition.OptionDialogGuids to define what Guids to pre-load in the administrator.
virtual List< Configuration.ServiceURIInfo > GetRegisteredServiceUriInfo (Guid serviceType, ServerId serverId)
 Get all Registered services on from server identified by ServerId, that has a specific serviceType. Built in service types are: MAPServiceType LogServiceType.
virtual List< Configuration.ServiceURIInfo > GetRegisteredServiceUriInfo (ServerId serverId)
 Get all Registered services on from server identified by ServerId.
virtual Client.ViewGroup GetViewGroup (Guid groupId)
 Returns the content of one ViewGroup.
virtual ReadOnlyCollection< ViewGroupInfo > GetViewGroups ()
 Returns the list of available viewgroups designed for Smart Client usage.
virtual void RefreshConfiguration (Guid kind)
 This call will clear current cache and next Get operation will request a new copy from the server.
virtual void RefreshConfiguration (ServerId serverId, Guid kind)
 This call will clear current cache of items from a specific server, and next Get operation will request a new copy from the server.
virtual void RegisterServiceUri (Guid serviceType, ServerId serverId, Guid instance, Uri uri, String name, string description, string customData)
 Register own service on a login server. Can be used when your have multiple servers involved in performing a CPU heavy task, and still want to access all servers from the different plug-ins.
virtual void RegisterServiceUri (Guid serviceType, ServerId serverId, Guid instance, Uri uri, String name, string description, string customData, List< RegistrationServiceEndpoint > endpoints)
virtual void SaveAssociatedProperties (VideoOS.Platform.Admin.AssociatedProperties associatedProperties)
 Will save the associated properties on the VMS server, for use by any relevant application.
virtual void SaveItemConfiguration (Guid pluginDefinitionId, Item item)
 Call this to notify the system that there is configuration to be saved for the Item.
virtual void SaveItemConfiguration (ServerId serverId, Guid pluginDefinitionId, Item item)
 Save one Item's configuration. Note that the serialization method serializes the Item base class, make sure that any fields that need to be saved are stored in the Properties Dictionary.
virtual void SaveOptionsConfiguration (Guid optionsDialogId, bool userPrivate, XmlNode xmlNode)
 This method works in conjunction with the GetOptionsConfiguration method, to save a configuration.
The Client.OptionsDialogPlugin class has built-in methods that use these two methods. Even though these methods are designed to support saving configuration defined on the Smart Client’s option dialog, a plugin could utilize these methods for saving any relevant configuration or settings that the plug-in may need to share with other users or have common for the same user – no matter where that user connects from.
virtual void UnRegisterServiceUri (ServerId serverId, Guid instance)
 UnRegister own service from a server.
Static Public Attributes
static readonly Guid LogServiceId = new Guid("3D6F1153-92AD-43F1-B467-9482FFD291B2")
 The id for the Log service.
static readonly Guid LogServiceType = new Guid("3D6F1153-92AD-43F1-B467-9482FFD291B2")
 The type for the Log service.
static readonly Guid MAPServiceId = new Guid("08AB8F23-9AEF-4298-9CAA-F39259FE7CDA")
 The type for the Event and MAP service.
static readonly Guid MAPServiceType = new Guid("08AB8F23-9AEF-4298-9CAA-F39259FE7CDA")
static bool TraceItemConfigurationCache
 Indicate if the ItemConfigurationCache should enable for tracing.
Properties
ConfigurationApiManager ConfigurationApiManager = new ConfigurationApiManager() [get]
 The ConfigurationApiManager provides options to control what API to use (Rest or Configuration API -SOAP), as well as a debug flag to dump out all Rest API calls.
static Configuration Instance [get, set]
 This class only exists once and can be accessed through the Instance static field. Only use the 'get' access method.
bool IsMIPItemSupported [get, set]
 Will return true for Corporate releases 12.3 (2018R3) or later.
FQID ServerFQID [get]
 Identifies the server that the application is currently logged into.
String ServerName [get]
 The Name of the Server, if one exists. Otherwise the DNS name / IP address.
Detailed Description
Member Function Documentation
◆ BeginMassUpdate()
virtual void VideoOS.Platform.Configuration.BeginMassUpdate ( )
inlinevirtual
◆ DeleteItemConfiguration() [1/2]
virtual void VideoOS.Platform.Configuration.DeleteItemConfiguration ( Guid platformDefinitionId,
Item item )
inlinevirtual
This method is only implemented in the Management Client and Event Server (not in Smart Client and standalone SDK).
Parameters
itemThe Item to delete
◆ DeleteItemConfiguration() [2/2]
virtual void VideoOS.Platform.Configuration.DeleteItemConfiguration ( ServerId serverId,
Item item )
inlinevirtual
Parameters
serverIdIdentify the server the configuration is located
◆ EndMassUpdate()
virtual void VideoOS.Platform.Configuration.EndMassUpdate ( )
inlinevirtual
◆ GetAssociatedProperties()
virtual VideoOS.Platform.Admin.AssociatedProperties VideoOS.Platform.Configuration.GetAssociatedProperties ( Item item,
Guid pluginId )
inlinevirtual
This is intended to be configured on the user control provided via the TabPlugin, and used anywhere.
Parameters
item
pluginId
Returns
◆ GetItem() [1/3]
Item VideoOS.Platform.Configuration.GetItem ( FQID fqid)
abstract
Parameters
fqidThe ID of the item to lookup
Returns
An Item identified by the FQID or null if not identified/found
◆ GetItem() [2/3]
Item VideoOS.Platform.Configuration.GetItem ( Guid objectId,
Guid kind )
abstract
Parameters
objectIdThe unique ID of this Item
kindThe Kind of the Item
Returns
◆ GetItem() [3/3]
Item VideoOS.Platform.Configuration.GetItem ( ServerId serverId,
Guid objectId,
Guid kind )
abstract
Parameters
serverIdThe ID of the server where this Item is located
kindThe Kind of Item
Returns
◆ GetItemAsync()
virtual void VideoOS.Platform.Configuration.GetItemAsync ( FQID fqid,
Control control,
object callerReference )
inlinevirtual
Parameters
asyncItemHandlerThe handler to be called with the result
Returns
An Item for this item
◆ GetItemConfiguration() [1/2]
virtual Item VideoOS.Platform.Configuration.GetItemConfiguration ( Guid pluginDefinitionId,
Guid itemKind,
Guid objectId )
inlinevirtual
Parameters
pluginDefinitionIdThe plug-in owner of the configuration
itemKindThe ID of the ItemNode
objectIdThe specific id of the Item to get
Returns
The found Item. If no nodes exists null is returned
◆ GetItemConfiguration() [2/2]
virtual Item VideoOS.Platform.Configuration.GetItemConfiguration ( ServerId serverId,
Guid itemKind,
Guid objectId )
inlinevirtual
Parameters
Returns
◆ GetItemConfigurationDataVersion() [1/2]
virtual long VideoOS.Platform.Configuration.GetItemConfigurationDataVersion ( Guid itemKind)
inlinevirtual
Parameters
itemKind
Returns
◆ GetItemConfigurationDataVersion() [2/2]
virtual long VideoOS.Platform.Configuration.GetItemConfigurationDataVersion ( ServerId serverId,
Guid itemKind )
inlinevirtual
Parameters
serverId
itemKind
Returns
◆ GetItemConfigurationLastModified()
virtual DateTime VideoOS.Platform.Configuration.GetItemConfigurationLastModified ( ServerId serverId,
Guid kind )
inlinevirtual
Parameters
serverId
kind
Returns
◆ GetItemConfigurations() [1/2]
virtual List< Item > VideoOS.Platform.Configuration.GetItemConfigurations ( Guid pluginDefinitionId,
Item parentItem,
Guid itemKind )
inlinevirtual
List\<Item\> result = GetItemConfiguration(...);
List\<Item\> myResult = new List\<Item\>();
foreach (Item item in result)
myResult.Add(new MyItem(item.FQID, item.Name, item.Properties));
virtual Item GetItemConfiguration(Guid pluginDefinitionId, Guid itemKind, Guid objectId)
Retrieve one item of a specific Kind and with a specific objectId. Also see comment on GetItemConfigu...
Definition Configuration.cs:387
This class is used as a base class of all objects and items, be it cameras, audio sources or plug-in ...
Definition Item.cs:52
virtual String Name
The Display Name of this Item.
Definition Item.cs:174
virtual FQID FQID
The Fully Qualified ID of this Item.
Definition Item.cs:165
virtual Dictionary< String, String > Properties
Returns a set of selected properties for the Item. Can also return null, if implementation has no rel...
Definition Item.cs:418
As explained elsewhere, you may need your own class to implement e.g. GetChildren() and GetParent()
Parameters
parentItemIdentify the Item that is parent to the one we are looking for. If parentItem is null, then there are no parent.
itemKindThe Kind of Items to get
Returns
A list of all the configuration Items matching the parameters. If no nodes exists a list of zero entries is returned
◆ GetItemConfigurations() [2/2]
virtual List< Item > VideoOS.Platform.Configuration.GetItemConfigurations ( ServerId serverId,
Item parentItem,
Guid itemKind )
inlinevirtual
Parameters
serverIdIdentify the server where the configuration is located
Returns
◆ GetItems() [1/2]
List< Item > VideoOS.Platform.Configuration.GetItems ( )
abstract
◆ GetItems() [2/2]
virtual List< Item > VideoOS.Platform.Configuration.GetItems ( ItemHierarchy itemHierarchy)
inlinevirtual
◆ GetItemsAsync()
virtual void VideoOS.Platform.Configuration.GetItemsAsync ( AsyncItemsHandler asyncItemsHandler,
Control control,
inlinevirtual
Parameters
◆ GetItemsByKind() [1/2]
List< Item > VideoOS.Platform.Configuration.GetItemsByKind ( Guid kind)
abstract
Parameters
kind
Returns
◆ GetItemsByKind() [2/2]
virtual List< Item > VideoOS.Platform.Configuration.GetItemsByKind ( Guid kind,
ItemHierarchy itemHierarchy )
inlinevirtual
Parameters
kindIdentifies the Kind we are looking for
itemHierarchyUsed to specify that the returned Item should ONLY contain children that are from the defined ItemHierarchy.
Returns
◆ GetItemsByKindSorted() [1/2]
List< Item > VideoOS.Platform.Configuration.GetItemsByKindSorted ( Guid kind)
inline
Returns
◆ GetItemsByKindSorted() [2/2]
List< Item > VideoOS.Platform.Configuration.GetItemsByKindSorted ( Guid kind,
inline
Returns
◆ GetItemsBySearch()
virtual List< Item > VideoOS.Platform.Configuration.GetItemsBySearch ( String searchText,
int maxCount,
int maxSeconds,
out SearchResult searchResult )
inlinevirtual
Parameters
searchTextA phrase to search for
maxCountOnly return of the total count is less then this number
maxSecondsMax seconds to process this request
searchResultExplains the reason for the result, e.g. timeout or a list of relevant Items
◆ GetItemsBySearchAsync()
virtual void VideoOS.Platform.Configuration.GetItemsBySearchAsync ( String searchText,
int maxCount,
int maxSeconds,
Control control,
inlinevirtual
Parameters
asyncItemsHandlerThe method to get the result
controlThe Control the method is executed on
callerReferenceSome call relevant class
◆ GetItemsSorted() [1/2]
List< Item > VideoOS.Platform.Configuration.GetItemsSorted ( )
inline
Returns
◆ GetItemsSorted() [2/2]
List< Item > VideoOS.Platform.Configuration.GetItemsSorted ( ItemHierarchy itemHierarchy)
inline
Returns
◆ GetOptionsConfiguration()
virtual XmlNode VideoOS.Platform.Configuration.GetOptionsConfiguration ( Guid optionsDialogId,
bool userPrivate )
inlinevirtual
Parameters
optionsDialogId
userPrivate
Returns
◆ GetRegisteredServiceUriInfo() [1/2]
virtual List< Configuration.ServiceURIInfo > VideoOS.Platform.Configuration.GetRegisteredServiceUriInfo ( Guid serviceType,
ServerId serverId )
inlinevirtual
Parameters
serviceType
serverIdIdentifies the server to be contacted
Returns
Exceptions
CommunicationMIPExceptionWhen unable to contact the registration service
◆ GetRegisteredServiceUriInfo() [2/2]
virtual List< Configuration.ServiceURIInfo > VideoOS.Platform.Configuration.GetRegisteredServiceUriInfo ( ServerId serverId)
inlinevirtual
Parameters
Returns
Exceptions
◆ GetViewGroup()
virtual Client.ViewGroup VideoOS.Platform.Configuration.GetViewGroup ( Guid groupId)
inlinevirtual
Parameters
groupId
Returns
◆ GetViewGroups()
virtual ReadOnlyCollection< ViewGroupInfo > VideoOS.Platform.Configuration.GetViewGroups ( )
inlinevirtual
Returns
◆ RefreshConfiguration() [1/2]
virtual void VideoOS.Platform.Configuration.RefreshConfiguration ( Guid kind)
inlinevirtual
Only works for plug-in defined configurations. Configuration for build-in item types is controlled by the environment and cannot be refreshed.
Parameters
kindKind of items to flush
◆ RefreshConfiguration() [2/2]
virtual void VideoOS.Platform.Configuration.RefreshConfiguration ( ServerId serverId,
Guid kind )
inlinevirtual
Parameters
serverIdServer ID of items to flush
◆ RegisterServiceUri() [1/2]
virtual void VideoOS.Platform.Configuration.RegisterServiceUri ( Guid serviceType,
ServerId serverId,
Guid instance,
Uri uri,
String name,
string description,
string customData )
inlinevirtual
Parameters
serviceType
serverId
instance
uri
name
description
customData
Exceptions
◆ RegisterServiceUri() [2/2]
ServerId serverId,
Guid instance,
Uri uri,
String name,
string description,
string customData,
List< RegistrationServiceEndpoint > endpoints )
inlinevirtual
Parameters
serviceType
serverId
instance
uri
name
description
customData
endpoints
Exceptions
◆ SaveAssociatedProperties()
virtual void VideoOS.Platform.Configuration.SaveAssociatedProperties ( VideoOS.Platform.Admin.AssociatedProperties associatedProperties)
inlinevirtual
Parameters
◆ SaveItemConfiguration() [1/2]
virtual void VideoOS.Platform.Configuration.SaveItemConfiguration ( Guid pluginDefinitionId,
Item item )
inlinevirtual
Also, be aware that the term "FQID" is reserved and must not be used as the name of a property nor as the beginning of a name of a property.
Cannot be used in Smart Client offline mode (Smart Client Player).
Parameters
itemThe Item to save
◆ SaveItemConfiguration() [2/2]
virtual void VideoOS.Platform.Configuration.SaveItemConfiguration ( ServerId serverId,
Item item )
inlinevirtual
Parameters
◆ SaveOptionsConfiguration()
virtual void VideoOS.Platform.Configuration.SaveOptionsConfiguration ( Guid optionsDialogId,
bool userPrivate,
XmlNode xmlNode )
inlinevirtual
Supported in Management Client, Smart Client and standalone environment, but not Event Server.
Parameters
optionsDialogId
userPrivate
xmlNodeA single XML Node (potentially with children) encapsulating the data to be saved. Must not be a full XmlDocument.
◆ UnRegisterServiceUri()
virtual void VideoOS.Platform.Configuration.UnRegisterServiceUri ( ServerId serverId,
Guid instance )
inlinevirtual
Parameters
serverId
instance
Exceptions
Member Data Documentation
◆ LogServiceId
readonly Guid VideoOS.Platform.Configuration.LogServiceId = new Guid("3D6F1153-92AD-43F1-B467-9482FFD291B2")
static
◆ LogServiceType
readonly Guid VideoOS.Platform.Configuration.LogServiceType = new Guid("3D6F1153-92AD-43F1-B467-9482FFD291B2")
static
◆ MAPServiceId
readonly Guid VideoOS.Platform.Configuration.MAPServiceId = new Guid("08AB8F23-9AEF-4298-9CAA-F39259FE7CDA")
static
◆ MAPServiceType
readonly Guid VideoOS.Platform.Configuration.MAPServiceType = new Guid("08AB8F23-9AEF-4298-9CAA-F39259FE7CDA")
static
◆ TraceItemConfigurationCache
bool VideoOS.Platform.Configuration.TraceItemConfigurationCache
static
Property Documentation
◆ ConfigurationApiManager
ConfigurationApiManager VideoOS.Platform.Configuration.ConfigurationApiManager = new ConfigurationApiManager()
get
◆ Instance
Configuration VideoOS.Platform.Configuration.Instance
staticgetset
◆ IsMIPItemSupported
bool VideoOS.Platform.Configuration.IsMIPItemSupported
getset
◆ ServerFQID
FQID VideoOS.Platform.Configuration.ServerFQID
getabstract
◆ ServerName
String VideoOS.Platform.Configuration.ServerName
getabstract
