| class | Group |
| | Contains constants defining the different type of logs. More...
| class | LogClient |
| | This class is used for storing log messages in the server side logs. More...
| class | LogMessage |
| | Contains one log message. More...
| class | LogMessageDictionary |
| | Represent a set of log messages that a MIP plugin would like to define in the log system. Used when using the LogClient to register messages for later use. More...
| class | PermissionState |
| | Used when performing audit logging - specify result of an permission check. More...
| class | Severity |
| | Contains constants definining the severity levels available. More...
| class | Status |
| | Contains constants defining if a message also should be considered to change a state. More...
