VideoOS.Platform.ConfigItem Class Reference
An overloaded class of the Item class.
Can be subclassed when you want new MIP Items and modifications to existing MIP Items reflect into the mother environments settings. Used by the Smart Client when creating and modifying Views, layouts and view groups in the smart client.
Used by the Administrators to create, modify and delete generic events. Only supported for e-code family! For c-code use Configuration API instead. More...
Inheritance diagram for VideoOS.Platform.ConfigItem:
VideoOS.Platform.Item VideoOS.Platform.Client.ViewAndLayoutItem VideoOS.Platform.GenericEventConfigItem
Public Member Functions
virtual ConfigItem AddChild (ConfigItem item)
 Add a new child to this Item. The child's Kind must be correct, and the parentId set to this item's ObjectId.
virtual ConfigItem AddChild (FQID fqid, String name)
virtual Item AddChild (Item item)
virtual ConfigItem AddChild (String name, Guid kind, FolderType folderType)
virtual void AddRangeChild (ICollection< ConfigItem > items)
 Add a list of children to this Item. The children's Kind must be correct, and the parentId set to this item's ObjectId.
virtual void AddRangeChild (ICollection< Item > items)
 ConfigItem ()
 Used internally in the Smart Client.
 ConfigItem (FQID fqid, String name)
 ConfigItem (ServerId serverId, String name)
 ConfigItem (ServerId serverId, String name, FolderType folderType, Guid kind)
override List< Item > GetChildren ()
 Get the children of this item. The Kind of item returned may be of different Kind.
virtual void PropertiesModified ()
 This method is used in the Smart Client to notify to the Smart Client that ViewLayouts and Views have changed and should be saved on the server.
In standalone MIP environment, this is called when a preset name or position needs to change. (Current position of the camera is stored in the preset).
virtual void RemoveChild (Item childItem)
 Remove a child from this item.
- Public Member Functions inherited from VideoOS.Platform.Item
virtual bool Contains (String searchString)
 Looks through all fields for a match.
virtual void GetChildrenAsync (AsyncItemsHandler asyncItemsHandler, Control control, object callerReference)
 Initiates a call to retrieve all Children for the item. The AsyncItemHandler will be called with the result.
virtual List< Item > GetChildrenSorted ()
 Same as GetChildren, just sorted by name.
virtual DataSource GetDataSource ()
 Get the DataSource relevant for this Item type.
If no DataSource is available for this Item, a null value is returned.
This can for instance be used for retrieving Sequence information for a Camera Item.
virtual Item GetParent ()
 Get the parent Item to this Item This implementation will build the FQID from the current ServerId and set objectId = ParentId, and assume other fields are the same (FolderType, Kind). If not found it will try with Kind = Kind.Server.
virtual List< Item > GetRelated ()
 Return a list of Related Items for this Item.
Could e.g. be Audio devices to a Camera.
virtual void GetRelatedAsync (AsyncItemsHandler asyncItemsHandler, Control control, object callerReference)
 Initiates a call to retrieve all Related items for the item.
virtual Image IconWithOverlay ()
 Take item's icon (if available) and place a 'disable' red cross over - if item is disabled.
virtual Image IconWithOverlay (bool attention, bool active)
 Construct an icon with overlay.
 Item ()
 Create a new Item. The FQID needs to be set afterwards.
 Create a new Item including FQID and the items Name. Other properties can be set afterwards.
 Item (MIPItem mipItem)
 Construct an Item from the MIPItem retrieved via the Configuration API.
 Item (ServerId serverId, Guid parentId, Guid objectId, String name, FolderType folderType, Guid kind)
 Create a new Item. A FQID is created from the provided fields. No further fields needs to be filled to have a valid Item and FQID.
 Item (ServerId serverId, Guid parentId, String objectIdString, String name, FolderType folderType, Guid kind)
 Create a new Item, a FQID containing the ServerId is created.
Important: You will need to fill the FQIDs parentId, ObjectId or ObjectString and Kind afterwards.
 Create a new Item. A FQID is created from the provided fields. Important: You will need to fill the FQIDs ObjectId or ObjectIdString afterwards to have a valid FQID.
String Serialize ()
 Serialize the content of the Item, that is independent of Environment and User.
Note: Overloaded properties, UserContext and Authentication will not be saved.
void Serialize (XmlWriter xmlWriter)
virtual void SetChildren (List< Item > children)
 This method can be used when the base Item class is used, and it contains children. This method will NOT add the children to any servers or configuration, but is merely to simplify instantiation. The children set in this method could be retrieved by the GetChildren method. You should only use this way of implementing an Item, if the number of children is limited.
override String ToString ()
 Returns the name of the item. Can be used for adding the Item directly on ListBox's and other user controls.
Additional Inherited Members
- Static Public Member Functions inherited from VideoOS.Platform.Item
static Item Deserialize (String serializedItem)
 De-serializes a string as generated by the Serialize method.
Note: UserContext and Authorization properties are not filled.
- Protected Attributes inherited from VideoOS.Platform.Item
HasChildren _anyChildren = HasChildren.Maybe
List< Item > _children = new List<Item>()
HasRelated _hasRelated = HasRelated.Maybe
List< Item > _related = new List<Item>()
- Package Attributes inherited from VideoOS.Platform.Item
- Properties inherited from VideoOS.Platform.Item
virtual Dictionary< String, String > Authorization [get]
 Returns a set of strings identifying what the current user is authorized to do.
virtual Collection< MapAlarmContextMenu > ContextMenu [get, set]
 Defines a list of ContextMenu items relevant for this item. It is displayed when a user right click on a Map containing this item.
virtual bool Enabled [get, set]
 Interpret the properties dictionary for "Enabled" and "Disabled" keys. If no entry is found, default is enabled. Otherwise values of "Yes"/"No" and "True" / "False" are checked for each.
virtual bool Encrypt [get, set]
 Identify if the properties of the item should be stored encrypted on the server.
virtual FQID FQID [get, set]
 The Fully Qualified ID of this Item.
virtual HasChildren HasChildren [get, set]
 Inform if this Item contains children. If the property is no, then no children should be available. If the property is yes, there will normally be children, but it is not a requirement. This property is used to improve the UI when displaying TreeView controls to avoid the (+) plus sing for expanding items, that does not have any children.
virtual HasRelated HasRelated [get, set]
virtual Image Icon [get, set]
 Icon used for ViewAndLayout items in the Smart Client.
The Icon represent a given layout.
virtual Guid MapIconKey [get, set]
 Identified what Icon to display on the Map.
A value of Guid.Empty or this Items Kind will use the default MapIcon on the ItemNode.
Otherwise the value is the key into the MapIconDictionary on the ItemNode class.
Please note that MIP items on Map supports dynamic change but MIP Items on Smart Map do not.
virtual String Name [get, set]
 The Display Name of this Item.
virtual PositioningInformation PositioningInformation [get, set]
 Will retrieve the gis location and other positioning information for this Item.
virtual Dictionary< String, String > Properties [get]
 Returns a set of selected properties for the Item. Can also return null, if implementation has no relevant properties for this type of Item.
For built-in items, the available properties depends on the Kind of item, where it is accessed (e.g. Management Client/Application or Smart Client/Standalone).
A item containing a Camera, Recorder or a Server contains the most properties.
Detailed Description
Constructor & Destructor Documentation
◆ ConfigItem() [1/4]
VideoOS.Platform.ConfigItem.ConfigItem ( )
inline
◆ ConfigItem() [2/4]
VideoOS.Platform.ConfigItem.ConfigItem ( FQID fqid,
String name )
inline
◆ ConfigItem() [3/4]
VideoOS.Platform.ConfigItem.ConfigItem ( ServerId serverId,
String name )
inline
◆ ConfigItem() [4/4]
String name,
Guid kind )
inline
Member Function Documentation
◆ AddChild() [1/4]
virtual ConfigItem VideoOS.Platform.ConfigItem.AddChild ( ConfigItem item)
inlinevirtual
Parameters
item
Returns
◆ AddChild() [2/4]
virtual ConfigItem VideoOS.Platform.ConfigItem.AddChild ( FQID fqid,
String name )
inlinevirtual
Parameters
fqid
name
Returns
◆ AddChild() [3/4]
virtual Item VideoOS.Platform.ConfigItem.AddChild ( Item item)
inlinevirtual
Parameters
item
Returns
◆ AddChild() [4/4]
virtual ConfigItem VideoOS.Platform.ConfigItem.AddChild ( String name,
Guid kind,
FolderType folderType )
inlinevirtual
Parameters
name
kind
folderType
Returns
◆ AddRangeChild() [1/2]
virtual void VideoOS.Platform.ConfigItem.AddRangeChild ( ICollection< ConfigItem > items)
inlinevirtual
Parameters
items
Returns
◆ AddRangeChild() [2/2]
virtual void VideoOS.Platform.ConfigItem.AddRangeChild ( ICollection< Item > items)
inlinevirtual
Parameters
items
Returns
◆ GetChildren()
override List< Item > VideoOS.Platform.ConfigItem.GetChildren ( )
inlinevirtual
Returns
Reimplemented from VideoOS.Platform.Item.
◆ PropertiesModified()
virtual void VideoOS.Platform.ConfigItem.PropertiesModified ( )
inlinevirtual
◆ RemoveChild()
virtual void VideoOS.Platform.ConfigItem.RemoveChild ( Item childItem)
inlinevirtual
Parameters
childItem
