VideoOS.Platform.ClientControl Class Reference
The class to access Client relevant methods. More...
Public Member Functions
virtual void CallOnUiThread (Action actionToBeInvoked)
 Use this method to ensure the action is executed on the UI thread.
The method will first check if it is already executing on the UI thread and if not invoke the call.
virtual void Close ()
 Reserved for internal use.
virtual Item CreateTemporaryGroupItem (String name)
 Create a new Temporary View Group on top level in the Tree structure.
The returned GroupItem will exists as long as the Smart Client is logged in to a server.
The created item will be visible to the operator, unless the following property is set:
groupItem.Properties["Visible"] = "False";
The returned GroupItem is an instance of a ConfigItem and support the AddChild and RemoveChild methods for managing ViewGroups on the next level. This method is used within the smart client.
virtual void DeleteTemporaryGroupItem (Item groupItem)
 This method will delete a previously created GroupItem through the CreateTemporaryGroupItem method.
virtual AdminImageViewerControl GenerateAdminImageViewerControl ()
 Creates a new instance of a AdminImageViewerControl.
virtual AudioPlayerControl GenerateAudioPlayerControl ()
 This method is deprecated. Windows Forms controls are no longer supported. Use AudioPlayer instead. Creates a new instance of a AudioPlayerControl. This method is used for standalone application and Smart Client plugins.
Upon return the generated audio player need to be added to a UserControl.Control collection.
virtual AudioPlayerControl GenerateAudioPlayerControl (WindowInformation windowInformation)
This method is used for Smart Client plugins.
The WindowInformation class should be passed on from the ViewItemUserControl that this control will be added to.
The main effect of adding the WindowInformation is that the AudioPlayer will run in live and playback mode just like the Smart Client usually do, e.g. flowing windows have different mode then the main window.
virtual ImageViewerControl GenerateImageViewerControl ()
 This method is deprecated. Windows Forms controls are no longer supported. Use ImageViewerWpfControl instead. Creates a new instance of ImageViewerControl. This method is used within Smart Client and standalone plug-ins.
virtual ImageViewerControl GenerateImageViewerControl (WindowInformation windowInformation)
This method is used within Smart Client.
The main effect of adding the WindowInformation is that the ImageViewer will run in live and playback mode just like the Smart Client usually do, e.g. floating windows have different mode then the main window.
virtual IAudioRecorder GeneratePcAudioRecorder ()
 Generate a AudioRecorder instance that pick up audio from the PCs microphone.
virtual FQID GeneratePlaybackController ()
 This method can be called when a standalone application would like to have multiple PlaybackControllers active at the same time.
One default PlaybackController is build-in and addressed by sending messages with receive FQID = null.
Each PlaybackController is addressed by sending messages to it with the receiver FQID equal to the return value of this method.
Each of the ImageViewerControl's have one (and only one) PlaybackController that controls it. The default is the build-in BrowserController, but can be changed by setting the ImageViewerControl.PlaybackControllerFQID = result from this method.
virtual PlaybackUserControl GeneratePlaybackUserControl ()
 This method is deprecated. Windows Forms controls are no longer supported. Use PlaybackWpfUserControl instead and use PlaybackWpfUserControl.ShowTallUserControl to control the size. Generates a new instance of a PlaybackUserControl.
virtual PlaybackUserControl GeneratePlaybackUserControl (WindowInformation windowInformation)
This is intended to work together with one or more ImageViewerControl(s) and a PlaybackController (In Smart Client or for standalone application in the MIPSDK .Net Library).
virtual VideoControl GenerateVideoControl ()
 Generates an instance of the VideoControl class.
virtual ViewControl GenerateViewControl (List< ViewControlItem > items, List< Rectangle > viewLayout)
 Generates an instance of the ViewControl class.
virtual ViewControl GenerateViewControl (List< ViewControlItem > items, List< Rectangle > viewLayout, WindowInformation windowInformation)
virtual PlaybackController GetPlaybackController (FQID fqid)
 This method will lookup the actual class handling the playback. Notice that not all methods are available for all Environments.
virtual FQID GetPlaybackController (WindowInformation windowInformation)
 Get the default playback controller for a given window within the Smart Client.
Please note that the FQID of the playback controller for the Smart Client main window is null.
The ViewItemUserControl base class contains the WindowInformation to use as parameter.
virtual SmartClientProfileSetting GetSmartClientProfileSetting (int smartClientProfileSettingKey)
 Gets the SmartClientProfileSetting for the provided key.
virtual List< Item > GetSmartWallItems ()
 Get top list of all video wall view groups for this user.
This method is used within the Smart Client.
virtual List< Item > GetViewGroupItems ()
 Get top list of all accessible view groups for this user. Usually this will return a private group and one or more public groups. This method is used within the Smart Client.
virtual WindowState GetWindowState (FQID window)
 Gets the state of the provided window FQID.
virtual List< Item > GetWorkSpaceItems ()
 Gets a list of all available work spaces.
These items can be used for selecting the active workspace via this class or via messages.
virtual void Init ()
delegate void NewImageViewerControlHandler (ImageViewerAddOn imageViewerAddOn)
virtual void Print (Bitmap bitmap, String name, String extraInformation)
 This method is deprecated. Windows Forms controls are no longer supported. Use Print(ImageSource, String, String) instead. Open a print dialog where user can enter a notes and issue preview and print.
virtual void Print (Bitmap bitmap, String name, String extraInformation, string cameraName)
 This method is deprecated. Windows Forms controls are no longer supported. Use Print(ImageSource, String, String, string) instead. Open a print dialog where user can enter a notes and issue preview and print.
virtual void Print (ImageSource imageSource, string name, string extraInformation)
 Open a print dialog where user can enter a note and issue preview and print.
virtual void Print (ImageSource imageSource, string name, string extraInformation, string cameraName)
virtual void RaiseKeyDownEvent (KeyEventArgs e)
 This method is deprecated. Windows Forms controls are no longer supported. For pure WPF plugins a method like this is not needed. Raise key down events in the Smart Client.
Use this method to pass key down events received in ElementHost hosted WPF controls in the plugin. For pure Winforms plugins it should not be necessary to call this method.
virtual void RegisterUIControlForAutoTheming (FrameworkElement uiControl)
 Register the provided UI control for auto theming. The SC theme will automatically be applied to registered controls. The theme is applied to the registered control and all child controls automatically. Current accepted control is System.Windows.FrameworkElement (WPF).
All side panels, property panels and option configuration panels are automatically being themed according to the Theme definition. This method should be used for the main part of the ViewItem and any pop Forms you may have.
virtual void RegisterUIControlForAutoTheming (object uiControl)
 This method is deprecated. Windows Forms controls are no longer supported. Use RegisterUIControlForAutoTheming(FrameworkElement) instead. Register the provided UI control for auto theming. The SC theme will automatically be applied to registered controls. The theme is applied to the registered control and all child controls automatically. Current accepted controls are System.Windows.Forms.Control (Windows Forms) and System.Windows.Controls.Control (WPF).
All side panels, property panels and option configuration panels are automatically being themed accordingly to the Theme definition. This method should be used for the main part of the ViewItem and any pop Forms you may have.
virtual void ReleasePlaybackController (FQID fqid)
 This method will dispose of a PlaybackController previous created from the GeneratePlaybackController() method.
virtual void ShowHelp (Control control, int id)
 This method is deprecated. Windows Forms controls are no longer supported. Use ShowHelp(int) instead. Reserved for internal use.
virtual void ShowHelp (int topicId)
 Opens the help at the given topic id.
Help language is automatically resolved.
virtual void UnInitialize ()
 Call this to uninitialize the ClientControl.
Static Public Attributes
static Guid AccessControlBuildInWorkSpaceId = new Guid("CE411EB1-3593-4681-A3E1-1BA2D1A761B8")
 Guid defining the object id of the build in access control workspace item.
static Guid AlarmManagementBuildInWorkSpaceId = new Guid("5A77E227-1A5E-4D7B-B345-46A7BB993037")
 Guid defining the object id of the build in alarm management workspace item.
static string EmbeddedCameraFQIDProperty = "EmbeddedCameraFQID"
 Name of property that allows a MIP view item to specify which embedded camera it contains. Setting this property will ensure that the embedded camera is added to the timeline and can be exported.
static Guid ExportBuildInWorkSpaceId = new Guid("7DB87263-F9AB-426D-B641-91D9E4BD7B86")
 Guid defining the object id of the build in export workspace item.
static readonly string ExportTimeIntervals = "ExportTimeIntervals"
 Name of property describing the time intervals for the export of an item instance.
static Guid LiveBuildInWorkSpaceId = new Guid("B8C936BF-815D-4D5D-BAAF-1CEAFC7428C0")
 Guid defining the object id of the build in live workspace item.
static Guid PlaybackBuildInWorkSpaceId = new Guid("DA486915-863C-4ECE-B301-5FC7FD80A2B0")
 Guid defining the object id of the build in playback workspace item.
static Guid SequenceExplorerBuildInWorkSpaceId = new Guid("955323C5-2ECC-48CE-93A9-3CF1835A4A23")
 Guid defining the object id of the build in sequence explorer workspace item.
static Guid SystemMonitorBuildInWorkSpaceId = new Guid("FFFA9495-2D44-4183-97CB-550837441294")
 Guid defining the object id of the build in system monitor workspace item.
static Guid TransactBuildInWorkSpaceId = new Guid("952F54A2-08EE-44F7-B010-86DCA20BA2B2")
 Guid defining the object id of the build in transact workspace item.
Protected Member Functions
 ClientControl ()
virtual void FireSignalKeyDownEvent (Keys keys)
 This method is deprecated. Windows Forms controls are no longer supported. For pure WPF plugins a method like this is not needed. Do not use this method. Use RaiseKeyDownEvent instead.
void RaiseFlowDirectionChanged ()
 Raises the FlowDirectionChanged event.
void RegisterReceivers ()
Protected Attributes
PlaybackControllerBase PlaybackControllerBase
 Used internally.
Properties
virtual System.Windows.FlowDirection FlowDirection = CultureInfo.CurrentCulture.TextInfo.IsRightToLeft ? System.Windows.FlowDirection.RightToLeft : System.Windows.FlowDirection.LeftToRight [get]
 Gets the flow direction currently in use.
virtual bool Initialized [get]
 Indicates if the ClientControl specific instance has been created for the executing Environment.
When executing in the Smart Client, this is always initiated by the Smart Client, when executing as a standalone application, you can choose to call the VideoOS.Platform.SDK.UI.Environment.Initialize() method yourself, or let the MIPSDK do this automatically (New in MIP SDK v3).
static ClientControl Instance [get, set]
 This Singleton item of this class. Only use the 'get' access method.
virtual TimeZoneInfo SelectedTimeZoneInfo [get, set]
 This field indicates what timezone the user has selected to work in.
This will by default be the local timezone for the PC, but can be changed to another zone by the user.
The effect is that all UI components should display date/time information in this selected TimeZone.
Setting this field is not recommended, as the value will not be persisted.
virtual Item ShownWorkSpace [get, set]
 Gets or sets the current shown Smart Client work space.
virtual Theme Theme [get]
 Return the currently select Theme details.
This class is only useful for Smart Client plugins.
virtual WorkSpaceState WorkSpaceState [get, set]
 Gets or sets the current Smart Client work space state.
The state can be Normal or Setup for the current workspace, what another workspace is selected, the current workspace will go out of Setup, and be returned to Normal work space state.
Events
virtual EventHandler ApplicationCloseEvent
 Subscribe to this event to be notified when the application is about to be shut down.
EventHandler FlowDirectionChanged
 Event raised when the FlowDirection changes.
virtual NewImageViewerControlHandler NewImageViewerControlEvent
 A background plug-in can subscribe to this event to be advised when a new ImageViewerControl has been created. The ImageViewerAddOn class passed as a parameter, can be used for controlling the ImageViewer's mode, and for adding overlay to the originators ImageViewerControl.
This is intended for use by analytics overlay drawings and for retail text overlay.
Detailed Description
Constructor & Destructor Documentation
◆ ClientControl()
VideoOS.Platform.ClientControl.ClientControl ( )
inlineprotected
Member Function Documentation
◆ CallOnUiThread()
virtual void VideoOS.Platform.ClientControl.CallOnUiThread ( Action actionToBeInvoked)
inlinevirtual
The below line will call the MuFillTextBox method on the UI thread.
ClientControl.Instance.CallOnUiThread( () => MyFillTextBox("fill this text") );
private void MyFillTextBox(String s)
_myTextBox.Text = s;
Definition ClientControl.cs:37
Definition ClientControl.cs:105
virtual void CallOnUiThread(Action actionToBeInvoked)
Use this method to ensure the action is executed on the UI thread. The method will first check if it...
Definition ClientControl.cs:545
Parameters
actionToBeInvoked
◆ Close()
virtual void VideoOS.Platform.ClientControl.Close ( )
inlinevirtual
◆ CreateTemporaryGroupItem()
virtual Item VideoOS.Platform.ClientControl.CreateTemporaryGroupItem ( String name)
inlinevirtual
Parameters
nameName of the View Group
Returns
The new ViewGroupItem just created, as a ConfigItem.
◆ DeleteTemporaryGroupItem()
virtual void VideoOS.Platform.ClientControl.DeleteTemporaryGroupItem ( Item groupItem)
inlinevirtual
Parameters
groupItemThe GroupItem returned by the CreateTemporaryGroupItem
◆ FireSignalKeyDownEvent()
virtual void VideoOS.Platform.ClientControl.FireSignalKeyDownEvent ( Keys keys)
inlineprotectedvirtual
◆ GenerateAdminImageViewerControl()
virtual AdminImageViewerControl VideoOS.Platform.ClientControl.GenerateAdminImageViewerControl ( )
inlinevirtual
This method is used within XProtect Management Client application.
Returns
◆ GenerateAudioPlayerControl() [1/2]
virtual AudioPlayerControl VideoOS.Platform.ClientControl.GenerateAudioPlayerControl ( )
inlinevirtual
Returns
The new AudioPlayerControl
◆ GenerateAudioPlayerControl() [2/2]
virtual AudioPlayerControl VideoOS.Platform.ClientControl.GenerateAudioPlayerControl ( WindowInformation windowInformation)
inlinevirtual
Returns
◆ GenerateImageViewerControl() [1/2]
virtual ImageViewerControl VideoOS.Platform.ClientControl.GenerateImageViewerControl ( )
inlinevirtual
Exceptions
System.IO.FileNotFoundExceptionIs thrown when one of the dependencies is not found.
Returns
The new ImageViewerControl
◆ GenerateImageViewerControl() [2/2]
virtual ImageViewerControl VideoOS.Platform.ClientControl.GenerateImageViewerControl ( WindowInformation windowInformation)
inlinevirtual
Returns
◆ GeneratePcAudioRecorder()
virtual IAudioRecorder VideoOS.Platform.ClientControl.GeneratePcAudioRecorder ( )
inlinevirtual
Returns
◆ GeneratePlaybackController()
virtual FQID VideoOS.Platform.ClientControl.GeneratePlaybackController ( )
inlinevirtual
Returns
◆ GeneratePlaybackUserControl() [1/2]
virtual PlaybackUserControl VideoOS.Platform.ClientControl.GeneratePlaybackUserControl ( )
inlinevirtual
This works together with one or more ImageViewerControl(s) and one PlaybackController. For standalone applications, you can use the PlaybackController controller and control it via your own user interface, and issue Message's to have it navigate.
This method only works within Smart Client.
Returns
◆ GeneratePlaybackUserControl() [2/2]
virtual PlaybackUserControl VideoOS.Platform.ClientControl.GeneratePlaybackUserControl ( WindowInformation windowInformation)
inlinevirtual
Parameters
windowInformationIdentifies that the returned UserControl will be placed on the window identified by the WindowInformation.
Returns
◆ GenerateVideoControl()
virtual VideoControl VideoOS.Platform.ClientControl.GenerateVideoControl ( )
inlinevirtual
Only for use in Smart Client plugins.
Returns
The new VideoControl
◆ GenerateViewControl() [1/2]
virtual ViewControl VideoOS.Platform.ClientControl.GenerateViewControl ( List< ViewControlItem > items,
List< Rectangle > viewLayout )
inlinevirtual
Parameters
itemsThe view control items to show in the view layout
viewLayoutThe layout to use
Returns
The new ViewControl
◆ GenerateViewControl() [2/2]
WindowInformation windowInformation )
inlinevirtual
Parameters
windowInformationThe window to show the view on
Returns
The new ViewControl
◆ GetPlaybackController() [1/2]
virtual PlaybackController VideoOS.Platform.ClientControl.GetPlaybackController ( FQID fqid)
inlinevirtual
Parameters
fqid
Returns
◆ GetPlaybackController() [2/2]
virtual FQID VideoOS.Platform.ClientControl.GetPlaybackController ( WindowInformation windowInformation)
inlinevirtual
Parameters
windowInformation
Returns
◆ GetSmartClientProfileSetting()
virtual SmartClientProfileSetting VideoOS.Platform.ClientControl.GetSmartClientProfileSetting ( int smartClientProfileSettingKey)
inlinevirtual
Only supported in Smart Client.
Parameters
smartClientProfileSettingKeyKey identifying which SmartClientProfileSetting to fetch.
Returns
SmartClientProfileSetting instance associated with the provided key, or null if it does not exist.
◆ GetSmartWallItems()
virtual List< Item > VideoOS.Platform.ClientControl.GetSmartWallItems ( )
inlinevirtual
Returns
◆ GetViewGroupItems()
virtual List< Item > VideoOS.Platform.ClientControl.GetViewGroupItems ( )
inlinevirtual
Returns
◆ GetWindowState()
virtual WindowState VideoOS.Platform.ClientControl.GetWindowState ( FQID window)
inlinevirtual
Parameters
windowThe window FQID to fetch the current state of.
Returns
WindowState of the provided window.
Exceptions
MIPExceptionThrown if the method is not supported in the environment from where it is called.
◆ GetWorkSpaceItems()
virtual List< Item > VideoOS.Platform.ClientControl.GetWorkSpaceItems ( )
inlinevirtual
Returns
◆ Init()
virtual void VideoOS.Platform.ClientControl.Init ( )
inlinevirtual
◆ NewImageViewerControlHandler()
delegate void VideoOS.Platform.ClientControl.NewImageViewerControlHandler ( ImageViewerAddOn imageViewerAddOn)
Parameters
imageViewerAddOn
◆ Print() [1/4]
virtual void VideoOS.Platform.ClientControl.Print ( Bitmap bitmap,
String name,
String extraInformation )
inlinevirtual
Parameters
bitmapA bitmap to be placed at the top of the report.
nameName of the report
extraInformationMultiple lines of text can be provided
◆ Print() [2/4]
String name,
string cameraName )
inlinevirtual
Parameters
cameraNameThe name to display for the label 'camera'
◆ Print() [3/4]
virtual void VideoOS.Platform.ClientControl.Print ( ImageSource imageSource,
string name,
string extraInformation )
inlinevirtual
Parameters
imageSourceAn image to be placed at the top of the report.
◆ Print() [4/4]
string name,
string cameraName )
inlinevirtual
Parameters
◆ RaiseFlowDirectionChanged()
void VideoOS.Platform.ClientControl.RaiseFlowDirectionChanged ( )
inlineprotected
◆ RaiseKeyDownEvent()
virtual void VideoOS.Platform.ClientControl.RaiseKeyDownEvent ( KeyEventArgs e)
inlinevirtual
Parameters
eThe winform event args
◆ RegisterReceivers()
void VideoOS.Platform.ClientControl.RegisterReceivers ( )
inlineprotected
◆ RegisterUIControlForAutoTheming() [1/2]
virtual void VideoOS.Platform.ClientControl.RegisterUIControlForAutoTheming ( FrameworkElement uiControl)
inlinevirtual
Parameters
uiControlThe UI control to register
◆ RegisterUIControlForAutoTheming() [2/2]
virtual void VideoOS.Platform.ClientControl.RegisterUIControlForAutoTheming ( object uiControl)
inlinevirtual
Parameters
◆ ReleasePlaybackController()
virtual void VideoOS.Platform.ClientControl.ReleasePlaybackController ( FQID fqid)
inlinevirtual
Parameters
fqid
◆ ShowHelp() [1/2]
virtual void VideoOS.Platform.ClientControl.ShowHelp ( Control control,
int id )
inlinevirtual
Parameters
control
id
◆ ShowHelp() [2/2]
virtual void VideoOS.Platform.ClientControl.ShowHelp ( int topicId)
inlinevirtual
Parameters
topicIdThe id of the help topic.
◆ UnInitialize()
virtual void VideoOS.Platform.ClientControl.UnInitialize ( )
inlinevirtual
Member Data Documentation
◆ AccessControlBuildInWorkSpaceId
Guid VideoOS.Platform.ClientControl.AccessControlBuildInWorkSpaceId = new Guid("CE411EB1-3593-4681-A3E1-1BA2D1A761B8")
static
◆ AlarmManagementBuildInWorkSpaceId
Guid VideoOS.Platform.ClientControl.AlarmManagementBuildInWorkSpaceId = new Guid("5A77E227-1A5E-4D7B-B345-46A7BB993037")
static
◆ EmbeddedCameraFQIDProperty
string VideoOS.Platform.ClientControl.EmbeddedCameraFQIDProperty = "EmbeddedCameraFQID"
static
◆ ExportBuildInWorkSpaceId
Guid VideoOS.Platform.ClientControl.ExportBuildInWorkSpaceId = new Guid("7DB87263-F9AB-426D-B641-91D9E4BD7B86")
static
◆ ExportTimeIntervals
readonly string VideoOS.Platform.ClientControl.ExportTimeIntervals = "ExportTimeIntervals"
static
◆ LiveBuildInWorkSpaceId
Guid VideoOS.Platform.ClientControl.LiveBuildInWorkSpaceId = new Guid("B8C936BF-815D-4D5D-BAAF-1CEAFC7428C0")
static
◆ PlaybackBuildInWorkSpaceId
Guid VideoOS.Platform.ClientControl.PlaybackBuildInWorkSpaceId = new Guid("DA486915-863C-4ECE-B301-5FC7FD80A2B0")
static
◆ PlaybackControllerBase
PlaybackControllerBase VideoOS.Platform.ClientControl.PlaybackControllerBase
protected
Used internally.
◆ SequenceExplorerBuildInWorkSpaceId
Guid VideoOS.Platform.ClientControl.SequenceExplorerBuildInWorkSpaceId = new Guid("955323C5-2ECC-48CE-93A9-3CF1835A4A23")
static
◆ SystemMonitorBuildInWorkSpaceId
Guid VideoOS.Platform.ClientControl.SystemMonitorBuildInWorkSpaceId = new Guid("FFFA9495-2D44-4183-97CB-550837441294")
static
◆ TransactBuildInWorkSpaceId
Guid VideoOS.Platform.ClientControl.TransactBuildInWorkSpaceId = new Guid("952F54A2-08EE-44F7-B010-86DCA20BA2B2")
static
Property Documentation
◆ FlowDirection
virtual System.Windows.FlowDirection VideoOS.Platform.ClientControl.FlowDirection = CultureInfo.CurrentCulture.TextInfo.IsRightToLeft ? System.Windows.FlowDirection.RightToLeft : System.Windows.FlowDirection.LeftToRight
get
◆ Initialized
virtual bool VideoOS.Platform.ClientControl.Initialized
get
◆ Instance
ClientControl VideoOS.Platform.ClientControl.Instance
staticgetset
◆ SelectedTimeZoneInfo
virtual TimeZoneInfo VideoOS.Platform.ClientControl.SelectedTimeZoneInfo
getset
◆ ShownWorkSpace
virtual Item VideoOS.Platform.ClientControl.ShownWorkSpace
getset
◆ Theme
virtual Theme VideoOS.Platform.ClientControl.Theme
get
◆ WorkSpaceState
virtual WorkSpaceState VideoOS.Platform.ClientControl.WorkSpaceState
getset
Event Documentation
◆ ApplicationCloseEvent
virtual EventHandler VideoOS.Platform.ClientControl.ApplicationCloseEvent
Generally it is a better idea to do cleanup in the Close() methods as these will be called whenever the application is no longer logged on to the VMS and thus configuration might no longer be valid, but if you have some cleanup that should only be done when the application is actually shutting down, this is the place to do it.
Only do basic cleanup here. Don't attempt to access any UI or utilize MIP functionality in general here, as a lot of that will already be gone at this point.
The event is only supported in Smart Client and Management Client.
◆ FlowDirectionChanged
EventHandler VideoOS.Platform.ClientControl.FlowDirectionChanged
◆ NewImageViewerControlEvent
virtual NewImageViewerControlHandler VideoOS.Platform.ClientControl.NewImageViewerControlEvent
Note that the content of the ImageViewerAddOn may not be filled when this event is fired, and the receiving class should register on the ImageViewerAddOn's PropertyChangedEvent to keep the receiver in sync with the correct e.g. CameraId and other properties.
