Integrate MIP .NET Library into Your Application
This page contains an overview of the available application solutions when you integrate MIP components into your application. The applications are described from an idea viewpoint, and should help you in identifying the elements to use and the elements you need to develop your solution.
The following table below contains user scenarios to help you find a suitable solution for your plug-in or integration task.
Application
icon Adding Video Content to an Existing Application
icon Alarm and Monitoring System
icon Residential Verification
