Alarm and monitoring system
An existing alarm and monitoring system need to overview and monitor a set of Milestone installations.
Description
The existing system could be focused on an operational system of the Milestone servers and cameras. It could include video content alarms and management of video analytics alarms.
1) Alarm management system
- As an add-on to this system, the Milestone status and central protocols are implemented.
- The red lines indicate that status information is sent from Milestone servers regarding the servers and attached devices (cameras) to the alarm management system.
- Events are also sent in this flow, supporting dry contacts or the result of rule-configured alerts.
2) Milestone servers
- A set of Milestone servers that needs to be monitored. No further development done here.
3) Operator UI
- The operator continues to use well-known UI. Video content management can be added, but may not be required.
