VideoOS.Platform.UI.Util Class Reference
A utility class to collect all Icons used in the system for both plug-ins and for the Environment.
Lookup to an Icon is done via KindToImageIndex, and KindToCategory can be used for the default Category if an Kind. More...
Static Public Member Functions
static Image BuiltInItemToImage (Item item)
 Finetune a few of the Icons used for built-in items, e.g. camera PTZ icon instead of just a camera icon.
static int BuiltInItemToImageIndex (Item item)
static bool IsBuiltInKind (Guid kind)
 Validates if a specific kind is a built-in kind or from a plug-in.
Static Public Attributes
static Bitmap ActiveOverlay = null
 The little green arrow to place on top of other icons.
static int AlertIconIx = 2
 Index into ImageList property. (Consider to use method: BuiltInItemToImageIndex(Item) to get an Icon)
static Bitmap AttentionOverlay = null
 The little exclamation point to place on top of other icons.
static int CameraIconIx = 8
static int CameraPtzIx = 30
static int CustomEventIconIx = 9
static Bitmap DisabledOverlay = null
 The little red cross to place on top of other icons.
static int FirstFreeIx = 33
 Index into ImageList property. Identify size of ImageList.
static int FolderIconIx = 1
static int GisMapLocationIx = 33
 Index of the GisMapLocation icon.
static int GroupIx = 14
static int HardwareIx = 28
static int InputIconIx = 3
static int InterConnectedIx = 29
static int MatrixIconIx = 5
static int MetadataIx = 31
static int MicrophoneIconIx = 11
static int OutputIconIx = 4
static int PluginIx = 19
static int PresetIconIx = 7
static int RecorderIconIx = 12
static int RoleIx = 24
static int SDK_GeneralIx = 21
static int SDK_ToolIx = 22
static int SDK_VSIx = 20
static int ServerIconIx = 0
static int SpeakerIconIx = 10
static int TimeProfileIx = 27
static int TransactIconIx = 6
static int UserIx = 25
static int VideoWallGroupIx = 15
static int VideoWallIx = 16
static int VideoWallPreset = 32
 Index to Video Wall Preset.
static int ViewGroupIx = 13
static int ViewItemIx = 18
static int ViewIx = 17
static int WindowIx = 23
static int WorkSpaceIx = 26
Properties
static ImageList ImageList [get]
 Returns a complete list of all Images for all Kinds.
static ImageList ImageList32 [get]
 Returns a complete list of all Images for all Kinds - in size 32, if available from plugin.
static ImageList ImageListClone [get]
static Dictionary< Guid, CategoryKindToCategory [get]
 Returns a dictionary where the Category of all Kinds can be found.
static Dictionary< Guid, int > KindToImageIndex [get]
 Returns a dictionary where the index of the ImageList is index by kind.
Detailed Description
Member Function Documentation
◆ BuiltInItemToImage()
static Image VideoOS.Platform.UI.Util.BuiltInItemToImage ( Item item)
inlinestatic
Parameters
item
Returns
◆ BuiltInItemToImageIndex()
static int VideoOS.Platform.UI.Util.BuiltInItemToImageIndex ( Item item)
inlinestatic
Parameters
item
Returns
◆ IsBuiltInKind()
static bool VideoOS.Platform.UI.Util.IsBuiltInKind ( Guid kind)
inlinestatic
Parameters
kindThe Kind to check
Returns
True if the Kind is a built-in Kind
Member Data Documentation
◆ ActiveOverlay
Bitmap VideoOS.Platform.UI.Util.ActiveOverlay = null
static
◆ AlertIconIx
int VideoOS.Platform.UI.Util.AlertIconIx = 2
static
◆ AttentionOverlay
Bitmap VideoOS.Platform.UI.Util.AttentionOverlay = null
static
◆ CameraIconIx
int VideoOS.Platform.UI.Util.CameraIconIx = 8
static
◆ CameraPtzIx
int VideoOS.Platform.UI.Util.CameraPtzIx = 30
static
◆ CustomEventIconIx
int VideoOS.Platform.UI.Util.CustomEventIconIx = 9
static
◆ DisabledOverlay
Bitmap VideoOS.Platform.UI.Util.DisabledOverlay = null
static
◆ FirstFreeIx
int VideoOS.Platform.UI.Util.FirstFreeIx = 33
static
◆ FolderIconIx
int VideoOS.Platform.UI.Util.FolderIconIx = 1
static
◆ GisMapLocationIx
int VideoOS.Platform.UI.Util.GisMapLocationIx = 33
static
◆ GroupIx
int VideoOS.Platform.UI.Util.GroupIx = 14
static
◆ HardwareIx
int VideoOS.Platform.UI.Util.HardwareIx = 28
static
◆ InputIconIx
int VideoOS.Platform.UI.Util.InputIconIx = 3
static
◆ InterConnectedIx
int VideoOS.Platform.UI.Util.InterConnectedIx = 29
static
◆ MatrixIconIx
int VideoOS.Platform.UI.Util.MatrixIconIx = 5
static
◆ MetadataIx
int VideoOS.Platform.UI.Util.MetadataIx = 31
static
◆ MicrophoneIconIx
int VideoOS.Platform.UI.Util.MicrophoneIconIx = 11
static
◆ OutputIconIx
int VideoOS.Platform.UI.Util.OutputIconIx = 4
static
◆ PluginIx
int VideoOS.Platform.UI.Util.PluginIx = 19
static
◆ PresetIconIx
int VideoOS.Platform.UI.Util.PresetIconIx = 7
static
◆ RecorderIconIx
int VideoOS.Platform.UI.Util.RecorderIconIx = 12
static
◆ RoleIx
int VideoOS.Platform.UI.Util.RoleIx = 24
static
◆ SDK_GeneralIx
int VideoOS.Platform.UI.Util.SDK_GeneralIx = 21
static
◆ SDK_ToolIx
int VideoOS.Platform.UI.Util.SDK_ToolIx = 22
static
◆ SDK_VSIx
int VideoOS.Platform.UI.Util.SDK_VSIx = 20
static
◆ ServerIconIx
int VideoOS.Platform.UI.Util.ServerIconIx = 0
static
◆ SpeakerIconIx
int VideoOS.Platform.UI.Util.SpeakerIconIx = 10
static
◆ TimeProfileIx
int VideoOS.Platform.UI.Util.TimeProfileIx = 27
static
◆ TransactIconIx
int VideoOS.Platform.UI.Util.TransactIconIx = 6
static
◆ UserIx
int VideoOS.Platform.UI.Util.UserIx = 25
static
◆ VideoWallGroupIx
int VideoOS.Platform.UI.Util.VideoWallGroupIx = 15
static
◆ VideoWallIx
int VideoOS.Platform.UI.Util.VideoWallIx = 16
static
◆ VideoWallPreset
int VideoOS.Platform.UI.Util.VideoWallPreset = 32
static
◆ ViewGroupIx
int VideoOS.Platform.UI.Util.ViewGroupIx = 13
static
◆ ViewItemIx
int VideoOS.Platform.UI.Util.ViewItemIx = 18
static
◆ ViewIx
int VideoOS.Platform.UI.Util.ViewIx = 17
static
◆ WindowIx
int VideoOS.Platform.UI.Util.WindowIx = 23
static
◆ WorkSpaceIx
int VideoOS.Platform.UI.Util.WorkSpaceIx = 26
static
Property Documentation
◆ ImageList
ImageList VideoOS.Platform.UI.Util.ImageList
staticget
◆ ImageList32
ImageList VideoOS.Platform.UI.Util.ImageList32
staticget
◆ ImageListClone
ImageList VideoOS.Platform.UI.Util.ImageListClone
staticget
◆ KindToCategory
Dictionary<Guid, Category> VideoOS.Platform.UI.Util.KindToCategory
staticget
◆ KindToImageIndex
Dictionary<Guid, int> VideoOS.Platform.UI.Util.KindToImageIndex
staticget
