Data class containing all search criteria data (i.e. values of selected SearchFilters) which is to be used in the SearchDefinition it belongs to.
More...
◆ SearchCriteria()
| VideoOS.Platform.Search.SearchCriteria.SearchCriteria |
SearchScope | searchScope | ) |
inline |
Constructor taking the search scope as parameter.
- Parameters
| searchScope | The search scope associated with the search criteria. |
◆ AddFilterValue() [1/2]
| void VideoOS.Platform.Search.SearchCriteria.AddFilterValue |
SearchFilter | searchFilter | ) |
inline |
Adds a filter value for the given search filter by invoking SearchFilter.CreateValue.
- Parameters
| searchFilter | The search filter for which to add a search filter value. |
◆ AddFilterValue() [2/2]
Adds a filter value for the given search filter./>.
- Parameters
| filterValue | The filter value to add. |
◆ ClearFilterValues()
| void VideoOS.Platform.Search.SearchCriteria.ClearFilterValues |
inline |
Clears all search filter values for the provided search filter.
- Parameters
| searchFilter | The search filter for which to clear all values. |
◆ GetFilterValues() [1/2]
Gets the value(s) of the given filter. Use this when invoking your search to obtain the filter values setup by the user.
- Parameters
| searchFilter | The filter to get the value(s) for. |
- Returns
- The value(s) of the given search filter.
◆ GetFilterValues() [2/2]
| ReadOnlyCollection< FilterValueBase > VideoOS.Platform.Search.SearchCriteria.GetFilterValues |
SearchFilter | searchFilter, |
bool | removeEmptyValues ) |
inline |
Gets the value(s) of the given filter. This overload provides an option to keep/remove empty values. This is needed by the UI to be able to show a filter value even though it is "empty".
NOTE: You should not call this method from your search agent, this is a method intended for a UI application.
- Parameters
| removeEmptyValues | Specifies whether to include/exclude empty values in the result. |
- Returns
◆ GetFilterValues< T >()
Gets the value(s) of the given filter as the provided generic type. Use this when invoking your search to obtain the filter values setup by the user.
- Template Parameters
| T | The type of filter values to return a collection of. |
- Parameters
| searchFilter | The filter to get the value for. |
- Returns
- The value(s) of the given search filter as the provided generic type.
◆ RemoveFilterValue()
Removes the provided search filter value from the search criteria.
- Parameters
| searchFilter | The search filter which the filterValue was previously added to. |
| filterValue | The search filter value to remove. |
◆ Changed
Indication that the search criteria has changed.
