VideoOS.Platform.Search.SearchDefinition Class Referenceabstract
Represents an independent search definition. More...
Public Member Functions
virtual void Close ()
 Called when the search definition is no longer needed for searching. After this is called, no searches will be called on this definition.
virtual void Init ()
 This method is called when the search definition has been created. This could be used if the search definition need to initialize variables.
Protected Member Functions
virtual void FireErrorOccurredEvent (Guid sessionId, SearchError searchError)
 Invoke this method when a run-time error occurred. The search could continue after calling this method.
virtual void FireSearchResultsReadyEvent (Guid sessionId, IEnumerable< SearchResultData > searchResults)
 Invoke this method when a partial result is ready to be offloaded.
virtual void Search (Guid sessionId, DateTime from, DateTime to, IEnumerable< Item > items, CancellationToken cancellationToken)
 Override this method to implement your search for pre 2020 R1 VMS. To support search in 2020 R1 VMS and newer, please override the overload Search(VideoOS.Platform.Search.SearchInput,System.Threading.CancellationToken). Note: The search is considered finished when this method returns. Use FireSearchResultsReadyEvent when search results are ready.
virtual void Search (SearchInput searchInput, CancellationToken cancellationToken)
 Override this method to implement your search. Note: The search is considered finished when this method returns. Use FireSearchResultsReadyEvent when search results are ready.
 SearchDefinition (SearchScope searchScope)
 Default constructor invoked by all base classes.
Properties
Guid SearchAgentPluginId [get, set]
 The ID of the SearchAgentPlugin which created this search definition.
SearchCriteria SearchCriteria [get]
 The search criteria container associated with this search definition. There is always a 1-to-1 relationship between a SearchDefinition and a Platform.Search.SearchCriteria.
SearchScope SearchScope [get]
 Gets the search scope associated with the edit control.
Detailed Description
Constructor & Destructor Documentation
◆ SearchDefinition()
VideoOS.Platform.Search.SearchDefinition.SearchDefinition ( SearchScope searchScope)
inlineprotected
Member Function Documentation
◆ Close()
virtual void VideoOS.Platform.Search.SearchDefinition.Close ( )
inlinevirtual
◆ FireErrorOccurredEvent()
virtual void VideoOS.Platform.Search.SearchDefinition.FireErrorOccurredEvent ( Guid sessionId,
SearchError searchError )
inlineprotectedvirtual
Parameters
sessionIdThe session id identifying the current search.
searchErrorThe search error that occurred.
◆ FireSearchResultsReadyEvent()
virtual void VideoOS.Platform.Search.SearchDefinition.FireSearchResultsReadyEvent ( Guid sessionId,
IEnumerable< SearchResultData > searchResults )
Parameters
searchResultsThe chunk of search results ready to be offloaded.
◆ Init()
virtual void VideoOS.Platform.Search.SearchDefinition.Init ( )
inlinevirtual
◆ Search() [1/2]
virtual void VideoOS.Platform.Search.SearchDefinition.Search ( Guid sessionId,
DateTime from,
DateTime to,
CancellationToken cancellationToken )
Parameters
sessionIdA unique session id identifying the started search.
fromThe start of the time span in which to search.
toThe end of the time span in which to search.
itemsThe items (i.e. cameras) to include in the search.
cancellationTokenCancellation token which can be used to cancel an ongoing search (if the implementation allows it).
◆ Search() [2/2]
virtual void VideoOS.Platform.Search.SearchDefinition.Search ( SearchInput searchInput,
Parameters
searchInputInput for the search
Property Documentation
◆ SearchAgentPluginId
Guid VideoOS.Platform.Search.SearchDefinition.SearchAgentPluginId
getset
◆ SearchCriteria
SearchCriteria VideoOS.Platform.Search.SearchDefinition.SearchCriteria
get
◆ SearchScope
SearchScope VideoOS.Platform.Search.SearchDefinition.SearchScope
get
Returns
