VideoOS.Platform.Live.LiveSource Class Referenceabstract
An abstract class to be used for implementation of a LiveSources.
Within the MIP Environment there are currently these built-in implementations:
JPEGLiveSource
BitmapLiveSource
RawLiveSource
More...
Inheritance diagram for VideoOS.Platform.Live.LiveSource:
VideoOS.Platform.Live.BaseLiveSource< TLiveContent, TLiveContentEventArgs >
Public Member Functions
virtual void Close ()
 See the specific LiveSource implementation for documentation.
virtual void Init ()
Protected Member Functions
 LiveSource ()
 Construct a LiveSource. The Item need to be initialized before the Init call.
 LiveSource (Item item)
 Construct a LiveSource based on the Item given as parameter.
void ProcessingNewFrame ()
 Signal that an implementation has passed on a new frame to a client.
bool ProcessNextFrame ()
 Tells if the client is not ready to process the next frame when SingleFrameQueue is active.
Properties
virtual Item Item [get, set]
virtual bool LiveModeStart [get, set]
 This flag controls the ongoing stream of live packages. When the user UI is shortly doing something else, this flag can be set to false, to avoid packages passing the network but not used.
bool SingleFrameQueue [get, set]
 Defines if only ONE frame should be forwarded to the application at any given time.
Events
EventHandler LiveContentEvent
 This event is fired for every new live frame.
The EventArgs passed on with this event is the LiveContentEventArgs or LiveContentRawEventArgs containing the frame and properties.
EventHandler LiveStatusEvent
 This event is fired when new live status information is available.
The EventArgs passed on with this event is the LiveStatusEventArgs containing flag information about the current status of the camera connection.
Detailed Description
JPEGLiveSource
BitmapLiveSource
RawLiveSource
Construct one of these classes with the Item as parameter, e.g.
JPEGLiveSource myJpeg = new JPEGLiveSource( cameraItem )
This class is responsible for delivering live JPEG images from a camera. Only supported in Smart Cli...
Definition JPEGLiveSource.cs:16
Constructor & Destructor Documentation
◆ LiveSource() [1/2]
VideoOS.Platform.Live.LiveSource.LiveSource ( )
inlineprotected
◆ LiveSource() [2/2]
VideoOS.Platform.Live.LiveSource.LiveSource ( Item item)
inlineprotected
Parameters
item
Member Function Documentation
◆ Close()
virtual void VideoOS.Platform.Live.LiveSource.Close ( )
inlinevirtual
Reimplemented in VideoOS.Platform.Live.BaseLiveSource< TLiveContent, TLiveContentEventArgs >.
◆ Init()
virtual void VideoOS.Platform.Live.LiveSource.Init ( )
inlinevirtual
◆ ProcessingNewFrame()
void VideoOS.Platform.Live.LiveSource.ProcessingNewFrame ( )
inlineprotected
◆ ProcessNextFrame()
bool VideoOS.Platform.Live.LiveSource.ProcessNextFrame ( )
inlineprotected
Returns
true if the client is still processing the old frame
Property Documentation
◆ Item
virtual Item VideoOS.Platform.Live.LiveSource.Item
getset
◆ LiveModeStart
virtual bool VideoOS.Platform.Live.LiveSource.LiveModeStart
getset
◆ SingleFrameQueue
bool VideoOS.Platform.Live.LiveSource.SingleFrameQueue
getset
Event Documentation
◆ LiveContentEvent
EventHandler VideoOS.Platform.Live.LiveSource.LiveContentEvent
abstract
◆ LiveStatusEvent
EventHandler VideoOS.Platform.Live.LiveSource.LiveStatusEvent
abstract
