VideoOS.Platform.Live.RawLiveSource Class Reference
Provides raw video frames, including GenericByteHeader, for further analysis and decoding. More...
Inheritance diagram for VideoOS.Platform.Live.RawLiveSource:
VideoOS.Platform.Live.BaseLiveSource< LiveSourceRawContent, LiveContentRawEventArgs >
Public Member Functions
 RawLiveSource (Item item)
 Construct the class for use of video from the defined Item. The Item can be an ImageServer owned camera, or a Corporate database file.
- Public Member Functions inherited from VideoOS.Platform.Live.BaseLiveSource< LiveSourceRawContent, LiveContentRawEventArgs >
override void Close ()
 See the specific LiveSource implementation for documentation.
override void Init ()
 Initialize and connect to the source of the video.
void ReleaseObject (IDisposable usedObject)
 Deprecated. May be deleted in the future.
Protected Member Functions
override object ConnectLiveSource (string media)
 ConnectLiveSource(string media) base class overritable.
override void HandleLiveDataContent (LiveSourceRawContent data)
 HandleLiveDataContent(LiveSourceRawContent data) base class overritable.
override void OnUpdateLiveStart ()
 OnUpdateLiveStart() base class overritable.
override void OnUpdateSettings ()
 OnUpdateSettings() base class overritable.
- Protected Member Functions inherited from VideoOS.Platform.Live.BaseLiveSource< LiveSourceRawContent, LiveContentRawEventArgs >
 BaseLiveSource (Item item, IEnumerable< Guid > supportedTypes, bool isRawSource)
void ConnectAndStartLiveSource ()
 Method to be overriten in the inheritors.
void HandleLiveDataContent (TLiveContent data)
 Called on received data. Should be overrriten in the inheritors.
bool OnLiveContentEvent (EventArgs eventArgs)
 Called when data is received.
void OnLiveStatusEvent (EventArgs eventArgs)
 Called when status is received.
 Called when Live start is updated. Used from inheritors to do specific intializations.
 Used by inheritors to update some settings.
void StopAndDisconnectLiveSource ()
Properties
bool EnableMulticast [get, set]
 Specify whether multicast should be used if supported by and enabled on the server. Must be set before calling BaseLiveSource<LiveSourceRawContent, LiveContentRawEventArgs>.Init() Default is false.
Only supported in Smart Client and standalone.
bool RequestSignatures [get, set]
 Defines if the signatures should be passed from the DB layer to the application - can be used when the video database is signed. The Application can use this to validate the frames as being authentic.
- Properties inherited from VideoOS.Platform.Live.BaseLiveSource< LiveSourceRawContent, LiveContentRawEventArgs >
TimeSpan ConnectTimeout [get, set]
 Timeout for connecting. If not set the timeout is infinite.
StatusFlags CurrentStatusFlags [get]
 Holds the current status.
It is also possible to be immediately informed about status changes by subscribing to the LiveStatusEvent.
bool IsInitialized [get]
 Returns true when Init has been called, and false after Close() has been called.
bool IsRawSource [get, set]
 Property describing if the live source will get raw data or not.
override Item Item [get, set]
 The camera Item to receive live video from.
override bool LiveModeStart [get, set]
 Start the live feed. Frames will be passed through the LiveNotificationEvent event.
bool MulticastEnabled [get, protected set]
 Tells whether multicast is enabled for current stream.
bool SendInitialImage [get, set]
 Informs RS to send cached old image in case of missing live at the moment.
object SessionId [get]
 Session object that can be used by the inheritors or users of the component.
Guid StreamId [get, set]
 Can be used to identify which stream to use, when more than one is available.
Multiple streams are available in XProtect Corporate.
When set to Guid.Empty, the default stream will be used.
virtual IStreamSelectionParams StreamSelectionParams [get]
 Allows configuration/selection of the specific camera stream.
IEnumerable< Guid > SupportedItemTypes [get, set]
 List of supported item Types.
Additional Inherited Members
- Package Functions inherited from VideoOS.Platform.Live.BaseLiveSource< LiveSourceRawContent, LiveContentRawEventArgs >
- Events inherited from VideoOS.Platform.Live.BaseLiveSource< LiveSourceRawContent, LiveContentRawEventArgs >
override EventHandler LiveContentEvent
 This event is fired for every new live frame.
The EventArgs passed on with this event is the LiveContentEventArgs/LiveContentRawEventArgs containing the frame and properties.
override EventHandler LiveStatusEvent
 This event is fired when new live status information is available.
The EventArgs passed on with this event is the LiveStatusEventArgs containing flag information about the current status of the camera connection.
Detailed Description
Note: Is only implemented in the Smart Client and in the MIP SDK for component integration.
Constructor & Destructor Documentation
◆ RawLiveSource()
VideoOS.Platform.Live.RawLiveSource.RawLiveSource ( Item item)
inline
Parameters
item
Member Function Documentation
◆ ConnectLiveSource()
override object VideoOS.Platform.Live.RawLiveSource.ConnectLiveSource ( string media)
inlineprotected
Parameters
media
◆ HandleLiveDataContent()
override void VideoOS.Platform.Live.RawLiveSource.HandleLiveDataContent ( LiveSourceRawContent data)
inlineprotected
Parameters
data
◆ OnUpdateLiveStart()
override void VideoOS.Platform.Live.RawLiveSource.OnUpdateLiveStart ( )
inlineprotected
◆ OnUpdateSettings()
override void VideoOS.Platform.Live.RawLiveSource.OnUpdateSettings ( )
inlineprotected
Property Documentation
◆ EnableMulticast
bool VideoOS.Platform.Live.RawLiveSource.EnableMulticast
getset
◆ RequestSignatures
bool VideoOS.Platform.Live.RawLiveSource.RequestSignatures
getset
