Namespaces | |
| namespace | HardwareDeviceDefinitions |
| namespace | MediaDataHelpers |
| namespace | MediaProviderInternal |
| namespace | MetadataSuppliersInternal |
Classes | |
| class | AccessControlEvent |
| The AccessControlEvent class is used for events generated with access control plugins. More... | |
| class | Alarm |
| The representation of a Milestone alarm. More... | |
| class | AlarmUpdateKey |
| This class specifies the available keys when doing an alarm update. More... | |
| class | AlertConverter |
| Allows for conversion from legacy MAD format to MAD format version 2.5. More... | |
| class | AlertData |
| This is simply a reference to the EventData structure, that is used to return the result. More... | |
| class | AlertDataSource |
| Alerts are no longer supported. More... | |
| class | AnalyticsEvent |
| An implementation of the BaseEvent with more relevant information when an Analytics oriented event has occurred. More... | |
| class | AnalyticsObject |
| The representation of an analytics object. More... | |
| class | AnalyticsObjectList |
| A list of analytics objects. More... | |
| class | AsyncResultEventArgs |
| The result of a Async operation. More... | |
| class | AudioStreamPlayer |
| Streams PCM data from an input stream to the OutgoingSpeakerController. More... | |
| class | AVIExporter |
| This class will use environment specific implementation to export either one video stream with zero or more audio streams, or multiple video streams, to an AVI file. More... | |
| class | BaseEvent |
| The BaseEvent, containing information common for all Milestone events. Notice that several overriden classes exists that may be more useful in a given situation, e.g. AnalyticsEvent or EventData. More... | |
| class | BitmapData |
| Contains the Bitmap information. More... | |
| class | BitmapDataResult |
| The result type received when using the ThumbnailQueue to fetch a thumbnail. The type has properties to indicate if an error occurred, and the actual data (if no error occurred). More... | |
| class | BitmapVideoSource |
| BitmapVideoSource gets video image formatted as Bitmaps. This class is NOT thread safe, and all calls to these methods MUST be coming from same thread. When getting images from the server, it should be considered that the Get() method can take some time and is not ideal to execute on a UI thread. Only supported in Smart Client and standalone environments. More... | |
| class | BitmapVideoSourceImplementer |
| BitmapVideoSourceImplementer gets video image formatted as Bitmaps. This class is NOT thread safe, and all calls to these methods MUST be coming from same thread. When getting images from the server, it should be considered that the Get() method can take some time and is not ideal to execute on a UI thread. | |
| class | Bookmark |
| The Bookmark class represents a bookmark instance. More... | |
| class | BookmarkReference |
| The result of getting a new bookmark reference. This class is returned as a result for the BookmarkGetNewReference method. More... | |
| class | BookmarkService |
| Provides access to the bookmark service of the ServerCommandService. Note that this service is only available on the high-end XProtect Corporate products. For the products where it is not supported, each method entry is ignored and a single message is logged in the MIP log. The methods of this service is invoked through the singleton reference 'Instance'. E.g. A new bookmark may be created using the statement: Bookmark bookmark1 = BookmarkService.Instance.BookmarkCreate(cameraFqid, timeBegin, timeTrigger, timeEnd, reference, header, description); The 'Bookmark' class contains all the information related to the new bookmark, especially the BookmarkFQID property, which holds the unique identification of the new bookmark. Existing bookmarks may be queried by BookmarkSearchTime or BookmarkSearchFromBookmark. BookmarkSearchTime searches for bookmarks within a specific time interval. BookmarkSearchFromBookmark begins the search from the time right after a specific existing bookmark. The search may take several seconds. Therefore it may be relevant to use the asynchronous equivalents BookmarkSearchTimeAsync and BookmarkSearchFromBookmarkAsync in stead. A known bookmark may be quieried by means of the BookmarkGet method. More... | |
| class | BoundingBox |
| The representation of a bounding box, describing a rectangle in normalized coordinates within the scene. More... | |
| class | CameraDeviceDefinition |
| This class is responsible for describing the parameters for a single camera device. More... | |
| class | DataCapability |
| This class is responsible for describing the parameters for a data capability, which takes integer values. More... | |
| class | DataSource |
| An abstract class to be used for implementation of a DataSource. Within the MIP Environment there are currently these built-in implementations: AlertDataSource - to get access to video alerts SequenceDataSource - to get access to recorded video related sequence information StreamDataSource - to get the configured streams on a camera MetadataSource - to get the configured metadata stream information on a metadata item If a plug-in can provide list of data related to a specific Item, implementation of this class can be used. Construction can be performed in two ways: Call the GetDataSource() on the owning Item Construct the correct class based on the Item at hand More... | |
| class | DataType |
| Represents a type of Data being provided by a DataSource. More... | |
| class | DBExporter |
| Class to perform a database export from a VMS server to a local disk. More... | |
| class | DirectSpeakerController |
| The DirectSpeakerController sends an audio stream directly to an outgoing speaker. The audio data is transported "as is", without adjusting parameters like . More... | |
| class | DirectSpeakerControllerExt |
| Extension to DirectSpeakerController The DirectSpeakerControllerExt sends an audio stream directly to an outgoing speaker. The audio data is transported "as is", without adjusting parameters. Added error code and device id properties. More... | |
| class | EnumCapability |
| This class is responsible for describing the parameters for an enum capability, which can only take discrete predefined values. More... | |
| class | EnumCapabilityValue |
| This class is responsible for describing one of the allowed values for an enum capability. Each value is selectable in the drop-down list for the enum capability. More... | |
| class | EventData |
| The EventData contains a complete set of information for a specific event. It is used for some DataSources as well as for EventServer integration. More... | |
| class | EventGroup |
| This class is used to group EventTypes. More... | |
| class | EventHeader |
| The representation of an event header containing information common for all Milestone events. When using this class for creation of events or alarms, please be aware that Message is to be considered the type of the event/alarm and thus should not be unique for each event/alarm, but rather common between all events/alarms of the same type. More... | |
| class | EventHeaderTypes |
| Contains the built-in types used in the EventHeader.Type on the BaseEvent class. Partners are welcome to use their own types. These types can be used to filter message reception of type level, instead of receiving all messages, when using the MessageCommunication classes. VideoOS.Platform.Messaging.CommunicationIdFilter constructor for more on usage. More... | |
| class | EventSequence |
| Contain image and video reference. More... | |
| class | EventSource |
| The source of the event. This can represent e.g. a camera, a microphone, a user-defined event, etc. More... | |
| class | EventType |
| This class is used to define Event Types which an VideoOS.Platform.Admin.ItemManager can deliver to the Event Server using the method GetKnownEventTypes(CultureInfo culture). Event Types are used in defining the events, which can trigger alarms. More... | |
| class | FaultDevice |
| Error state of processed marked data. More... | |
| class | FreeFormBaseEvent |
| The FreeFormBaseEvent is used to store events with arbitrary JSON data. FreeFormBaseEvent is for internal use only. Do not use. More... | |
| class | GenericData |
| Contains the Generic Data as bytes. More... | |
| class | GenericTranscodedVideoSource |
| GenericTranscodedVideoSource - generic class to dela with transoded sources This class is NOT thread safe, and all calls to these methods MUST be coming from same thread. When getting images from the server, it should be considered that the Get() method can take some time and is not ideal to execute on a UI thread. | |
| class | GenericVideoSource |
| BaseVideoSource in abstract class for video and audio sources. More... | |
| class | HardwareDefinition |
| This class represents a piece of hardware that can added to a runnig system using the MIP driver. More... | |
| class | IAudioRecorder |
| This class is a base class for audio recorder implementations. In the .Net Library there is one implementation, for recording audio from a PC attached microphone. More... | |
| interface | ICancelableRequest |
| Defines a cancelable thumbnail queue request. More... | |
| interface | IDirectSpeakerController |
| Interface of DirectSpeakerController sends an audio stream directly to an outgoing speaker. More... | |
| interface | IDirectSpeakerControllerExt |
| interface | IExporter |
| The common interface used by DBExporter and AVIExporter. More... | |
| interface | IInternalCommandServiceImplementer |
| Interface for communication with InternalCommandService. Used by instances of BaseVideoSource. More... | |
| class | InternalCommandServiceImplementerBitmap |
| class | InternalCommandServiceImplementerJpegData |
| class | InternalCommandServiceImplementerPcmAudioDataList |
| interface | IPcmAudioData |
| Contains the specific data for audio data. More... | |
| class | ItemRequestQueue |
| Queue that is used to make multiple item related server requests in a controlled manor. Using this queue in the right way will throttle the server requests to ensure that resources are not exhausted. Currently item of type camera, microphone, speaker metadata is supported. More... | |
| interface | IThumbnailQueueDiagnostics |
| Diagnostics for the ThumbnailQueue providing a snapshot of the current state of the queue. More... | |
| class | JPEGData |
| Contains the JPEG as bytes. More... | |
| class | JPEGVideoSource |
| JPEGVideoSource gets recorded video image formatted as JPEGs. Please note that all calls to the methods in this class MUST be coming from the same thread! When getting images from the server, it should be considered that the Get() method can take some time and is not ideal to execute on a UI thread. Only supported in Smart Client and standalone environments. More... | |
| class | JPEGVideoSourceImplementer |
| JPEGVideoSourceImplementer gets recorded video image formatted as JPEGs. This class is NOT thread safe, and all calls to these methods MUST be coming from same thread. When getting images from the server, it should be considered that the Get() method can take some time and is not ideal to execute on a UI thread. | |
| class | MediaData |
| Contains one piece of media information. For video it will be one frame, for audio it will be for a short period. More... | |
| class | MediaProviderChannel |
| This MediaProvider provides an interface for sending video frames to a Milestone XProtect Recording Server. The specific MIPMediaProvider driver has to be configured to point at this executing application and port, as defined in this class. More... | |
| class | MediaProviderService |
| The MediaProviderService will open for TCP socket and listen for connections. New MediaProvider's need to be created for each channel that will be available for video later on. More... | |
| class | MediaProviderSession |
| Contains the properties that a given session is using. When used on the initial SessionOpening method, it will contain the values as requested by the server side. The application can then modify the values to what is relevant for the given application and session. This class is created by the MediaProviderService when a new HTTP request has been received that want to receive a new stream. Note that multiple MediaProviderSession classes can exist on the same MediaProvider when multiple servers are connecting to the same channel. More... | |
| class | MetadataCache |
| This class is repsonsible for caching and navigating a pseudo-"GOP" of metadata content. It handles navigating retreiving, storing and navigating by supporing GetNext and GetPrevious operations. | |
| class | MetadataDeviceCapability |
| This class is responsible for describing a capability for a metadata device. A capability describes a single setting that will appear on the settings tab for the device. More... | |
| class | MetadataDeviceDefintion |
| This class is responsible for describing the parameters used by a single metadata device on a piece of hardware. More... | |
| class | MetadataHardwareDefinition |
| This class represents the overall. More... | |
| class | MetadataPlaybackData |
| This class is responsible for containing the information about a single "frame" of recorded metadata. More... | |
| class | MetadataPlaybackSource |
| MetadataPlaybackSource gets metadata in raw mode. This means that the Generic Byte Header as well as the content is available. When getting metadata from the server, it should be considered that the Get() method can take some time and is not ideal to execute on a UI thread. Only supported in Smart Client and standalone environments. More... | |
| class | MetadataProviderChannel |
| This MetadataProviderChannel provides an interface for sending metadata to a Milestone XProtect Recording Server. More... | |
| class | MetadataQueue |
| Metadata queue (singleton) used for fetching metadata XML in a controlled and optimized manner. Queue characteristics can be controlled in the app.config of the client application, otherwise default values are used. The following app settings can be configured in the app.config file to control the queue: More... | |
| class | MetadataQueueResult |
| The result type received when using the MetadataQueue to fetch a metadata. The type has properties to indicate if an error occurred, and the actual data (if no error occurred). More... | |
| class | MetadataSource |
| This class is responsible for giving information about the data in a metadata device. Specifically, it allows a client to retrieve information about the types of metadata that the device can deliver. More... | |
| class | MetadataSupplier |
| This class automatically provides metadata when available, both in live and playback. More... | |
| class | MetadataSupplierErrorEventArgs |
| Instances of this class will be returned when MetadataSupplier.ErrorEvent is triggered. More... | |
| class | MetadataSupplierEventArgs |
| Instances of this class will be included when MetadataSupplier.NewMetadataEvent is triggered. More... | |
| class | MetadataSupplierMetadataInvalidatedEventArgs |
Instances of this class will be returned when MetadataSupplier.MetadataInvalidatedEvent is triggered. More... | |
| class | MetadataTypeDefinition |
| This class is responsible for handling the parameters that define the type of metadata a metadata device delivers when using the MIP driver. The display name (or its translation) will be used as the headline on the settings tab for the device in the Management Client. All capabilities in this type will then appear as children in the setting tab. More... | |
| class | MKVExporter |
| This class will use Environment specific implementation to export one video stream and zero or multiple audio streams to an MKV file (Matroska). More... | |
| class | ObjectMotion |
| The representation of an objects tracked motion through the scene. More... | |
| class | OutgoingSpeakerController |
| The OutgoingSpeakerController sends an audio stream to a speaker. The audio stream can come from a pc-microphone or a file. More... | |
| class | PcmAudioData |
| PCM data. More... | |
| class | PcmAudioDataList |
| List of PCM audio datas. More... | |
| class | PcmAudioSource |
| Class providing Pcm audio data for playback When getting audio from the server, it should be considered that the Get() method can take some time and is not ideal to execute on a UI thread. More... | |
| class | PointList |
| A list of points. More... | |
| class | PolygonList |
| A list of polygons. More... | |
| class | Property |
| The Property class is used for events generated with access control plugins. The AccessControlEvent class references this class. More... | |
| class | RawVideoSource |
| RawVideoSource gets video image in raw mode, e.g. GenericByteHeaders with encoded content. When getting images from the server, it should be considered that the Get() method can take some time and is not ideal to execute on a UI thread. Note: Is only implemented in the Smart Client and in the MIP SDK for component integration. More... | |
| class | RawVideoSourceData |
| Contains the raw GenericByteData content, used by RawVideoSource during playback of raw frames. More... | |
| class | RawVideoSourceDataList |
| Contains a list of raw GenericByteData content, used by RawVideoSource during playback of raw frames. More... | |
| class | Reference |
| The representation of a reference to another entity in the system - e.g. another alarm or device. More... | |
| class | ReferenceList |
| A list of references. More... | |
| class | RestrictedMedia |
| The RestrictedMedia class represents a restricted media instance. More... | |
| class | RestrictedMediaLive |
| This RestrictedMediaLive class represents a restricted media live instance. More... | |
| class | RestrictedMediaLiveResult |
| Result of processed restricted media live. More... | |
| class | RestrictedMediaResult |
| Result of processed restricted media. More... | |
| class | RestrictedMediaService |
| class | Rule |
| The representation of a rule, which triggered the event. More... | |
| class | RuleList |
| A list of rules. More... | |
| class | SequenceAviExportElement |
| Class for defining each element of an AVI sequence export. More... | |
| class | SequenceData |
| Contains the actual sequence data for one sequence, e.g. start and end DateTime. More... | |
| class | SequenceDataSource |
| The SequenceDataSource can assist with getting sequence information for a camera or metadata device. The GetData methods returns a list of SequenceData containing the DateTime information for the type of sequence requested. The GetTypes() method will return the possible and supported types for this class. E.g. the DataType.SequenceTypeGuids.RecordingSequence for Recorded sequences. More... | |
| class | SizeAndCropInfo |
| Internal class usage for holding the size and crop info. | |
| class | SmartClientProfileSetting |
| Data class for a Smart Client Profile setting. More... | |
| class | Snapshot |
| The representation of a snapshot associated with the event with time offset relative to the event timestamp. More... | |
| class | SnapshotList |
| A list of snapshots. More... | |
| class | SourceDataOnBitmapDataProxy |
| Proxy between ISourceData and BitmapData. More... | |
| class | SourceDataOnJpegDataProxy |
| Proxy between ISourceData and JPEGData. More... | |
| class | SourceDataOnRawDataProxy |
| Proxy between ISourceData and RawVideoSourceData. More... | |
| class | StateGroup |
| This class is used to define a state group, referenced by EventType More... | |
| class | StreamDataSource |
| The StreamDataSource provides information of what streams are available on a given Item. This data source is only valid for camera items (Kind.Camera) when running in the .Net Library Environment. (Version MIPSDK 3.6 or later). More... | |
| class | TColor |
| The representation of an ARGB color. More... | |
| class | ThumbnailQueue |
| Thumbnail queue (singleton) used for fetching thumbnail images from cameras in a controlled and optimized manner. Queue characteristics can be controlled in the app.config of the client application, otherwise default values are used. The following app settings can be configured in the app.config file to control the queue: More... | |
| class | TPoint |
| The representation of a point described by a set of normalized coordinates. More... | |
| class | TPolygon |
| The representation of a polygon describing a set of normalized coordiantes and color. More... | |
| class | Vendor |
| Information about the analytics vendor including any custom data. More... | |
| class | VideoSource |
| Gives access to recorded video. More... | |
| class | VideoSourceDataOnBitmapDataProxy |
| Proxy between IVideoSourceData and BitmapData. More... | |
| class | VideoSourceDataOnJpegDataProxy |
| class | WarningDevice |
| Warning state of processed restricted media. More... | |
| class | WAVExporter |
| This class will use environment specific implementation to export one or mixture of multiple audio streams to an WAV file. You can do sound mixing with combination of speaker output and microphone input for instance. To export multiple audio streams, you need to set the AudioList property then call the StartExport(DateTime, DateTime) method. More... | |
Enumerations | |
| enum | ClientErrorCode { Ok = 0 , ConnectionLost = 1 , WrongState = 2 , AuthenticationFailed = 3 , InternalError = 4 , Max = 99 } |
| Error code of the client. More... | |
| enum | EncryptionStrength { DES56 , AES128 , AES192 , AES256 } |
| Encryption strength values. More... | |
| enum | MediaContent { Jpeg = 1 , H264 = 2 , Audio = 3 , MetaData = 4 , Mpeg = 5 , H265 = 6 , Pcm = 7 } |
| The format being requested from the server side. More... | |
| enum | RestrictedMediaResponseCode { UnknownError = 0 , None = 1 , Warning = 2 , Unauthorized = 3 , DeviceNotFound = 4 , RestrictedMediasNotSupported = 5 , AlreadyInRestrictedLiveMode = 6 , NotInRestrictedLiveMode = 7 } |
| Response code of processed restricted media. More... | |
| enum | RestrictedMediaResultStatus { Undefined , Success , Failed , PartlySuccess , RestrictedMediaNotFound , FeatureNotLicensed , RecorderNotFound , ManagementServerUnavailable , Unauthorized } |
| Result status of processed restricted media. More... | |
Functions | |
| delegate void | AsyncCallbackHandler (object result, object state) |
| A delegate to hold the reference to your method to be called when the result has been retrieved from the server. | |
| delegate void VideoOS.Platform.Data.AsyncCallbackHandler | ( | object | result, |
| object | state ) |
