VideoOS.Platform.Log.LogMessage Class Reference
Contains one log message. More...
Properties
string Category [get, set]
 The Category ID further specifying what area this message relates to under the Group.
string CategoryName [get, set]
 Supported from VMS and MIP SDK 25.3. The localized Category name further specifying what area this message relates to under the Group.
String Group [get, set]
 The group this message should be saved under (see Group class)
String Id [get, set]
 A string identifying the log message (not the message itself!)
String Message [get, set]
 The message text in the defined Culture (as this LogMessage is part of a LogMessageDictionary for one Culture only)
Guid RelatedObjectKind [get, set]
 The id of an object that this message relates to.
String Severity [get, set]
 The Severity of this message.
String Status [get, set]
 Indicate if this message changes any states.
Detailed Description
Property Documentation
◆ Category
string VideoOS.Platform.Log.LogMessage.Category
getset
◆ CategoryName
string VideoOS.Platform.Log.LogMessage.CategoryName
getset
◆ Group
String VideoOS.Platform.Log.LogMessage.Group
getset
◆ Id
String VideoOS.Platform.Log.LogMessage.Id
getset
◆ Message
String VideoOS.Platform.Log.LogMessage.Message
getset
◆ RelatedObjectKind
Guid VideoOS.Platform.Log.LogMessage.RelatedObjectKind
getset
◆ Severity
String VideoOS.Platform.Log.LogMessage.Severity
getset
◆ Status
String VideoOS.Platform.Log.LogMessage.Status
getset
