VideoOS.Platform.Search.SearchUserControlsPlugin Class Referenceabstract
Defines the search user controls plugin interface. Inherit this class to create custom UI controls to visualize SearchResultData and/or FilterConfigurationBase instances. More...
Public Member Functions
virtual void Close ()
 Called by the Environment when the user log's off. Disposes of any resources.
virtual SearchFilterEditControl CreateSearchFilterEditControl (FilterConfigurationBase filterConfiguration)
 Creates a SearchFilterEditControl used to allow the user to edit a search filter based on the given filter configuration.
virtual SearchResultUserControl CreateSearchResultUserControl (Guid searchResultUserControlType)
 Creates a SearchResultUserControl which can visualize the given search result type.
virtual void Init ()
 This method is called when the user has logged in and configuration is accessible. If a user logs out and in again, this method will be called at every login. This should be used if the plugin is accessing configuration items.
Properties
Guid Id [get, protected set]
 Unique id of this plugin. If copying any of the sample plugins - be sure to replace this id with a new one.
string Name [get, protected set]
 Name of the plugin.
IEnumerable< Type > SearchFilterConfigurationTypes [get, protected set]
 Gets an enumerable of search filter configuration types (i.e. types deriving from FilterConfigurationBase) indicating which search filter types you wish to add a (or override the default) user control for.
IEnumerable< Guid > SearchResultUserControlTypes [get, protected set]
 Gets an enumerable of search result user control types indicating which search results you wish to add a (or override the default) user control for.
Detailed Description
Member Function Documentation
◆ Close()
virtual void VideoOS.Platform.Search.SearchUserControlsPlugin.Close ( )
inlinevirtual
◆ CreateSearchFilterEditControl()
virtual SearchFilterEditControl VideoOS.Platform.Search.SearchUserControlsPlugin.CreateSearchFilterEditControl ( FilterConfigurationBase filterConfiguration)
inlinevirtual
Parameters
filterConfigurationThe configuration of the search filter with which to create a SearchFilterEditControl.
Returns
User control to display the search filter edit control based on the provided filter configuration.
◆ CreateSearchResultUserControl()
virtual SearchResultUserControl VideoOS.Platform.Search.SearchUserControlsPlugin.CreateSearchResultUserControl ( Guid searchResultUserControlType)
inlinevirtual
Parameters
searchResultUserControlTypeThe search result user control type which to create a SearchResultUserControl.
Returns
User control to display a search result based on the provided search result user control type.
◆ Init()
virtual void VideoOS.Platform.Search.SearchUserControlsPlugin.Init ( )
inlinevirtual
Property Documentation
◆ Id
Guid VideoOS.Platform.Search.SearchUserControlsPlugin.Id
getprotected setabstract
◆ Name
string VideoOS.Platform.Search.SearchUserControlsPlugin.Name
Name of the plugin.
◆ SearchFilterConfigurationTypes
IEnumerable<Type> VideoOS.Platform.Search.SearchUserControlsPlugin.SearchFilterConfigurationTypes
◆ SearchResultUserControlTypes
IEnumerable<Guid> VideoOS.Platform.Search.SearchUserControlsPlugin.SearchResultUserControlTypes
