VideoOS.Platform.Live.LiveSourceContent Class Reference
This class is used for receiving live content. More...
Inheritance diagram for VideoOS.Platform.Live.LiveSourceContent:
VideoOS.Platform.Live.LiveSourceBitmapContent
Public Member Functions
virtual void Dispose ()
 Releases resources and signals that the client is done using this frame.
void Dispose (bool disposing)
 This method does nothing and should never be called!
Properties
DateTime BeginTime [get, set]
 The time stamp for the beginning of the content.
byte[] Content [get, set]
 Contains the requested content.
Be aware that this can be of zero length in certain cases, and should simply be ignored in that instance.
double CropHeight [get, set]
 When the CroppingDefined is true, this field contains the cropping definition. The definition contains the same values as used on the SetCropping call.
bool CroppingDefined [get, set]
 Is set to true if the returned content has been cropped.
double CropWidth [get, set]
double CropX [get, set]
double CropY [get, set]
object CustomData [get, set]
 Contains the CustomData set on the LiveSource (e.g. JPEGLiveSource).
DateTime EndTime [get, set]
 The time stamp for the end of the content. This field is only relevant for audio data.
virtual String HardwareDecodingStatus [get, set]
 Defines how the decoding of the current frame is performed.
Values can be:
'hardware' - Decoded by GPU
'software' - Decoded by Intel Media SDK
'fallback' - Decoded by Intel Media SDK, even though it was requested to be Hardware (or Auto)
'ipp' - Decoded by Intel UMC
int Height [get]
 Get the Height of the returned JPEG. 0 returned when height cannot be detected.
Dictionary< String, string > Properties [get, set]
 Any additional properties containing information about the content.
int Width [get]
 Get the width of the returned JPEG. 0 returned when width cannot be detected.
Detailed Description
Member Function Documentation
◆ Dispose() [1/2]
virtual void VideoOS.Platform.Live.LiveSourceContent.Dispose ( )
inlinevirtual
This method is not thread-safe!
Reimplemented in VideoOS.Platform.Live.LiveSourceBitmapContent.
◆ Dispose() [2/2]
void VideoOS.Platform.Live.LiveSourceContent.Dispose ( bool disposing)
inline
Property Documentation
◆ BeginTime
DateTime VideoOS.Platform.Live.LiveSourceContent.BeginTime
getset
◆ Content
byte [] VideoOS.Platform.Live.LiveSourceContent.Content
getset
◆ CropHeight
double VideoOS.Platform.Live.LiveSourceContent.CropHeight
getset
◆ CroppingDefined
bool VideoOS.Platform.Live.LiveSourceContent.CroppingDefined
getset
◆ CropWidth
double VideoOS.Platform.Live.LiveSourceContent.CropWidth
getset
◆ CropX
double VideoOS.Platform.Live.LiveSourceContent.CropX
getset
◆ CropY
double VideoOS.Platform.Live.LiveSourceContent.CropY
getset
◆ CustomData
object VideoOS.Platform.Live.LiveSourceContent.CustomData
getset
◆ EndTime
DateTime VideoOS.Platform.Live.LiveSourceContent.EndTime
getset
◆ HardwareDecodingStatus
virtual String VideoOS.Platform.Live.LiveSourceContent.HardwareDecodingStatus
getset
Values can be:
◆ Height
int VideoOS.Platform.Live.LiveSourceContent.Height
get
◆ Properties
Dictionary<String, string> VideoOS.Platform.Live.LiveSourceContent.Properties
getset
◆ Width
int VideoOS.Platform.Live.LiveSourceContent.Width
get
