VideoOS.Platform.Client.WorkSpacePlugin Class Referenceabstract
The abstract base class a MIP plugin can implement for having a WorkSpace tab available in the Smart Client. More...
Inheritance diagram for VideoOS.Platform.Client.WorkSpacePlugin:
VideoOS.Platform.Client.PropertyClass
Public Member Functions
void Close ()
 Called by the Environment when the user log's off.
void Init ()
 This method is called when the user has logged in and configuration is accessible. If a user logs out and in again, this method will be called at every login. This should be used if the plug-in is accessing configuration items.
bool LoadProperties (bool userPrivate)
 Get the stored properties from the connected server.
bool SaveProperties (bool userPrivate)
 Saves the values in the Properties on the connected server.
When userPrivate is true, the content is for own use only.
When userPrivate is false, the content is shared for all users connected to a server.
virtual void ViewItemConfigurationModified (int index)
 Called when a view item configuration for one of the view items in the workspace view has been modified.
 WorkSpacePlugin ()
- Public Member Functions inherited from VideoOS.Platform.Client.PropertyClass
void ClearProperties ()
 Clear property table.
virtual void Deserialize (XmlNode xmlNode)
 Deserializes the class item from xml format.
string GetProperty (string key)
 Gets a named (key) property value from the property list. Null is returned of the property does not exists.
ICollection GetPropertyKeys ()
 Gets all the keys in the property collection.
object GetTemporaryProperty (string key)
 Gets a named (key) temporary property value from the property list. Null is returned of the property does not exists.
 PropertyClass ()
 Constructs a PropertyClass item.
virtual void Serialize (System.Xml.XmlTextWriter xmlTextWriter)
 Serializes the class item into xml format.
virtual String SerializeToString ()
 Create a XmlNode containing the property dictionary, returned as a String.
virtual XmlNode SerializeToXmlNode ()
void SetProperty (string key, string value)
 Sets a named (key) property value in the property list. The property value is updated if the property exists.
void SetTemporaryProperty (string key, object value)
 Sets a named (key) temporary property value in the property list. The property value is updated if the property exists. Temporary will not be serialized (stored)
Properties
virtual Image Icon [get]
 This property is deprecated. Windows Forms controls are no longer supported. Use IconSource instead. The icon representing this workspace.
virtual VideoOSIconSourceBase IconSource [get]
Guid Id [get]
 Gets the unique id identifying this plug-in component. This property is accessed from WorkSpacePlugin constructor. So ensure that it returns the valid ID even though the constructor of the derived implementation has not been called.
virtual bool IsSetupStateSupported [get]
 Indicates whether this work space plugin supports setup state or not.
virtual bool Live [get]
 Indicates whether this work space plugin is in live mode or not. The default value is true.
String Name [get]
 The name of this plug-in.
WorkSpaceNotification Notification [get, set]
 The current work space notification. The work space implementation sets this to a new instance of WorkSpaceNotification every time its notification state changes. Set to null to indicate that no notification should be shown for the work space plugin.
virtual bool ShowTimeline [get]
 Indicates whether to show the timeline when in playback mode or not. The default value is true.
ViewAndLayoutItem ViewAndLayoutItem [get]
 The ViewAndLayoutItem shown in the WorkSpace.
Events
EventHandler NotificationChangedEvent
Additional Inherited Members
- Protected Attributes inherited from VideoOS.Platform.Client.PropertyClass
SortedList _properties = new SortedList()
 The key-value collection holding the properties.
SortedList _temporaryProperties = new SortedList()
 The key-value collection holding the temporary properties. Temporary will not be serialized (stored)
- Package Functions inherited from VideoOS.Platform.Client.PropertyClass
Detailed Description
Constructor & Destructor Documentation
◆ WorkSpacePlugin()
VideoOS.Platform.Client.WorkSpacePlugin.WorkSpacePlugin ( )
inline
Member Function Documentation
◆ Close()
void VideoOS.Platform.Client.WorkSpacePlugin.Close ( )
abstract
◆ Init()
void VideoOS.Platform.Client.WorkSpacePlugin.Init ( )
abstract
◆ LoadProperties()
bool VideoOS.Platform.Client.WorkSpacePlugin.LoadProperties ( bool userPrivate)
inline
Parameters
userPrivateset to true when properties are save for each user
Returns
true if Properties where found and false if this is a first time
◆ SaveProperties()
bool VideoOS.Platform.Client.WorkSpacePlugin.SaveProperties ( bool userPrivate)
inline
Parameters
userPrivate
Returns
◆ ViewItemConfigurationModified()
virtual void VideoOS.Platform.Client.WorkSpacePlugin.ViewItemConfigurationModified ( int index)
inlinevirtual
Parameters
indexThe index of the modified view item
Property Documentation
◆ Icon
virtual Image VideoOS.Platform.Client.WorkSpacePlugin.Icon
get
◆ IconSource
virtual VideoOSIconSourceBase VideoOS.Platform.Client.WorkSpacePlugin.IconSource
get
◆ Id
Guid VideoOS.Platform.Client.WorkSpacePlugin.Id
getabstract
◆ IsSetupStateSupported
virtual bool VideoOS.Platform.Client.WorkSpacePlugin.IsSetupStateSupported
get
◆ Live
virtual bool VideoOS.Platform.Client.WorkSpacePlugin.Live
get
◆ Name
String VideoOS.Platform.Client.WorkSpacePlugin.Name
getabstract
◆ Notification
WorkSpaceNotification VideoOS.Platform.Client.WorkSpacePlugin.Notification
getset
◆ ShowTimeline
virtual bool VideoOS.Platform.Client.WorkSpacePlugin.ShowTimeline
get
◆ ViewAndLayoutItem
ViewAndLayoutItem VideoOS.Platform.Client.WorkSpacePlugin.ViewAndLayoutItem
get
Event Documentation
◆ NotificationChangedEvent
EventHandler VideoOS.Platform.Client.WorkSpacePlugin.NotificationChangedEvent
