VideoOS.Platform.Client.PropertyClass Class Referenceabstract
Abstract class incapsulating a key-value based property list.
More...
Inheritance diagram for VideoOS.Platform.Client.PropertyClass:
VideoOS.Platform.Background.BackgroundPlugin VideoOS.Platform.Client.ConfigurationItemBase VideoOS.Platform.Client.OptionsDialogPlugin VideoOS.Platform.Client.SettingsPanelPlugin VideoOS.Platform.Client.SidePanelPlugin VideoOS.Platform.Client.ViewItemToolbarPlugin VideoOS.Platform.Client.WorkSpacePlugin VideoOS.Platform.Client.WorkSpaceToolbarPlugin VideoOS.Platform.Client.WorkSpaceToolbarPluginGroup
Public Member Functions
void ClearProperties ()
 Clear property table.
virtual void Deserialize (XmlNode xmlNode)
 Deserializes the class item from xml format.
string GetProperty (string key)
 Gets a named (key) property value from the property list. Null is returned of the property does not exists.
ICollection GetPropertyKeys ()
 Gets all the keys in the property collection.
object GetTemporaryProperty (string key)
 Gets a named (key) temporary property value from the property list. Null is returned of the property does not exists.
 PropertyClass ()
 Constructs a PropertyClass item.
virtual void Serialize (System.Xml.XmlTextWriter xmlTextWriter)
 Serializes the class item into xml format.
virtual String SerializeToString ()
 Create a XmlNode containing the property dictionary, returned as a String.
virtual XmlNode SerializeToXmlNode ()
void SetProperty (string key, string value)
 Sets a named (key) property value in the property list. The property value is updated if the property exists.
void SetTemporaryProperty (string key, object value)
 Sets a named (key) temporary property value in the property list. The property value is updated if the property exists. Temporary will not be serialized (stored)
Protected Attributes
SortedList _properties = new SortedList()
 The key-value collection holding the properties.
SortedList _temporaryProperties = new SortedList()
 The key-value collection holding the temporary properties. Temporary will not be serialized (stored)
Detailed Description
Constructor & Destructor Documentation
◆ PropertyClass()
VideoOS.Platform.Client.PropertyClass.PropertyClass ( )
inline
Member Function Documentation
◆ ClearProperties()
void VideoOS.Platform.Client.PropertyClass.ClearProperties ( )
inline
◆ Deserialize()
virtual void VideoOS.Platform.Client.PropertyClass.Deserialize ( XmlNode xmlNode)
inlinevirtual
Parameters
xmlNodeXmlNode containing the initialization xml
Reimplemented in VideoOS.Platform.Client.ViewItemManager.
◆ GetProperty()
string VideoOS.Platform.Client.PropertyClass.GetProperty ( string key)
inline
Parameters
keyThe key of the property to get
Returns
The value of the property
◆ GetPropertyKeys()
ICollection VideoOS.Platform.Client.PropertyClass.GetPropertyKeys ( )
inline
Returns
◆ GetTemporaryProperty()
object VideoOS.Platform.Client.PropertyClass.GetTemporaryProperty ( string key)
inline
Parameters
keyThe key of the temporary property to get
Returns
The value of the temporary property
◆ Serialize()
virtual void VideoOS.Platform.Client.PropertyClass.Serialize ( System.Xml.XmlTextWriter xmlTextWriter)
inlinevirtual
Parameters
xmlTextWriterXmlTextWriter that the class item is serialized to
◆ SerializeToString()
virtual String VideoOS.Platform.Client.PropertyClass.SerializeToString ( )
inlinevirtual
Returns
◆ SerializeToXmlNode()
virtual XmlNode VideoOS.Platform.Client.PropertyClass.SerializeToXmlNode ( )
inlinevirtual
Returns
◆ SetProperty()
void VideoOS.Platform.Client.PropertyClass.SetProperty ( string key,
string value )
inline
Parameters
keyThe key of the property to set
valueThe value of the property to set
Setting a value of null will remove the setting from the dictionary
◆ SetTemporaryProperty()
void VideoOS.Platform.Client.PropertyClass.SetTemporaryProperty ( string key,
object value )
inline
Parameters
keyThe key of the temporary property to set
valueThe value of the temporary property to set
Member Data Documentation
◆ _properties
SortedList VideoOS.Platform.Client.PropertyClass._properties = new SortedList()
protected
◆ _temporaryProperties
SortedList VideoOS.Platform.Client.PropertyClass._temporaryProperties = new SortedList()
protected
