VideoOS.Platform.Client.ViewControl Class Referenceabstract
ViewControl is an easy to use UI component for showing a collection of viewitems in a MIP plugin UI. More...
Inheritance diagram for VideoOS.Platform.Client.ViewControl:
Public Member Functions
virtual bool ChangeLayout (List< ViewControlItem > items, List< Rectangle > viewLayout)
 Change control layout for items with related viewLayout.
void Close ()
 Closes the ViewControl. Call this method when it is removed from the UI.
Protected Member Functions
 ViewControl ()
 ViewControl (List< ViewControlItem > items, List< Rectangle > viewLayout)
 Creates a ViewControl.
 ViewControl (List< ViewControlItem > items, List< Rectangle > viewLayout, WindowInformation windowInformation)
 Use this constructor to create a ViewControl that is linked to the mode and playback of the window referenced in the windowInformation.
Properties
virtual bool EnabledViewItemToolbars = false [get, set]
 Gets or sets whether the toolbar of the view items in the ViewControl is enabled or not. Default value is false.
List< ViewControlItemItems [get, protected set]
 Gets or sets the list of ViewControlItems that belongs to the ViewControl.
bool Live [get, set]
 Gets or sets whether the control is in live mode or not. If set to false then the control is in playback mode. If ParentWindowInformation is set, the mode of the whole window is affected.
WindowInformation ParentWindowInformation [get]
 Gets the WindowInformation of the window that should control the playback mode and time of the ViewControl. If this is not set, the ViewControl will ignore the playback mode and playback events in the view that it is part of. Obtain the WindowInformation from the ViewItemUserControl, where it will be set before Init is called.
DateTime PlaybackTime [get, set]
 Gets or sets the current playback time. If ParentWindowInformation is not set, the playback time of the whole window is affected.
virtual ViewControlItem SelectedItem [get, set]
 Gets or sets the current selected item.
List< Rectangle > ViewLayout [get, protected set]
 Gets or sets the layout of the view.
Guid WindowId [get, protected set]
 Gets the window ID assigned to this ViewControl (not to be confused with the ID of the window containing the control). Can be used for sending messages to view items within the control.
Events
EventHandler< ViewControlItemDataArgsItemDataChanged
 Event that is fired when the data for one of the items is changed.
Typically the data is used to persist and later restore the view item using the DataViewControlItem view item type.
EventHandler< ViewControlItemArgsSelectedItemChanged
 Event that is fired when the selected viewItem is changed.
Detailed Description
Constructor & Destructor Documentation
◆ ViewControl() [1/3]
VideoOS.Platform.Client.ViewControl.ViewControl ( )
inlineprotected
◆ ViewControl() [2/3]
VideoOS.Platform.Client.ViewControl.ViewControl ( List< ViewControlItem > items,
List< Rectangle > viewLayout )
inlineprotected
◆ ViewControl() [3/3]
WindowInformation windowInformation )
inlineprotected
Member Function Documentation
◆ ChangeLayout()
virtual bool VideoOS.Platform.Client.ViewControl.ChangeLayout ( List< ViewControlItem > items,
inlinevirtual
Parameters
itemsNew items for the layout.
viewLayoutNew layout elements. Must correspond to items.
Returns
true if layout was updated.
◆ Close()
void VideoOS.Platform.Client.ViewControl.Close ( )
abstract
Property Documentation
◆ EnabledViewItemToolbars
virtual bool VideoOS.Platform.Client.ViewControl.EnabledViewItemToolbars = false
getset
◆ Items
List<ViewControlItem> VideoOS.Platform.Client.ViewControl.Items
getprotected set
◆ Live
bool VideoOS.Platform.Client.ViewControl.Live
getsetabstract
◆ ParentWindowInformation
WindowInformation VideoOS.Platform.Client.ViewControl.ParentWindowInformation
get
◆ PlaybackTime
DateTime VideoOS.Platform.Client.ViewControl.PlaybackTime
getsetabstract
◆ SelectedItem
virtual ViewControlItem VideoOS.Platform.Client.ViewControl.SelectedItem
getset
◆ ViewLayout
List<Rectangle> VideoOS.Platform.Client.ViewControl.ViewLayout
getprotected set
◆ WindowId
Guid VideoOS.Platform.Client.ViewControl.WindowId
getprotected set
Event Documentation
◆ ItemDataChanged
EventHandler<ViewControlItemDataArgs> VideoOS.Platform.Client.ViewControl.ItemDataChanged
◆ SelectedItemChanged
EventHandler<ViewControlItemArgs> VideoOS.Platform.Client.ViewControl.SelectedItemChanged
abstract
