Playback streaming
Overview
Mobile Server provides functionality for getting playback streams - both audio and video.
To get live stream one of the following commands should be called with the respective parameters.
For playback mode SignalType parameter should be set to Playback
On response of these commands a StreamId will be returned that should be used to get audio\video:
See Video channel or Audio channel sections for further details
Playback mode
Mobile Server supports two playback modes:
Single stream playbak is controlled via the following command
and provided as a prameter to the command for requesting stream
To create Multiple stream playbak a playback controller should be created first via:
To control Multiple stream playbak use:
