Video channel
Video channel is implemented with private binary protocol, which has header and data parts.
Main Header
Size, Bytes
Name
Type
Description
16
Video ID
GUID
Retrieved from the Meta channel. Used as a start code and a frame separator.
8
Time Stamp UTC
LONG
Milliseconds since 1st January 1970 (UTC)
4
Frame Count
UINT
Number of frame (probably won’t be necessary)
4
Frame Size Bytes
UINT
Size in bytes of the following data part
2
HeaderSizeBytes
USHORT
Total size of headers in bytes including this Main header. (So the value will always be 36 or more).
If the vaule is zero, however, it has special meaning that the Main header contains additional 4-byte "HeaderSizeBytesExt" field (effectively making the Main header 40 bytes long).
2
HeaderExtensionFlags
USHORT
Bit mask which describes which extension headers presents.
4
HeaderSizeBytesExt
(optional)
UINT
Total size of headers in bytes including this Main header. (So the value will always be 40 or more).
This additional field is present only if the ordinary "HeaderSizeBytes" field has value of zero. Otherwise this field is never present.
It is allowed this filed to present even if total lenght of headers could be described with 2 bytes.
Header Extension sizes
Headerflag - 0x01
Size, Bytes
Name
Type
Description
4
SrcStrideX
INT
Camera original source width.
4
SrcStrideY
INT
Camera original source height.
4
SrcLeft
INT
Cropping rectangle left.
4
SrcTop
INT
Cropping rectangle top.
4
SrcRight
INT
Cropping rectangle right.
4
SrcBottom
INT
Cropping rectangle bottom.
4
DestStrideX
INT
Rescaled picture destination width.
4
DestStrideY
INT
Rescaled picture destination height.
4
ResamplingTag
INT
- Mobile client or Mobile Server does not support decimal resampling factor- 1,2 or 4. Indicates the multiplier that will yield the original number of pixels.
Mobile client and Mobile Server support support decimal resampling factor – divide the value by 106 (ex. Value = 1234567, Resampling factor = 1.234567)
4
Reserved
INT
Not used.
4
Reserved
INT
Not used.
4
Reserved
INT
Not used.
Header Extension live events
Headerflag - 0x02
Size, Bytes
Name
Type
Description
4
CurrentFlags
UINT
Bit mask for current flags state.
4
ChangedFlags
UINT
Bit mask for changed flags state (since previous state).
Available flags:
•   LiveFeed = 1,
•   Motion = 2,
•   Recording = 4,
•   Notification = 8,
•   CameraConnectionLost = 16,
•   DatabaseFail = 32,
•   DiskFull = 64,
•   ClientLiveStopped = 128,
Header Extension playback events
Headerflag - 0x04
Size, Bytes
Name
Type
Description
4
CurrentFlags
UINT
4
ChangedFlags
UINT
Available Flags:
•   PlayStopped = 0x1,
•   PlayForward = 0x2,
•   PlayBackward = 0x4,
•   DatabaseStart = 0x10,
•   DatabaseEnd = 0x20,
•   DatabaseError = 0x40,
•   RangeNoData = 0x100,
•   OutOfRange = 0x200,
Header Extension Native Data Headers
Headerflag - 0x08
Size, Bytes
Name
Type
Description
4
NativeDataHeaderSize
UINT
Size of the whole group of native header extensions
4
NativeDataExtensionsFlags
UINT
Flags specifying which of the native data header extensions are included.
This header serves as the main header of the native data headers. The first value is the size of the whole group of native headers extensions. The second value is a bitmask stating which of the extended native data headers are included on the current native data frame. The next four sections will describe each of these extensions.
Native Data Header extension - Playback SyncPoint
Native Data Header flag - 0x01
Size, Bytes
Name
Type
Description
8
PreviousSyncTimeStamp
ULONG
Time stamp of previous sync-point in playback stream.
8
NextSyncTimeStamp
ULONG
Time stamp of next sync-point in playback stream.
The time stamp of the previous and next sync point is used by the Milestone decoders and must be accessible on a Native Stream in Playback Mode. Note that this header extension is required on a sync point, i.e. an I-frame in H.264 but it should not be set on other media data frames. The time stamps are available through the Image Server Source Toolkit and needs to be throught the MIP SDK along with the media data. These time stamps are not used in live mode and this header extension should therefore not be sent.
Native Data Header extension -Native Playback Header
Native Data Header flag - 0x02
Size, Bytes
Name
Type
Description
8
SequenceId
ULONG
Sequence Id of the current frame
2
HasMotion
UINT16
Flag stating whether the current frame has motion.
The SequenceId and HasMotion flags can be used to recreate the sequence and time line information available on the server. This is of great importance for the Media Storage Export Toolkit for instance. In contrast to native playback sync point header extension described in the previous section this header should be set on all media data frames, including sync points. The SequenceId and HasMotion header values are not used in live mode and this header extension should therefore not be included.
Native Data Header extension - Privacy Mask
Native Data Header flag - 0x04
Size, Bytes
Name
Type
Description
4
PrivacyMaskState
UINT
State of the privacy mask.
4
PrivacyMaskLength
UINT
Length of privacy mask string in bytes.
VAR
PrivacyMask
STRING
Privacy mask string in standard ASCII format.
Today the privacy mask is added to the images by the Mobile Server during transcoding. We have to do something similar in the Direct Streaming decoders and hence we need the privacy mask streamed as a string (no zeros and thus not zero-terminated, nor CRLF-terminated). This can for instance be handled as a chunk of binary data. The privacy mask header can be set on both sync points media data frames and regular media data frames. Furthermore, privacy masks are set for both Live and Playback Streams and this header extension therefore has to be permitted in both modes.
This header should not be sent if no privacy mask is specified on the server.
Assuming a privacy mask has been specified at least one of the following conditions have to be met when determining whether to add a privacy mask header extension:
1. The media frame is the first one being sent after the RequestStream call.
2. The privacy mask has changed since sending the last frame and must be changed for the current.
The reason for the second condition is that it is assumed that clients cache the current privacy mask.
Native Data Header extension - Signature
Native Data Header flag - 0x08
Size, Bytes
Name
Type
Description
4
SignatureState
UINT
State of the signature.
4
SignatureLength
UINT
Length of signature string.
VAR
Signature
STRING
Signature string in standard ASCII format.
Database signing was a feature added to the Media Storage Database with the XPCO 5.0 release. This involves signing the media data with a certificate and then verifying the signatures during database export. Again the Web and Mobile Client will not have much use for this header extension (for now), but it must be there for later and for third-party SDK use. Contrary to privacy masks media data signatures only exists for recorded data. For that reason this header extension should only be set on media data sent through a Playback Stream.
A signature is calculated for a range of records in the database.
This header should only be sent when signing is enabled by the server, on the first frame that is received on a Playback Stream, and when the signature changes.
Assuming that signing has been enabled on server at least one of the following conditions have to be met when determining whether to add a signature header extension on a media data frame:
2. The signature has changed since sending the last frame and must be changed for the current.
The reason for the second condition is that it is assumed that clients cache the current signature.
Header Extension motion events (Arcus only)
Motion Events Header Flag - 0x10
This header is Arcus server specific.
Size, Bytes
Name
Type
Description
4
HeaderSize
UINT
Size of this header.
4
MotionAmmount
UINT
Ammount of motion detected.
Header Extension Location Info (Under Development)
Location Info Header Flag - 0x20
Size, Bytes
Name
Type
Description
4
HeaderSize
UINT
4
Version
UINT
Version of the location header.
4
Source
UINT
Location data source.
4
Reserved
UINT
Reserved for future use.
4 ValidFields UINT Indicates which of the following fields have valid values.
4 Longitude UINT Longitude in GCS.
4 Latitude UINT Latitude in GCS.
4 Altitude INT Altitude in GCS.
4 HorizontalAccuracy UINT Accuracy of the Longitude and Latitude.
4 VerticalAccuracy UINT Accuracy of the Altitude.
4 Speed UINT Client horizontal speed.
4 Azimuth UINT Angle to the North of the client's direction.
HeaderSize - size of this header in bytes. Currently has a value of 48.
Version - currently this field has only one valie value and this is zero (0).
Source - indicates where the location info comes from. It is a bit field mask with members:
 Unknown = 0,
 Satellite = 0x01,
 WiFi = 0x02,
 Cellular = 0x04,
 IpAddress = 0x08,
 Radio = WiFi | Cellular,
Reserved - allocated for future usage. Currently should have value of zero.
ValidFileds - bitmask which idicates correcteness of data members (Longiture, Latitude, Altitude, Horizontal/Vertical Accuracy, Speed and Azimuth)
 LongitudeMask = 0x01,
 LatitudeMask = 0x02,
 AltitudeMask = 0x04,
 HorizontalAccuracyMask = 0x08,
 VerticalAccuracyMask = 0x10,
 SpeedMask = 0x20,
 AzimuthMask = 0x40
GSC - Geographic coordinate system
Longitude - Specifies the east-west position in degrees.
 It has only positive values - from 0 to 360. Every negative value should be added to 360. For example if (-90) should be expressed, it is equal to 270.
 The value in the field is multiplied with 10^7. For example value of 42.670308 should be written as 426'703'080.
Latitude - Specifies the north-south position in degrees.
 It has only positive values - from 0 to 180. Every negative value should be added to 180. For example if (-36) should be expressed, it is equal to 144.
 The value in the field is multiplied with 10^7. For example value of 23.352784 should be written as 233'527'840.
Altitude - Height above mean see level, measured in centimeters. (1 cm = 10 mm = 0.01 m)
HorizontalAccuracy - Accuracy of the Longitude and Latitude, measured in centimeters.
VerticalAccuracy - Accuracy of the Altitude, measured in centimeters.
Speed - Horizontal velocity (change of the position) in cm/s (centimeters per second)
Azimuth - Angle between client's forward direction and true north in degrees (measured in clockwise direction).
 It has only positive values - from 0 to 360. Every negative value should be added to 360. For example if (-34) should be expressed, it is equal to 326.
 The value in the field is multiplied with 10^7. For example value of 18.234556 should be written as 182'345'560.
Header Extension Stream Info
Stream Info Header Flag - 0x40
Size, Bytes
Name
Type
Description
4
HeaderSize
UINT
4
Version
UINT
Version of the info header.
4
Reserved
UINT
4
Fields
UINT
4
TimeBetweenFrames
UINT
In MS
4
DataType
UINT
Four letter data type (e.g. H264, JPEG) of the underlying raw stream
4
Flags
UINT
Streaming info flags
4
Profile
UINT
Video codec profile.
4
Level
UINT
Video codec level.
4
Compatibility
UINT
Video codec compatibility.
8
Constrains
ULONG
Video codec constrains.
4
FramesCount
UINT
Number of frames in current stream segment
HeaderSize - size of this header in bytes. Currently has a value of 52.
Version - current version (3).
Fields - bitmask which indicates correctness of data members
 TimeBetweenFrames = 0x01,
 DataType = 0x02,
 Flags = 0x04
 Profile = 0x08,
 Level = 0x10,
 Compatibility = 0x20,
 Constraints = 0x40,
 FramesCount = 0x80,
DataType - Four letter string byte representation of the stream data type. NULL for not supported, H264, H265, JPEG.
Flags are currently set to 0x01 in case the video data contains key frame.
Header Extension Carousel Info
Carousel Info Header Flag - 0x80
Size, Bytes
Name
Type
Description
4
HeaderSize
UINT
4
Version
UINT
Version of the header.
16
ItemId
GUID
ID of the current playing camera in the carousel.
HeaderSize - size of this header in bytes. Currently has a value of 24.
Version - currently this field has only one value and this is zero (0).
ItemId - GUID of the camera Item which is currently playing.
Header Extension Dynamic Info
Carousel Info and Error in Audio Push Header Flag - 0x100
Size, Bytes
Name
Type
Description
4
HeaderSize
UINT
Size of this header + size of following data.
4
Version
UINT
4
DataCount
UINT
Number of data type structers following this header
4
DataType
UINT
Type of the data following this header.
HeaderSize - size of this header + size of following data in bytes.
DataCount - Number of data type structures following this header.
DataType - Type of the data following this header.
 HeaderTypeDeviceStateInfo = 0x00
Header Type Device State Info
Type Device State - 0x00
Size, Bytes
Name
Type
Description
16
ItemID
GUID
Id of device (speaker) that has failed.
4
ErrorCode
UINT
Error code
4
Reserved
UINT
Align to 8 bytes
ItemID - Id of device (speaker) that has failed.
ErrorCode - Code of the error. Error codes are defined as Command error codes
Reserved - Align to 8 bytes.
Header Extension Playback Info
Headerflag - 0x200
Size, Bytes
Name
Type
Description
8
RequestedTimeStampUtcMs
ULONG
Time stamp of requested playback image.
4
Reserved
UINT
Not used.
4
Reserved
UINT
Not used.
