Classes | |
| class | AuthenticationType |
| Defines the authentication types used in MIP. More... | |
| interface | ILoginSettingsCacheWrapper |
| class | LoginServerProductInfo |
| Contains information about the server that is logged on to. More... | |
| class | LoginSettings |
| LoginSettings contain a Token of login for one server. It needs to be renewed once in a while. More... | |
| class | LoginSettingsCache |
| Contains the cache of all LoginSettings currently in use by the Environment. More... | |
| class | LoginSettingsCacheWrapper |
| Contains the cache of all LoginSettings currently in use by the Environment. | |
| class | Util |
| A utility class to build user CredentialCache and NetworkCredential. More... | |
