Classes | |
| class | BooleanElement |
| Contains one json element of boolean type. More... | |
| class | DoubleElement |
| Contains one json element with a double value. More... | |
| class | ElementList |
| ElementList is a class used to contain the json elements sent in Post, Put and Patch messages. These values will later be used to update the values of items stored in the database. More... | |
| interface | IElement |
| Interface used to describe one json element. Specific classes for each json formatted type implements this interface. More... | |
| class | IntElement |
| Contains one json element of integer type. More... | |
| class | JsonBuilder |
| A class for basic Json handling. This class handles construction of json objects in string format. More... | |
| class | JsonErrorMessages |
| class | JsonObject |
| Handling JSON formated fields. This class constructior will use the JsonReader to pass the json string and construct IElement objects of all sub fields. More... | |
| class | JsonReader |
| Converts JSON string into an ElementList. More... | |
| class | JsonUtilities |
| Class for assisting in handling Json strings. More... | |
| class | NullElement |
| Element that only contains a null value - could be related to both an Int or a String. More... | |
| class | StringElement |
| Contains one json element of string type, the string is enclused in double quotes, and need to be json escaped for special characters. More... | |
| class | Token |
| Contains a single json token with field name, the value in either Text or BoolValue. More... | |
| class | TokenException |
| Exception throws when the json parser finds an invalid token. More... | |
Enumerations | |
| enum | TokenType { ElementStart , ElementEnd , ArrayStart , ArrayEnd , Colon , Comma , String , Int , Boolean , Double , Null , Ulong } |
| Identifies a single token in a json string. More... | |
| Enumerator | |
| ElementStart | Token is: {. |
| ElementEnd | Token is: }. |
| ArrayStart | Token is: [. |
| ArrayEnd | Token is: ]. |
| Colon | Token is: : |
| Comma | Token is: ,. |
| String | Token is: a complete string (without the quotes) |
| Int | The token is an integer (or could be a double with no decimals) |
| Boolean | The token is a boolean. |
| Double | The token is a double value. |
| Null | The token value is a 'null'. |
| Ulong | The token is a big unsigned integer. |
