VideoOS.Platform.Search.SearchResultUserControl Class Referenceabstract
User control used to visualize a given SearchResultData. More...
Inheritance diagram for VideoOS.Platform.Search.SearchResultUserControl:
Public Member Functions
virtual void Close ()
 Closes the control.
void Init (SearchResultData searchResultData)
 Initializes the user control with the provided SearchResultData.
Protected Member Functions
virtual void OnPropertyChanged (string propertyName)
 Raises the PropertyChanged event with the provided propertyName in the event args.
Properties
Thickness DefaultLoadingVisualizationMargin = new Thickness() [get, set]
 Margin for default visualization of the loading progress. Override this property to adjust placement of the default visualization. Default placement is center of the control.
bool IsLoading [get, protected set]
 Indicates whether or not a general loading visualization should be visible. Set this property to True if the content of your result view is not displayed instantly, and set it back to False when the view is done loading.
bool SuppressDefaultLoadingVisualization [get, set]
 Set to true/false to disable/enable general "loading in progress"-visualization.
Events
EventHandler IsLoadingChanged
 Event which is fired whenever the IsLoading property changes.
PropertyChangedEventHandler PropertyChanged
 Event which is fired whenever a property changes. This is primarily used for UI bindings.
Detailed Description
Inherit this class to create your own visualization of a SearchResultData. In order to use the type you create, you must also add a SearchUserControlsPlugin to your plugin definition.
Member Function Documentation
◆ Close()
virtual void VideoOS.Platform.Search.SearchResultUserControl.Close ( )
inlinevirtual
Closes the control.
◆ Init()
void VideoOS.Platform.Search.SearchResultUserControl.Init ( SearchResultData searchResultData)
abstract
Parameters
searchResultDataSearch result to visualize.
◆ OnPropertyChanged()
virtual void VideoOS.Platform.Search.SearchResultUserControl.OnPropertyChanged ( string propertyName)
inlineprotectedvirtual
Parameters
propertyNameThe property for which to raise a PropertyChanged event.
Property Documentation
◆ DefaultLoadingVisualizationMargin
Thickness VideoOS.Platform.Search.SearchResultUserControl.DefaultLoadingVisualizationMargin = new Thickness()
getset
◆ IsLoading
bool VideoOS.Platform.Search.SearchResultUserControl.IsLoading
getprotected set
To suppress default visualization, call SuppressDefaultLoadingVisualization
◆ SuppressDefaultLoadingVisualization
bool VideoOS.Platform.Search.SearchResultUserControl.SuppressDefaultLoadingVisualization
getsetprotected
Event Documentation
◆ IsLoadingChanged
EventHandler VideoOS.Platform.Search.SearchResultUserControl.IsLoadingChanged
◆ PropertyChanged
PropertyChangedEventHandler VideoOS.Platform.Search.SearchResultUserControl.PropertyChanged
