Used by the EnvironmentManager.Instance.HasCapability() method. More...
Static Public Attributes | |
| const String | DynamicSecurityActions = "DynamicSecurityActions" |
| Defines if a plugin can add and remove SecurityActions over time. E.g. between releases. When this capability is not available, a MIP plugin should keep the same set of SecurityActions. | |
static |
