Namespaces | |
namespace | AdaptiveStreaming |
namespace | Error |
namespace | GisMap |
namespace | Images |
namespace | ImageServer |
namespace | Pcm |
namespace | Performance |
namespace | Queue |
namespace | Security |
namespace | Svc |
namespace | ToolkitXmlProviders |
Classes | |
class | AlarmBuilder |
class | AnalyticsOverlayBuilder |
A utility class to construct a bitmap that can be used as an overlay on top of video. More... | |
class | ByteArrayHelper |
Helper class for work with byte arrays. More... | |
class | ConfigurationCache |
Cache for MIP Item configurations from one VMS server (site) | |
class | ConfigurationChangedService |
For internal use only. More... | |
class | DifferentiatedAdministrationRights |
This class is only relevant for Corporate VMS systems, while running inside the Management Client. More... | |
class | EventServerDummyBackgroundPlugin |
Helper class to be used by build-in plugin definitions that do not have a background plugin themselves, but want to ensure they are loaded in Event Server. | |
class | Factory |
Wrapper of creator function. | |
class | GuidUtil |
Utility class for dealing with creation of unique Guids based on a string input. NOTE: Code borrowed and slightly modified (only SHA1 support) from this OpenSource project (license terms updated accordingly): https://github.com/Faithlife/FaithlifeUtility/blob/master/src/Faithlife.Utility/GuidUtility.cs. More... | |
interface | IFactory |
Factory that can create instances of type T | |
class | InternalConfigService |
class | InternalMediaService |
interface | IPcmSourceSettings |
Interface for getting audio parameters. More... | |
class | ItemSearch |
interface | IWaitUtil |
class | JpegUtil |
Util to analyze JPEG content. More... | |
class | KindConfiguration |
Holds a cache for items of one kind. | |
class | LazyExtensions |
class | Migration |
For internal use. More... | |
class | MipTrace |
class | PcmSourceSettings |
Class that encapsulates PCM source settings. More... | |
class | SecurityAccess |
This class assists in maintaining security access for Items and validating what Items a user can access. The plug-in must be sure to register and unregister the Items that is under access control, e.g. has a SecurityAccess defined. This could be done in the ItemManager.ValidateAndSaveUserControl method with a call to RegisterItem(Item) and in the ItemManager.DeleteItem(Item) with a call to UnregisterItem(Item). More... | |
class | ServiceHelperBackground |
class | ServiceHelperPlugin |
class | ServiceUtil |
The ServiceUtil class is used as common point to register services and later retrieve a list of the registered services. Service types are identified by a Guid, and in case of multiple registrations of the same service type, an instance field is used to distinguish them. More... | |
class | ServiceUtilCache |
Used by ServiceUtil - cache service list for 10 minutes. | |
class | Sort |
Contains method for Sorting assistance. More... | |
class | SpnFactory |
The SpnFactory is a helper class to get the right SPN for a connection. More... | |
class | TimeConvert |
struct | TimeInterval |
Responsible for representing a time interval. It is up to the consumer to handle the DateTimeKind of the TimeInterval instance. In any case, all DateTimeKinds are supported, but we highly recommend to use only UTC time! Instances are immutable. More... | |
class | UrlUtil |
Utility for URL formatting. More... | |
class | ViewItemUtility |
Construct an XML node containg the definition of a View, as used by Video Wall. More... | |
class | WaitUtil |
class | WorkStealingQueue |
A work-stealing queue. | |
class | WorkStealingTaskScheduler |
Provides a work-stealing scheduler. | |
