VideoOS.Platform.Metadata Namespace Reference
Classes
class  Appearance
 This class is responsible for representing an ONVIF XML appearance. More...
class  Behaviour
 This class is responsible for representing an ONVIF XML behavior for objects. More...
class  ClassCandidate
 This class is responsible for representing an ONVIF XML class candidate used for conveying information on the type of object inside a bounding box. More...
class  Color
class  ColorCluster
class  DisplayColor
 This class is responsible for containing information on the color used to draw metadata objects. More...
class  DisplayText
 This class is responsible for representing text than can be embedded as part of metadata. This text can then be presented to the users in some form. More...
class  Frame
 This class is responsible for representing a Frame in ONVIF XML. More...
class  MetadataContent
 This class is responsible for containing metadata received from the VMS system. More...
class  MetadataDeserializer
 This class is responsible for deserializing metadata stored in the ONVIF metadata format. More...
class  MetadataSerializer
 This class is responsible for serializing metadata to the ONVIF XML metadata format. More...
class  MetadataStream
class  MetadataXml
 A nametable for Metadata XML used for speeding up processing and centralizing names. This works by only instantiating a specific string once, thereby making reference comparisons possible for string matching. All XML names (elements and attributes) must be public static read-only string. Otherwise the reflection logic will fail to add the names to the XmlNameTable.
class  NavigationalData
 This class is responsible for holding navigational metadata. More...
class  OnvifClass
 This class is responsible for representing an ONVIF XML class. More...
class  OnvifObject
 This class is responsible for representing an ONVIF XML object. More...
class  Polygon
class  Rectangle
 This class is responsible for representing an ONVIF XML rectangle. More...
class  Shape
 This class is responsible for representing an ONVIF XML shape. More...
class  Transformation
 This class is responsible for representing an ONVIF XML transformation. More...
class  Vector
 This class is responsible for representing a two-dimensional vector in ONVIF XML. More...
class  VideoAnalytics
 This class is responsible for representing a VideoAnalytics in ONVIF XML. More...
