Namespaces | |
| namespace | OemResources |
Classes | |
| class | ConcurrentLicenseManager |
| NOTE: This class has been discontinued and should no longer be used. More... | |
| class | ConcurrentLicenseUsed |
| class | CryptoHelper |
| Can encrypt and decrypt data. More... | |
| interface | ILicenseCompatibilityHandler |
| interface | ILicenseService |
| For internal use only. More... | |
| class | Keys |
| class | LicenseCompatibilityHandler |
| class | LicenseInformation |
| This class is used for both license requests and license responses. It contains the information flowing from a plugin to and from the license server. More... | |
| class | LicenseItem |
| Contains information for one single reserved licensed item. This class can be used to ear-mark the specific items to have a valid license, or are in trial mode. The items that are added above the licensed max and therefore are extra items in trial mode. The plug-in will decided how may items can be added above the licensed count, and for how long they can be in this mode before an activation is required. More... | |
| class | LicenseManager |
| The LicenseManager assist the plugins in managing licenses for a plugin or stand alone application. More... | |
| class | LicenseResponse |
| This class is used for license responses and inherits LicenseInformation. When a license response it obtained as a LicenseInformation, it can be cast to a an instance of this class to access additional license response properties. More... | |
| class | NonFipsLicenseCompatibilityHandler |
| class | OemResourceManager |
| Used internally for extranting OEM resources. Only used for light weight OEM solutions. More... | |
| class | ReservedLicenseManager |
| This class is used for handling licenses to be reserved for specific items. All the items to have a licensed reserved for them need to have a LicenseItem saved in the LicenseInformation. The LicenseItem contains the id of the item to have a license, and the current state of the license. The state can be that it is a normal license, an item in trial mode and a trial end date. The main difference between this class and the ConcurrentLicenseManager, is that the ConcurrentLicenseManager assist with checking for concurrent use of the licenses. More... | |
| class | ResolvedLicenseCount |
| Container for various license count information. More... | |
| class | SystemLicense |
| Contains information about the general license for the installed XProtect product. More... | |
| class | UnknownCompressionTypeException |
Enumerations | |
| enum | CompressionType { None = 0 , Deflate = 1 } |
| enum | EncryptionAlgorithm { None = 0 , DES = 1 , RC2 = 2 , Rijndael = 3 , TripleDES = 4 } |
