The event line is a subset of the event. The fields contained in the event line are also the fields which are searchable using the event filter VideoOS.Platform.Proxy.Alarm.EventFilter.
More...
| System.Guid | CameraId [get, set] |
| | The camera id either of the source camera or if the source is not a camera then the first related camera.
| string | CustomTag [get, set] |
| | Custom tag corresponds to Alarm.EventHeader.CustomTag.
| System.Runtime.Serialization.ExtensionDataObject | ExtensionData [get, set] |
| | Reserved for internal use.
| System.Guid | Id [get, set] |
| | Id corresponds to Alarm.EventHeader.ID.
| int | LocalId [get, set] |
| | LocalId is a human readable alarm id that is unique on a server.
| string | Message [get, set] |
| | Message corresponds to Alarm.EventHeader.Message.
| System.Guid | MessageId [get, set] |
| | The ID of the message.
| string | Name [get, set] |
| | Name corresponds to Alarm.EventHeader.Name.
| string | ObjectData [get, set] |
| | Object data is the first AnalyticsObject data in the alarm.
| string | ObjectValue [get, set] |
| | Object value is the first AnalyticsObject value in the alarm.
| string | RuleType [get, set] |
| | Rule type is the type of the first rule in the alarm.
| System.Guid | SourceId [get, set] |
| | Source id corresponds to Alarm.EventHeader.EventSource.FQID.ObjectId.
| string | SourceName [get, set] |
| | Source name corresponds to Alarm.EventHeader.EventSource.Name.
| System.DateTime | Timestamp [get, set] |
| | Timestamp corresponds to Alarm.EventHeader.Timestamp.
| string | Type [get, set] |
| | Type corresponds to Alarm.EventHeader.Type.
| string | VendorName [get, set] |
| | Vendor name corresponds to Alarm.Vendor.Name.
◆ CameraId
| System.Guid VideoOS.Platform.Proxy.Alarm.EventLine.CameraId |
getset |
◆ CustomTag
| string VideoOS.Platform.Proxy.Alarm.EventLine.CustomTag |
getset |
◆ ExtensionData
| System.Runtime.Serialization.ExtensionDataObject VideoOS.Platform.Proxy.Alarm.EventLine.ExtensionData |
getset |
◆ Id
| System.Guid VideoOS.Platform.Proxy.Alarm.EventLine.Id |
getset |
◆ LocalId
| int VideoOS.Platform.Proxy.Alarm.EventLine.LocalId |
getset |
◆ Message
| string VideoOS.Platform.Proxy.Alarm.EventLine.Message |
getset |
◆ MessageId
| System.Guid VideoOS.Platform.Proxy.Alarm.EventLine.MessageId |
getset |
◆ Name
| string VideoOS.Platform.Proxy.Alarm.EventLine.Name |
getset |
◆ ObjectData
| string VideoOS.Platform.Proxy.Alarm.EventLine.ObjectData |
getset |
◆ ObjectValue
| string VideoOS.Platform.Proxy.Alarm.EventLine.ObjectValue |
getset |
◆ RuleType
| string VideoOS.Platform.Proxy.Alarm.EventLine.RuleType |
getset |
◆ SourceId
| System.Guid VideoOS.Platform.Proxy.Alarm.EventLine.SourceId |
getset |
◆ SourceName
| string VideoOS.Platform.Proxy.Alarm.EventLine.SourceName |
getset |
◆ Timestamp
| System.DateTime VideoOS.Platform.Proxy.Alarm.EventLine.Timestamp |
getset |
◆ Type
| string VideoOS.Platform.Proxy.Alarm.EventLine.Type |
getset |
◆ VendorName
| string VideoOS.Platform.Proxy.Alarm.EventLine.VendorName |
getset |
