A utility class to build user CredentialCache and NetworkCredential.
More...
static CredentialCache | BuildCredentialCache (Uri uri, string userName, SecureString securePassword, string authenticationType) |
| Build a CredentialCache with a NetWorkCredential or DefaultCredential depending on the authenticationType string. The username can be a simple name, a domain\username or blank. Blank indicates current credentials should be used. If no domain is entered the current machine default is used.
static CredentialCache | BuildCredentialCache (Uri uri, string username, string password, string authenticationType) |
static NetworkCredential | BuildNetworkCredential (string userName, SecureString securePassword, string authenticationType) |
If no domain is entered the server machine will determine to use either it's domain or local defined user.
Notice that when creating a "Basic" NetworkCredential, it must be added into a CredentialCache before it can be used. The CredentialCache should then be used for adding servers etc.
static NetworkCredential | BuildNetworkCredential (Uri uri, string username, string password, string authenticationType) |
static NetworkCredential | GetCredential (ServerId serverId) |
| Retrieve relevant Credentials to be used for a given ServerId.
static String | GetHostName (String mixedUrl) |
| Pick out the servername from any Url or address string.
static String | GetHostNameWithoutDomain (String mixedUrl) |
| Take out any postfix domain names.
static SecureString | ToSecureString (this string unsecureString) |
| Utility method for making a SecureString from a normal string.
◆ BuildCredentialCache() [1/2]
static CredentialCache VideoOS.Platform.Login.Util.BuildCredentialCache |
Uri | uri, |
string | userName, |
SecureString | securePassword, |
string | authenticationType ) |
inlinestatic |
- Parameters
uri | The server to use this credential for |
userName | Blank or user name possibly preceded with domain name |
securePassword | Password |
authenticationType | Either "Basic" or "Negotiate" for Window type login |
- Returns
◆ BuildCredentialCache() [2/2]
Uri | uri, |
string | username, |
string | password, |
inlinestatic |
- Parameters
username | Blank or user name possibly preceded with domain name |
password | Password |
- Returns
◆ BuildNetworkCredential() [1/2]
static NetworkCredential VideoOS.Platform.Login.Util.BuildNetworkCredential |
inlinestatic |
For authenticationType AuthenticationType.External, null is returned - as NetworkCredential is not used for those users.
- Parameters
- Returns
◆ BuildNetworkCredential() [2/2]
Uri | uri, |
inlinestatic |
- Parameters
uri | Not used |
- Returns
◆ GetCredential()
static NetworkCredential VideoOS.Platform.Login.Util.GetCredential |
ServerId | serverId | ) |
inlinestatic |
- Parameters
- Returns
- NetworkCredential or null if the user is using OAuth
◆ GetHostName()
static String VideoOS.Platform.Login.Util.GetHostName |
String | mixedUrl | ) |
inlinestatic |
- Parameters
- Returns
◆ GetHostNameWithoutDomain()
static String VideoOS.Platform.Login.Util.GetHostNameWithoutDomain |
inlinestatic |
- Parameters
- Returns
◆ ToSecureString()
static SecureString VideoOS.Platform.Login.Util.ToSecureString |
this string | unsecureString | ) |
inlinestatic |
- Parameters
- Returns
