VideoOS.Platform.Login.LoginSettings Class Reference
LoginSettings contain a Token of login for one server. It needs to be renewed once in a while. More...
Public Member Functions
void FireRequestNewToken ()
 This method can be called, to ask the MIPSDK to re-login. Only used internally for revovery situations.
 LoginSettings (Uri uri, CredentialCache credentialCache, Guid guid, String serverName)
 Store login settings for either Basic or Windows login to a specific server. The Guid is allowed to be updated after construction.
 LoginSettings (Uri uri, CredentialCache credentialCache, Guid guid, String serverName, bool secureOnly)
 LoginSettings (Uri uri, CredentialCache credentialCache, Guid guid, String serverName, String serverType)
 LoginSettings (Uri uri, CredentialCache credentialCache, Guid guid, String serverName, String serverType, bool secureOnly)
 LoginSettings (Uri uri, IMipTokenCache identityTokenCache, Guid guid, string serverName, bool secureOnly)
 Create login settings to be used for login to a specific server.
 LoginSettings (Uri uri, NetworkCredential networkCredential, Guid guid, String serverName)
 Store login settings for Windows login. Please use the CredentialCache overloaded method when basic authentication is used.
 LoginSettings (Uri uri, NetworkCredential networkCredential, Guid guid, String serverName, bool secureOnly)
 LoginSettings (Uri uri, NetworkCredential networkCredential, Guid guid, String serverName, String serverType)
 LoginSettings (Uri uri, NetworkCredential networkCredential, Guid guid, String serverName, String serverType, bool secureOnly)
Static Public Member Functions
static LoginSettings GetLoginSettings (ServerId serverId)
 This method will lookup the LoginSettings based on the provided ServerId.
Public Attributes
readonly Guid InstanceGuid = Guid.NewGuid()
 Identifies the instance of this one LoginSettings.
LoginServerProductInfo ServerProductInfo = new LoginServerProductInfo()
 Contains information about the server, after logon has been performed.
Properties
CredentialCache CredentialCache [get, set]
 The Credential cache for all types of authorizations.
string FullyQualifiedUserName [get]
 Provides the fully qualified user name as required by certain server requests.
string[] GroupMemberShip [get]
 Get all the group ID's that the user is a member of. The Group ID can be both AD-groups, and internally defined groups or roles.
Guid Guid [get, set]
 The GUID of the server. Please note that it may not always be filled to start with, as we need to login to the server before the GUID is found.
IMipTokenCache IdentityTokenCache [get, set]
 The token cache from IDP server for all types of users.
bool IsBasicUser [get]
 Return true if logging in was done as basic authentication.
bool IsOAuthConnection [get]
 Returns true if we have established a connection to an OAuth server.
bool IsOAuthIdentity [get]
 Returns true if the identity is managed by an identity provider, e.g. not AD or basic user.
String Name [get, set]
 A display name for this server, or just the Uri.Host.
NetworkCredential NetworkCredential [get, set]
 The credential used when connecting with Windows, WindowsDefault or basic user authorization.
bool SecureOnly [get]
 If true, authentication over https is accepted. Can only be used for server versions 2021 R1 or newer. If false, authentication over both http and https is accepted. Can be used for any server version.
string ServerType [get, set]
 If the actual server type is known, initializing this field will speed up the login process.
string ServerWebType [get, set]
 This field identify if the server is accessed via a ASMX or SVC service.
virtual String Token [get, set]
 Hold the current valid token for the connection to a given server.
If this property is blank, then it indicates that it was not possible to get a new token, or the server has rejected any further login.
DateTime TokenTimeToLive [get, set]
 Indicates when the token is no longer valid.
May not be supported in all environments, is DateTime.MinValue when not filled.
Uri Uri [get, set]
 The URI of the server where this class apply.
Uri UriCorporate [get]
 For servers 2021 R1+, returns value of Uri property For servers older than 2021 R1, returns uri with HTTPS prefix for basic users and HTTP prefix for other users.
string UserIdentity [get]
 The Identity of the user that has logged in.
The Identity can be a user SID or a GUID if it is a basic user or OAuth user.
UserIdentification UserInformation [get]
 Contains more details about the current user. Some of the detailed fields are the same as are available in this class.
string UserName [get]
 The display name of the identity logged in, like "John Doe". For the id see UserInformation.AccountName.
Events
EventHandler RequestNewTokenEvent
 Used internally to ask MIPSDK to perform a re-login.
EventHandler TokenChangedEvent
 This event is fired whenever the Token has changed. This is used for active sessions that needs to be updated on the fly, this event can be used to re-pass on the token as it is renewed.
Detailed Description
Constructor & Destructor Documentation
◆ LoginSettings() [1/9]
VideoOS.Platform.Login.LoginSettings.LoginSettings ( Uri uri,
Guid guid,
String serverName )
inline
Parameters
uri
credentialCache
guid
serverName
◆ LoginSettings() [2/9]
Guid guid,
String serverName,
String serverType )
inline
Parameters
uri
credentialCache
guid
serverName
serverType
◆ LoginSettings() [3/9]
Guid guid,
String serverName )
inline
Parameters
uri
networkCredential
guid
serverName
◆ LoginSettings() [4/9]
Guid guid,
String serverName,
String serverType )
inline
Parameters
uri
networkCredential
guid
serverName
serverType
◆ LoginSettings() [5/9]
Guid guid,
String serverName,
bool secureOnly )
inline
Parameters
uriThe URI of the server where this class apply
credentialCacheThe Credential cache for all types of authorizations
guidThe GUID of the server
serverNameA display name for this server, or just the Uri.Host
secureOnlyIf true, only authentication over https is accepted. Can only be used for server versions 2021 R1 or newer. If false, authentication over both http and https is accepted. Can be used for any server version.
◆ LoginSettings() [6/9]
Guid guid,
String serverName,
String serverType,
bool secureOnly )
inline
Parameters
serverTypeIf the actual server type is known, initializing this field will speed up the login process
◆ LoginSettings() [7/9]
Guid guid,
string serverName,
bool secureOnly )
inline
Parameters
identityTokenCacheThe token cache from IDP server for all types of users
Exceptions
ArgumentMIPExceptionThrown when uri scheme is not https and secureOnly is set to true
◆ LoginSettings() [8/9]
Guid guid,
String serverName,
bool secureOnly )
inline
Parameters
networkCredentialThe credential used when connecting with Windows or WindowsDefault authorization
◆ LoginSettings() [9/9]
Guid guid,
String serverName,
String serverType,
bool secureOnly )
inline
Parameters
Member Function Documentation
◆ FireRequestNewToken()
void VideoOS.Platform.Login.LoginSettings.FireRequestNewToken ( )
inline
◆ GetLoginSettings()
static LoginSettings VideoOS.Platform.Login.LoginSettings.GetLoginSettings ( ServerId serverId)
inlinestatic
Parameters
serverId
Exceptions
ArgumentExceptionIf the LoginSettings could not be found.
Returns
Member Data Documentation
◆ InstanceGuid
readonly Guid VideoOS.Platform.Login.LoginSettings.InstanceGuid = Guid.NewGuid()
◆ ServerProductInfo
LoginServerProductInfo VideoOS.Platform.Login.LoginSettings.ServerProductInfo = new LoginServerProductInfo()
Property Documentation
◆ CredentialCache
CredentialCache VideoOS.Platform.Login.LoginSettings.CredentialCache
getset
◆ FullyQualifiedUserName
string VideoOS.Platform.Login.LoginSettings.FullyQualifiedUserName
get
For AD users: domain\accountname
For Basic users: [BASIC]\accountname
For Oauth users: accountname
For 3rd party identity provider users: [BASIC]\accountname
◆ GroupMemberShip
string [] VideoOS.Platform.Login.LoginSettings.GroupMemberShip
get
◆ Guid
Guid VideoOS.Platform.Login.LoginSettings.Guid
getset
◆ IdentityTokenCache
IMipTokenCache VideoOS.Platform.Login.LoginSettings.IdentityTokenCache
getset
◆ IsBasicUser
bool VideoOS.Platform.Login.LoginSettings.IsBasicUser
get
◆ IsOAuthConnection
bool VideoOS.Platform.Login.LoginSettings.IsOAuthConnection
get
◆ IsOAuthIdentity
bool VideoOS.Platform.Login.LoginSettings.IsOAuthIdentity
get
◆ Name
String VideoOS.Platform.Login.LoginSettings.Name
getset
◆ NetworkCredential
NetworkCredential VideoOS.Platform.Login.LoginSettings.NetworkCredential
getset
◆ SecureOnly
bool VideoOS.Platform.Login.LoginSettings.SecureOnly
get
◆ ServerType
string VideoOS.Platform.Login.LoginSettings.ServerType
getset
◆ ServerWebType
string VideoOS.Platform.Login.LoginSettings.ServerWebType
getset
When set to blank - the access type is not yet identified.
◆ Token
virtual String VideoOS.Platform.Login.LoginSettings.Token
getset
◆ TokenTimeToLive
DateTime VideoOS.Platform.Login.LoginSettings.TokenTimeToLive
getset
◆ Uri
Uri VideoOS.Platform.Login.LoginSettings.Uri
getset
◆ UriCorporate
Uri VideoOS.Platform.Login.LoginSettings.UriCorporate
get
◆ UserIdentity
string VideoOS.Platform.Login.LoginSettings.UserIdentity
get
◆ UserInformation
UserIdentification VideoOS.Platform.Login.LoginSettings.UserInformation
get
◆ UserName
string VideoOS.Platform.Login.LoginSettings.UserName
get
Event Documentation
◆ RequestNewTokenEvent
EventHandler VideoOS.Platform.Login.LoginSettings.RequestNewTokenEvent
◆ TokenChangedEvent
EventHandler VideoOS.Platform.Login.LoginSettings.TokenChangedEvent
Note: Use can also register for the LoginTokenChangedIndication for getting same information.
