| const string | Address = "Address" |
| const string | Channel = "Channel" |
| | Identifies the port this device is located at on the hardware. For Video Servers this would often be e.g. be from "0" to "3" for a 4 channel device.
| const string | ConfigurationUrl = "ConfigurationUrl" |
| const string | DBID = "DBID" |
| const string | Description = "Description" |
| const string | DriverGroup = "DriverGroup" |
| const string | DriverNumber = "DriverNumber" |
| const string | EdgeStorageEnabled = "EdgeStorageEnabled" |
| const string | Enabled = "Enabled" |
| | Identify if the item is enabled or disabled. If "Enabled" property is not in dictionary, the item is by default enabled, when value is "No" or "False" the item is disabled.
| const string | Encrypt = "__Encrypt" |
| | Identify if the item should be encrypted in the database. If "Encrypt" property is not set, the default is to not encrypt. When value is "True", the item properties will be encrypted in the database.
| const string | Focus = "focus" |
| const string | FPS = "FPS" |
| const string | Ipix = "Ipix" |
| const string | IpixData = "IpixData" |
| const string | Iris = "iris" |
| const string | LastModified = "LastModified" |
| const string | Location = "Location" |
| const string | MacAddress = "MacAddress" |
| const string | Master = "Master" |
| const string | Pan = "pan" |
| const string | PanoramicLens = "PanoramicLens" |
| const string | PanoramicLensData = "PanoramicLensData" |
| const string | Password = "Password" |
| const string | Prebufferms = "Prebufferms" |
| const string | ProductID = "ProductID" |
| const string | ProductName = "ProductName" |
| const string | ProductVersion = "ProductVersion" |
| const string | PTZ = "PTZ" |
| const string | PTZCenter = "PTZCenter" |
| const string | PTZDiagonal = "PTZDiagonal" |
| const string | PTZHome = "PTZHome" |
| const string | PTZRectangle = "PTZRectangle" |
| const string | RecordingFPS = "RecordingFPS" |
| const string | ServerType = "ServerType" |
| const string | ShortCut = "ShortCut" |
| const string | SLC = "SLC" |
| const string | StorageId = "StorageId" |
| const string | StorageName = "StorageName" |
| const string | Tilt = "tilt" |
| const string | UserName = "UserName" |
| const string | UsingPrebuffer = "UsingPrebuffer" |
| const string | WebServerURI = "WebServerURI" |
| const string | Zoom = "zoom" |
