VideoOS.Platform.Data.BitmapData Class Referenceabstract
Contains the Bitmap information. More...
Inheritance diagram for VideoOS.Platform.Data.BitmapData:
VideoOS.Platform.CroppingInfo
Public Member Functions
BitmapSource ConvertToBitmapSource ()
 Utility method used to convert the contained bitmap into a BitmapSource which can be directly applied as a source to an WPF Image control.
void Dispose ()
 Call this to dispose the related memory (Unmanaged)
void Dispose (bool native)
 Call this to dispose the related memory.
Bitmap GetBitmap ()
 Get a Bitmap class pointing to the original plane data. The resulting Bitmap needs to be Disposed.
byte[] GetPlaneBytes (int plane)
 Returns the bytes in one plane.
Int32 GetPlaneHeight (int plane)
 Get the height of a given plane.
IntPtr GetPlanePointer (int plane)
 Get a pointer to the start of a plane. The pointer is pointing into unmanaged memory!
Int32 GetPlaneStride (int plane)
 Get the width of one scan line in bytes (including filler bytes)
Int32 GetPlaneWidth (int plane)
 Get the width of one plane.
Public Attributes
DateTime DateTime
 The date and time the image was taken.
bool IsNextAvailable
 Defines if the NextDateTime is filled.
bool IsPreviousAvailable
 Defines if the PreviousDateTime is filled.
DateTime NextDateTime
 The time stamp for the next image.
This field is not always available.
DateTime PreviousDateTime
 The time stamp for the previous image.
Properties
BitmapColorSpace ColorSpace [get]
 For BitmapFormat of types YCbCr, the BitmapColorSpace defines what color space is used.
BitmapFormat Format [get]
 The format of the received bitmap.
virtual String HardwareDecodingStatus [get, set]
 Defines how the decoding of the current frame is performed.
Values can be:
'hardware' - Decoded by GPU
'software' - Decoded by Intel Media SDK
'fallback' - Decoded by Intel Media SDK, even though it was requested to be Hardware (or Auto)
'ipp' - Decoded by Intel UMC
IDisposable ObjectToDispose [get, set]
 Reserved for internal use. DO NOT ACCESS THIS FIELD!
double PixelAspectRatio [get]
 How each pixel should be spaced.
- Properties inherited from VideoOS.Platform.CroppingInfo
double CropHeight [get, set]
 When the CroppingDefined is true, this field contains the cropping definition. The definition contains the same values as used on the SetCropping call.
bool CroppingDefined [get, set]
 Is set to true if the returned content has been cropped.
double CropWidth [get, set]
double CropX [get, set]
double CropY [get, set]
Detailed Description
Member Function Documentation
◆ ConvertToBitmapSource()
BitmapSource VideoOS.Platform.Data.BitmapData.ConvertToBitmapSource ( )
inline
Returns
◆ Dispose() [1/2]
void VideoOS.Platform.Data.BitmapData.Dispose ( )
inline
◆ Dispose() [2/2]
void VideoOS.Platform.Data.BitmapData.Dispose ( bool native)
inline
Parameters
nativeIgnored
◆ GetBitmap()
Bitmap VideoOS.Platform.Data.BitmapData.GetBitmap ( )
inline
Returns
◆ GetPlaneBytes()
byte[] VideoOS.Platform.Data.BitmapData.GetPlaneBytes ( int plane)
abstract
Parameters
plane
Returns
◆ GetPlaneHeight()
Int32 VideoOS.Platform.Data.BitmapData.GetPlaneHeight ( int plane)
abstract
Parameters
plane
Returns
◆ GetPlanePointer()
IntPtr VideoOS.Platform.Data.BitmapData.GetPlanePointer ( int plane)
abstract
Parameters
plane
Returns
◆ GetPlaneStride()
Int32 VideoOS.Platform.Data.BitmapData.GetPlaneStride ( int plane)
abstract
Parameters
plane
Returns
◆ GetPlaneWidth()
Int32 VideoOS.Platform.Data.BitmapData.GetPlaneWidth ( int plane)
abstract
Parameters
plane
Returns
Member Data Documentation
◆ DateTime
DateTime VideoOS.Platform.Data.BitmapData.DateTime
◆ IsNextAvailable
bool VideoOS.Platform.Data.BitmapData.IsNextAvailable
◆ IsPreviousAvailable
bool VideoOS.Platform.Data.BitmapData.IsPreviousAvailable
◆ NextDateTime
DateTime VideoOS.Platform.Data.BitmapData.NextDateTime
◆ PreviousDateTime
DateTime VideoOS.Platform.Data.BitmapData.PreviousDateTime
Property Documentation
◆ ColorSpace
BitmapColorSpace VideoOS.Platform.Data.BitmapData.ColorSpace
getabstract
◆ Format
BitmapFormat VideoOS.Platform.Data.BitmapData.Format
getabstract
◆ HardwareDecodingStatus
virtual String VideoOS.Platform.Data.BitmapData.HardwareDecodingStatus
getset
Values can be:
◆ ObjectToDispose
IDisposable VideoOS.Platform.Data.BitmapData.ObjectToDispose
getset
◆ PixelAspectRatio
double VideoOS.Platform.Data.BitmapData.PixelAspectRatio
getabstract
