VideoOS.Platform.Data.AnalyticsEvent Class Reference
An implementation of the BaseEvent with more relevant information when an Analytics oriented event has occurred. More...
Inheritance diagram for VideoOS.Platform.Data.AnalyticsEvent:
VideoOS.Platform.Data.BaseEvent
Properties
uint Count [get, set]
 The count value, if the analytics event is a counting events. Default: 0 (no count).
string Description [get, set]
 The description of the analytics event.
System.DateTime EndTime [get, set]
 The end time of the analytics event, if it takes place over a period of time.
string Location [get, set]
 The location of the analytics event (this will typically be the same as the camera's location).
AnalyticsObjectList ObjectList [get, set]
 The ObjectList, containing information about the detected object(s) in the scene.
ReferenceList ReferenceList [get, set]
 The ReferenceList, containing any number of references to other entities in the system, e.g. cameras, by FQID.
RuleList RuleList [get, set]
 The RuleList, containing information contains information about the rule(s), which triggered the analytics event.
SnapshotList SnapshotList [get, set]
 The SnapshotList, containing any number of images related to the analytics event. If the Source is a camera, it is not neccesary to attach a snapshot from that camera at the time of the analytics event.
System.DateTime StartTime [get, set]
 The start time of the analytics event, if it takes place over a period of time.
Vendor Vendor [get, set]
 The Vendor, containing information about the analytics vendor including any custom data.
- Properties inherited from VideoOS.Platform.Data.BaseEvent
EventHeader EventHeader [get, set]
 The EventHeader describing the source, timestamp and much more for this event.
ExtensionDataObject ExtensionData [get, set]
Additional Inherited Members
- Public Member Functions inherited from VideoOS.Platform.Data.BaseEvent
 BaseEvent ()
Detailed Description
Property Documentation
◆ Count
uint VideoOS.Platform.Data.AnalyticsEvent.Count
getset
◆ Description
string VideoOS.Platform.Data.AnalyticsEvent.Description
getset
◆ EndTime
System.DateTime VideoOS.Platform.Data.AnalyticsEvent.EndTime
getset
◆ Location
string VideoOS.Platform.Data.AnalyticsEvent.Location
getset
◆ ObjectList
AnalyticsObjectList VideoOS.Platform.Data.AnalyticsEvent.ObjectList
getset
◆ ReferenceList
ReferenceList VideoOS.Platform.Data.AnalyticsEvent.ReferenceList
getset
◆ RuleList
RuleList VideoOS.Platform.Data.AnalyticsEvent.RuleList
getset
◆ SnapshotList
SnapshotList VideoOS.Platform.Data.AnalyticsEvent.SnapshotList
getset
◆ StartTime
System.DateTime VideoOS.Platform.Data.AnalyticsEvent.StartTime
getset
◆ Vendor
Vendor VideoOS.Platform.Data.AnalyticsEvent.Vendor
getset
