VideoOS.Platform.ConfigurationItems.RecordingServer Class Reference
More...
Inheritance diagram for VideoOS.Platform.ConfigurationItems.RecordingServer:
VideoOS.Platform.ConfigurationItems.IConfigurationItem VideoOS.Platform.ConfigurationItems.IConfigurationItem VideoOS.Platform.ConfigurationItems.IConfigurationChildItem VideoOS.Platform.ConfigurationItems.IConfigurationChildItem
Public Member Functions
AddHardwareServerTask AddHardware ()
 Add new hardware.
ServerTask AddHardware (ChildTaskDetail hardwareScanResult, String customData=null)
 Add new hardware using the ChildTaskDetail returned by one of the hardware scan methods.
ServerTask AddHardware (String hardwareAddress, String hardwareDriverPath, String userName, String password)
 Add new hardware
Please consider using secure version taking SecureString instead.
ServerTask AddHardware (String hardwareAddress, String hardwareDriverPath, String userName, System.Security.SecureString password)
 Add new hardware.
ServerTask AddHardware (String hardwareAddress, String hardwareDriverPath, String userName, System.Security.SecureString password, String customData)
 Add new hardware.
CreateDirectoryOnRecorderServerTask CreateDirectoryOnRecorder ()
 Create directory on recorder.
ServerTask CreateDirectoryOnRecorder (String newDirectoryFullName)
ClassCollectionServerTask GetOtherDevicesWithMediaOnRecorder ()
 Get devices with media on recording server.
HardwareScanServerTask HardwareScan ()
 Detect hardware driver.
ServerTask HardwareScan (String hardwareAddress, String hardwareDriverIds, String userName, String password, bool useDefaultCredentials)
ClassCollectionServerTask HardwareScan (String hardwareAddress, String hardwareDriverIds, String userName, System.Security.SecureString password, bool useDefaultCredentials)
HardwareScanExpressServerTask HardwareScanExpress ()
 Detect hardware.
ServerTask HardwareScanExpress (String primaryUserName, String primaryPassword, String secondaryUserName, String secondaryPassword, String tertiaryUserName, String tertiaryPassword, bool useDefaultCredentials)
 Detect hardware.
ClassCollectionServerTask HardwareScanExpress (String primaryUserName, String primaryPassword, String secondaryUserName, String secondaryPassword, String tertiaryUserName, String tertiaryPassword, bool useDefaultCredentials, bool useSecurePort)
 Detect hardware.
ClassCollectionServerTask LoadTasks ()
 Load the tasks existing on the server.
ServerTask LoadTasks (String taskType)
 Load the tasks existing on the server. Supported from VMS 2025 R2.
ReadDirectoriesOnRecorderServerTask ReadDirectoriesOnRecorder ()
 Read directories on recorder.
ServerTask ReadDirectoriesOnRecorder (String currentDirectory)
ServerTask ReadDrivesOnRecorder ()
 Read drives on recorder.
 RecordingServer (FQID fqid)
 Construct the class from a MIP FQID - note that not all configuration items have a corresponding FQID.
 RecordingServer (ServerId serverId, ConfigurationItem recordingServer)
 Construct the class from serverId of the Management Server that owns the configuration, and the already returned ConfigurationItem.
 RecordingServer (ServerId serverId, string path)
 Construct the class from serverId of the Management Server that owns the configuration, and the path of the item.
- Public Member Functions inherited from VideoOS.Platform.ConfigurationItems.IConfigurationItem
void ClearChildrenCache ()
 Clear the internal cache of children. Can be used to force a new set of children to be fetched from the server at next access.
ServerTask ExecuteMethod (string methodId)
 Execute the provided method. The method id must be one of the defined values in the Methods property.
void FillChildren (string[] itemTypes)
 Fill all children and grand-children - as long as the itemtype is contained in itemType parameter.
void FillChildren (string[] itemTypes, ItemFilter[] itemFilters)
 Fill all children and grand-children - as long as the itemtype is contained in itemType parameter and filters match. If multiple filters are defined for same itemtype, all must match for the item to be included ('and' operation).
If no filter is defined for an ItemType, then all items of that type is filled.
void Save ()
 Will save all updated values to server.
ValidateResult ValidateItem ()
 Validate the current content.
- Public Member Functions inherited from VideoOS.Platform.ConfigurationItems.IConfigurationChildItem
string GetProperty (string key)
 Return a property value as string, if key is not found the return value will be null.
ICollection< string > GetPropertyKeys ()
 Get a collection of all available property keys.
List< ValueTypeInfoGetValueTypeInfoList (string propertyKey)
 Get defined ValueTypeInfo for a given property. If no ValueTypeInfo is available, an empty list is returned.
void SetProperty (string key, string content)
 Sets the value of a property (all is string format here)
override string ToString ()
 Display the 'DisplayName' is the default ToString()
Properties
string ActiveWebServerUri [get]
 Active Public Web server URI . Currently active public web server address.
bool Enabled [get, set]
 Indicate if this item is active in the VMS system, e.g. enabled.
HardwareDriverFolder HardwareDriverFolder [get]
 Return the single folder item of the given ItemType.
HardwareFolder HardwareFolder [get]
string HostName [get]
 Host name. Host name of the recording server (deprecated, use 'Web Server Uri')
string Id [get]
 ID.
DateTime LastModified [get]
 Last modified.
string MulticastServerAddress [get, set]
 Multicast server address.
int PortNumber [get]
 Port number. Port number of the recording server (deprecated, use 'Web Server Uri')
bool PublicAccessEnabled [get, set]
 Public address enabled. Enable or disable the public address.
string PublicWebserverHostName [get, set]
 Public recording server address.
int PublicWebserverPort [get, set]
 Public recording server port.
RecordingServerFailoverFolder RecordingServerFailoverFolder [get]
RecordingServerMulticastFolder RecordingServerMulticastFolder [get]
bool ShutdownOnStorageFailure [get, set]
 Shutdown on storage failure.
StorageFolder StorageFolder [get]
int SynchronizationTime [get, set]
 Synchronization time. Defines when the configuration is synchronized with the hardware. Define when to start the synchronization by entering a number of minutes after midnight (local time of recording server). The default value is -1, which means no synchronization.
string TimeZoneName [get]
 Time zone.
string Version [get]
 Version.
string WebServerUri [get]
 Web Server Uri. Web Server Uri of the recording server.
- Properties inherited from VideoOS.Platform.ConfigurationItems.IConfigurationItem
Guid Guid [get]
 Returns the id property or part of the path, when available. When no id is available this will be Guid.Empty. This is relevant for some items of ItemCategory.ChildItem where no property with key = "Id" exists and path does not contains a guid.
Collection< string > Methods [get]
 The available methods for this class.
- Properties inherited from VideoOS.Platform.ConfigurationItems.IConfigurationChildItem
string Description [get, set]
 Description.
virtual string DisplayName [get]
 Name of this ConfigurationItem in user readable format. Usually the same as property with key = "Name".
string ItemCategory [get]
 Return the item category for this item. This can be used to understand how multiple items are fetched and saved together. Only ItemCategory == 'Item' can be saved.
string Name [get, set]
 Name.
string ParentItemPath [get]
 Get hold of the next real parent path, e.g. skip any 'Folder' type parent.
string ParentPath [get]
 The path for the parent of this ConfigurationItem.
string Path [get]
 The identification of this item.
ServerId ServerId [get, set]
 Contains the ServerId of the Management Server holding this item.
Detailed Description
Constructor & Destructor Documentation
◆ RecordingServer() [1/3]
VideoOS.Platform.ConfigurationItems.RecordingServer.RecordingServer ( ServerId serverId,
ConfigurationItem recordingServer )
inline
Parameters
serverIdIdentify the Management Server that owns the configuration
recordingServerThe ConfigurationItem returned from elsewhere
Exceptions
ArgumentMIPExceptionWhen LoginSettings not found for serverId
◆ RecordingServer() [2/3]
string path )
inline
This construction will contact the server and read the specified item.
Parameters
pathThe path of a specific item
Exceptions
MIPExceptionRepresents a number of possible exceptions. Possible exceptions can be found via the inherited exceptions - like PathNotFoundMIPException
◆ RecordingServer() [3/3]
VideoOS.Platform.ConfigurationItems.RecordingServer.RecordingServer ( FQID fqid)
inline
Parameters
fqidIdentify the MIP item
Exceptions
Member Function Documentation
◆ AddHardware() [1/5]
AddHardwareServerTask VideoOS.Platform.ConfigurationItems.RecordingServer.AddHardware ( )
inline
Add new hardware.
◆ AddHardware() [2/5]
ServerTask VideoOS.Platform.ConfigurationItems.RecordingServer.AddHardware ( ChildTaskDetail hardwareScanResult,
String customData = null )
inline
Parameters
hardwareScanResultAddress
customDataCustom data - can be left empty
◆ AddHardware() [3/5]
ServerTask VideoOS.Platform.ConfigurationItems.RecordingServer.AddHardware ( String hardwareAddress,
String userName,
String password )
inline
Add new hardware
Parameters
hardwareAddressAddress
hardwareDriverPathHardware driver
userNameUser name
passwordPassword
◆ AddHardware() [4/5]
String userName,
System.Security.SecureString password )
inline
Add new hardware.
Parameters
userNameUser name
passwordPassword
◆ AddHardware() [5/5]
String userName,
String customData )
inline
Add new hardware.
Parameters
hardwareAddressAddress. The base address of the hardware. If the property HttpsEnabled exists in the general settings of this hardware and has the value Yes, the address should be modified to use HTTPS and the port defined in the property named HttpsPort under general settings.
hardwareDriverPathHardware driver. Contains the path/ID of the device driver used for the hardware. Driver can be looked up under the recording server.
userNameUser name. User name for the hardware
passwordPassword. Password for hardware
customDataCustom data. Data to be passed on to driver during add hardware process
◆ CreateDirectoryOnRecorder() [1/2]
CreateDirectoryOnRecorderServerTask VideoOS.Platform.ConfigurationItems.RecordingServer.CreateDirectoryOnRecorder ( )
inline
◆ CreateDirectoryOnRecorder() [2/2]
ServerTask VideoOS.Platform.ConfigurationItems.RecordingServer.CreateDirectoryOnRecorder ( String newDirectoryFullName)
inline
Parameters
newDirectoryFullNameFull path of new directory. Full path including name of directory to create on the recorder
◆ GetOtherDevicesWithMediaOnRecorder()
ClassCollectionServerTask VideoOS.Platform.ConfigurationItems.RecordingServer.GetOtherDevicesWithMediaOnRecorder ( )
inline
◆ HardwareScan() [1/3]
HardwareScanServerTask VideoOS.Platform.ConfigurationItems.RecordingServer.HardwareScan ( )
inline
◆ HardwareScan() [2/3]
ServerTask VideoOS.Platform.ConfigurationItems.RecordingServer.HardwareScan ( String hardwareAddress,
String userName,
String password,
bool useDefaultCredentials )
inline
Parameters
hardwareDriverIdsHardware driver IDs
userNameUser name
passwordPassword
useDefaultCredentialsUse default credentials
◆ HardwareScan() [3/3]
ClassCollectionServerTask VideoOS.Platform.ConfigurationItems.RecordingServer.HardwareScan ( String hardwareAddress,
String userName,
inline
Parameters
hardwareDriverIdsHardware driver IDs. Hardware driver IDs separated by ';'. Example: "48;13;25". Specify an empty string to include all drivers.
useDefaultCredentialsUse default credentials. Specify if you want to use the default hardware credentials or use another one.
◆ HardwareScanExpress() [1/3]
HardwareScanExpressServerTask VideoOS.Platform.ConfigurationItems.RecordingServer.HardwareScanExpress ( )
inline
Detect hardware.
◆ HardwareScanExpress() [2/3]
ServerTask VideoOS.Platform.ConfigurationItems.RecordingServer.HardwareScanExpress ( String primaryUserName,
inline
Detect hardware.
Parameters
primaryUserNameUser name
primaryPasswordPassword
secondaryUserNameUser name
secondaryPasswordPassword
tertiaryUserNameUser name
tertiaryPasswordPassword
◆ HardwareScanExpress() [3/3]
ClassCollectionServerTask VideoOS.Platform.ConfigurationItems.RecordingServer.HardwareScanExpress ( String primaryUserName,
bool useSecurePort )
inline
Detect hardware.
Parameters
primaryUserNameUser name. User name for the hardware
primaryPasswordPassword. Password for hardware
secondaryUserNameUser name. User name for the hardware
secondaryPasswordPassword. Password for hardware
tertiaryUserNameUser name. User name for the hardware
tertiaryPasswordPassword. Password for hardware
useSecurePortUse HTTPS. Specify if you want to use the HTTPS protocol to connect to the hardware.
◆ LoadTasks() [1/2]
ClassCollectionServerTask VideoOS.Platform.ConfigurationItems.RecordingServer.LoadTasks ( )
inline
◆ LoadTasks() [2/2]
ServerTask VideoOS.Platform.ConfigurationItems.RecordingServer.LoadTasks ( String taskType)
inline
Parameters
taskTypeTask type. Optional parameter for specifying the type of tasks to return
◆ ReadDirectoriesOnRecorder() [1/2]
ReadDirectoriesOnRecorderServerTask VideoOS.Platform.ConfigurationItems.RecordingServer.ReadDirectoriesOnRecorder ( )
inline
◆ ReadDirectoriesOnRecorder() [2/2]
ServerTask VideoOS.Platform.ConfigurationItems.RecordingServer.ReadDirectoriesOnRecorder ( String currentDirectory)
inline
Parameters
currentDirectoryCurrent directory. Current directory on the recorder
◆ ReadDrivesOnRecorder()
ServerTask VideoOS.Platform.ConfigurationItems.RecordingServer.ReadDrivesOnRecorder ( )
inline
Property Documentation
◆ ActiveWebServerUri
string VideoOS.Platform.ConfigurationItems.RecordingServer.ActiveWebServerUri
get
◆ Enabled
bool VideoOS.Platform.ConfigurationItems.RecordingServer.Enabled
getset
◆ HardwareDriverFolder
HardwareDriverFolder VideoOS.Platform.ConfigurationItems.RecordingServer.HardwareDriverFolder
get
◆ HardwareFolder
HardwareFolder VideoOS.Platform.ConfigurationItems.RecordingServer.HardwareFolder
get
◆ HostName
string VideoOS.Platform.ConfigurationItems.RecordingServer.HostName
get
◆ Id
string VideoOS.Platform.ConfigurationItems.RecordingServer.Id
get
ID.
◆ LastModified
DateTime VideoOS.Platform.ConfigurationItems.RecordingServer.LastModified
get
Last modified.
◆ MulticastServerAddress
string VideoOS.Platform.ConfigurationItems.RecordingServer.MulticastServerAddress
getset
◆ PortNumber
int VideoOS.Platform.ConfigurationItems.RecordingServer.PortNumber
get
◆ PublicAccessEnabled
bool VideoOS.Platform.ConfigurationItems.RecordingServer.PublicAccessEnabled
getset
◆ PublicWebserverHostName
string VideoOS.Platform.ConfigurationItems.RecordingServer.PublicWebserverHostName
getset
◆ PublicWebserverPort
int VideoOS.Platform.ConfigurationItems.RecordingServer.PublicWebserverPort
getset
◆ RecordingServerFailoverFolder
RecordingServerFailoverFolder VideoOS.Platform.ConfigurationItems.RecordingServer.RecordingServerFailoverFolder
get
◆ RecordingServerMulticastFolder
RecordingServerMulticastFolder VideoOS.Platform.ConfigurationItems.RecordingServer.RecordingServerMulticastFolder
get
◆ ShutdownOnStorageFailure
bool VideoOS.Platform.ConfigurationItems.RecordingServer.ShutdownOnStorageFailure
getset
◆ StorageFolder
StorageFolder VideoOS.Platform.ConfigurationItems.RecordingServer.StorageFolder
get
◆ SynchronizationTime
int VideoOS.Platform.ConfigurationItems.RecordingServer.SynchronizationTime
getset
◆ TimeZoneName
string VideoOS.Platform.ConfigurationItems.RecordingServer.TimeZoneName
get
Time zone.
◆ Version
string VideoOS.Platform.ConfigurationItems.RecordingServer.Version
get
Version.
◆ WebServerUri
string VideoOS.Platform.ConfigurationItems.RecordingServer.WebServerUri
get
