VideoOS.Platform.ConfigurationItems.AddStorageServerTask Class Reference
Add storage. More...
Inheritance diagram for VideoOS.Platform.ConfigurationItems.AddStorageServerTask:
VideoOS.Platform.ConfigurationItems.ServerTask
Public Member Functions
ServerTask Execute ()
 Call this method to let the server execute when the properties have been updated.
The returned ServerTask can be used to inspect the result.
- Public Member Functions inherited from VideoOS.Platform.ConfigurationItems.ServerTask
ServerTask ExecuteDefault ()
 Will execute the first available method. Can be called when multiple steps are involved in changing values in the properties.
ServerTask ExecuteMethod (string methodId)
 Execute the provided method. The method id must be one of the defined values in the Methods property.
string GetProperty (string key)
 Return a property value as string, if key is not found the return value will be null.
ICollection< string > GetPropertyKeys ()
 Gets a collection of all available property keys.
void GetTask (string path)
 Use this method once, when the InvokeResult has placed the task path in a property with another name than 'Path'.
List< ValueTypeInfoGetValueTypeInfoList (string propertyKey)
 Gets a list of defined ValueTypeInfo for a given property.
If no ValueTypeInfo is available, an empty list is returned.
void SetProperty (string key, string content)
 Sets the value of a property (all is string format here)
void UpdateState ()
 Calls the server to get the fields updated, when the progress is < 100.
ValidateResult ValidateItem ()
 Validate the current content.
Properties
string Description [get, set]
 Description.
string DiskPath [get, set]
 Path. Contains the path to the storage disk.
int MaxSize [get, set]
 Max size (in MB). The maximum size of the recording storage in MB. The value have to be between 1 and 1099511627776 (1 exabyte). By default, the value is set to 1024, which is 1 GB.
string Name [get, set]
 Name.
int RetainMinutes [get, set]
 Retention time. The number of minutes that must elapse before data are deleted or archived. The value that specifies the retention period in minutes. The value have to be between 1 and 525600000 (365000 days). By default, the value is 1440, which is 1 day.
bool Signing [get, set]
 Signing. Specifies if database should be signed.
- Properties inherited from VideoOS.Platform.ConfigurationItems.ServerTask
String ErrorCode [get]
 If state is Error the ErrorCode explains what went wrong.
String ErrorText [get]
 When state is Error the ErrorState TBD.
string ItemType [get]
 Returns the ItemType of the underlayng ConfigurationItem, usually InvokeResult or InvokeInfo.
Collection< string > Methods [get]
 The available methods for this task.
string Path [get]
 The path of an item, when relevant. Usually available after adding a ConfigurationItem.
int Progress [get]
 Defines the progress of the server task. When Progress is 100, or state is Success or Error - the task is complete.
StateEnum State [get]
 Defines the current state of this task.
Detailed Description
Add storage.
Member Function Documentation
◆ Execute()
ServerTask VideoOS.Platform.ConfigurationItems.AddStorageServerTask.Execute ( )
inline
Property Documentation
◆ Description
string VideoOS.Platform.ConfigurationItems.AddStorageServerTask.Description
getset
Description.
◆ DiskPath
string VideoOS.Platform.ConfigurationItems.AddStorageServerTask.DiskPath
getset
◆ MaxSize
int VideoOS.Platform.ConfigurationItems.AddStorageServerTask.MaxSize
getset
◆ Name
string VideoOS.Platform.ConfigurationItems.AddStorageServerTask.Name
getset
Name.
◆ RetainMinutes
int VideoOS.Platform.ConfigurationItems.AddStorageServerTask.RetainMinutes
getset
◆ Signing
bool VideoOS.Platform.ConfigurationItems.AddStorageServerTask.Signing
getset
