The ViewItemWpfUserControl is the WPF version of the ViewItemUserControl. It is instantiated for every position it is created on the current visible view. When a user select another View or ViewLayout, this class will be disposed. No permanent settings can be saved in this class. The Init() method is called when the class is initiated and handle has been created for the UserControl. Please perform resource initialization in this method.
If Message communication is performed, register the MessageReceivers during the Init() method and UnRegister the receivers during the Close() method.
The Close() method can be used to Dispose resources in a controlled manor.
Mouse events not used by this control, should be passed on to the Smart Client by issuing the following methods:
FireClickEvent() for single click
FireDoubleClickEvent() for double click
The single click will be interpreted by the Smart Client as a selection of the item, and the double click will be interpreted to expand the current viewitem to fill the entire View.
More...
virtual void | Close () |
| Method that is called when the view item is closed. The view item should free all resources when the method is called.
virtual void | Init () |
| Method that is called immediately after the view item is displayed.
virtual void | Print () |
| Overloaded method of Print, where the information parameter is blank.
virtual void | Print (string name, string information) |
| Same as overloaded Print method, with cameraName empty.
virtual void | Print (string name, string information, string cameraName) |
| Method that is called when print is activated while the content holder is selected.
| ViewItemWpfUserControl () |
virtual double | CalculateHeaderFontSize [get] |
| Calculate what font size is used in the header for a Camera View Item. This can used to make a similar header in own ViewItem.
virtual int | CalculateHeaderHeight [get] |
| Calculate the height of a Camera View Item. This can used to make a similar header in own ViewItem.
virtual bool | Hidden [get, set] |
| Gets or sets the hidden status on the content holder (e.g. the view item is set to be hidden when another view item is maximized). This status should never be set by the content holder.
virtual bool | Maximizable [get] |
| Gets boolean indicating whether the content holder can be maximized or not. The Maximized property of a non-maximizable content holder will never be set to true. The content holder should implement the click and double click events even if it is not maximizable.
virtual bool | Maximized [get, set] |
| Gets or sets the maximized status on the content holder. This status should never be set directly by the content holder, but instead the content holder should request to be maximized and restored by using the MaximizeRequestEvent and RestoreRequestEvent events.
virtual bool | Selectable [get] |
| Gets boolean indicating whether the content holder can be selectable or not. The Selected property of a non-selectable content holder will never be set to true. The content holder should implement the click and double click events even if it is not selectable.
virtual bool | Selected [get, set] |
| Gets or sets the selected status on the content holder. This status should never be set directly by the content holder, but instead the content holder should request to be selected by using the SelectRequestEvent event.
virtual bool | ShowToolbar [get] |
| Tells the Smart Client if the toolbar should pop up over the ViewItem, when the mouse hover over this ViewItem.
For MIP Plugins the default toolbar contains a print button.
WindowInformation | WindowInformation [get, set] |
| Gives some basic information about the Window holding this UserControl.
EventHandler | ClickEvent |
| Signals that the content holder is clicked.
EventHandler | DeselectRequestEvent |
| Signals that the content holder requests to be deselected.
EventHandler | DoubleClickEvent |
| Signals that the content holder is double clicked clicked.
EventHandler | MaximizeRequestEvent |
| Signals that the content holder requests to be maximized.
EventHandler | RestoreRequestEvent |
| Signals that the content holder requests to be restored.
EventHandler | SelectRequestEvent |
| Signals that the content holder requests to be selected.
◆ ViewItemWpfUserControl()
VideoOS.Platform.Client.ViewItemWpfUserControl.ViewItemWpfUserControl |
inline |
◆ Close()
virtual void VideoOS.Platform.Client.ViewItemWpfUserControl.Close |
inlinevirtual |
◆ FireClickEvent()
virtual void VideoOS.Platform.Client.ViewItemWpfUserControl.FireClickEvent |
inlineprotectedvirtual |
Activates the ClickEvent.
◆ FireDeselectRequestEvent()
virtual void VideoOS.Platform.Client.ViewItemWpfUserControl.FireDeselectRequestEvent |
Activates the DeselectRequestEvent.
◆ FireDoubleClickEvent()
virtual void VideoOS.Platform.Client.ViewItemWpfUserControl.FireDoubleClickEvent |
Activates the DoubleClickEvent.
◆ FireMaximizeRequestEvent()
virtual void VideoOS.Platform.Client.ViewItemWpfUserControl.FireMaximizeRequestEvent |
Activates the MaximizeRequestEvent.
◆ FireRestoreRequestEvent()
virtual void VideoOS.Platform.Client.ViewItemWpfUserControl.FireRestoreRequestEvent |
Activates the RestoreRequestEvent.
◆ FireSelectRequestEvent()
virtual void VideoOS.Platform.Client.ViewItemWpfUserControl.FireSelectRequestEvent |
Activates the SelectRequestEvent.
◆ Init()
virtual void VideoOS.Platform.Client.ViewItemWpfUserControl.Init |
inlinevirtual |
◆ Print() [1/3]
virtual void VideoOS.Platform.Client.ViewItemWpfUserControl.Print |
inlinevirtual |
◆ Print() [2/3]
string | name, |
string | information ) |
inlinevirtual |
- Parameters
name | The name of this viewItem |
information | Information being shown in a multi-line box |
◆ Print() [3/3]
string | name, |
string | information, |
string | cameraName ) |
inlinevirtual |
Base implementation does it as shown below:
Rect bounds = VisualTreeHelper.GetDescendantBounds(this);
RenderTargetBitmap renderTarget = new RenderTargetBitmap((Int32)bounds.Width, (Int32)bounds.Height, 96, 96, PixelFormats.Pbgra32);
DrawingVisual visual = new DrawingVisual();
using (DrawingContext context = visual.RenderOpen())
VisualBrush visualBrush = new VisualBrush(this);
context.DrawRectangle(visualBrush, null, new Rect(new Point(), bounds.Size));
renderTarget.Render(visual);
- Parameters
cameraName | Blank or name of a camera |
◆ CalculateHeaderFontSize
virtual double VideoOS.Platform.Client.ViewItemWpfUserControl.CalculateHeaderFontSize |
get |
◆ CalculateHeaderHeight
virtual int VideoOS.Platform.Client.ViewItemWpfUserControl.CalculateHeaderHeight |
get |
◆ Hidden
virtual bool VideoOS.Platform.Client.ViewItemWpfUserControl.Hidden |
getset |
◆ Maximizable
virtual bool VideoOS.Platform.Client.ViewItemWpfUserControl.Maximizable |
get |
◆ Maximized
virtual bool VideoOS.Platform.Client.ViewItemWpfUserControl.Maximized |
getset |
◆ Selectable
virtual bool VideoOS.Platform.Client.ViewItemWpfUserControl.Selectable |
get |
◆ Selected
virtual bool VideoOS.Platform.Client.ViewItemWpfUserControl.Selected |
getset |
◆ ShowToolbar
virtual bool VideoOS.Platform.Client.ViewItemWpfUserControl.ShowToolbar |
get |
◆ WindowInformation
◆ ClickEvent
EventHandler VideoOS.Platform.Client.ViewItemWpfUserControl.ClickEvent |
◆ DeselectRequestEvent
EventHandler VideoOS.Platform.Client.ViewItemWpfUserControl.DeselectRequestEvent |
◆ DoubleClickEvent
EventHandler VideoOS.Platform.Client.ViewItemWpfUserControl.DoubleClickEvent |
◆ MaximizeRequestEvent
EventHandler VideoOS.Platform.Client.ViewItemWpfUserControl.MaximizeRequestEvent |
◆ RestoreRequestEvent
EventHandler VideoOS.Platform.Client.ViewItemWpfUserControl.RestoreRequestEvent |
◆ SelectRequestEvent
EventHandler VideoOS.Platform.Client.ViewItemWpfUserControl.SelectRequestEvent |
