VideoOS.Platform.Client.RawSource Class Reference
This class wraps RawVideoSource and RawLiveSource, handling buffering video, synchronizing with the given PlaybackController and ensuring a uniform return of frames whether live or playback. More...
Public Member Functions
void Close (bool wait=false)
 Close the initialized class. The background thread is flagged to stop, and if the wait parameter is true the method will wait for it to finish, max wait time is 5 seconds.
void Init ()
 Initializes the class and starts a background thread.
void LiveStart ()
 Start live stream.
void LiveStop ()
 Stop live stream.
void PlaybackStart ()
 Start playback mode.
delegate void RawLiveStatusEventHandler (object sender, EventArgs eventArgs)
 Event handler for passing changes in live status.
 RawSource ()
 Constructor.
delegate void RawVideoErrorHandler (string error)
 Event handler for any errors during gathering of frames.
delegate void RawVideoSampleEventHandler (DateTime timeStamp, byte[] content, string privacyMask)
 Event handler for passing frames.
Public Attributes
RawLiveStatusEventHandler LiveStatusEvent
 Event for passing changes in live status.
Properties
bool IsInitialized [get]
 Returns true when Init has been called, and false after Close(bool) has been called.
Item Item [get, set]
 The camera that is streaming or has recorded the video in question.
FQID PlaybackFQID [get, set]
 FQID for the Playback Controller.
bool Selected [get, set]
 Bool determining whether the source has been selected.
Guid StreamId [get, set]
 The id of the stream to be used for the live stream.
Events
RawVideoErrorHandler ErrorOccuredEvent
 Event for passing error messages through.
RawVideoSampleEventHandler NewRawVideoSampleEvent
 Subscribe to this event to receive each time a frame is available.
Detailed Description
Constructor & Destructor Documentation
◆ RawSource()
VideoOS.Platform.Client.RawSource.RawSource ( )
inline
Constructor.
Member Function Documentation
◆ Close()
void VideoOS.Platform.Client.RawSource.Close ( bool wait = false)
inline
Parameters
waitIf true, the method will wait up to five seconds for the internal threads to finish.
◆ Init()
void VideoOS.Platform.Client.RawSource.Init ( )
inline
This method should only be called once, until Close(bool) has been called.
◆ LiveStart()
void VideoOS.Platform.Client.RawSource.LiveStart ( )
inline
Start live stream.
◆ LiveStop()
void VideoOS.Platform.Client.RawSource.LiveStop ( )
inline
Stop live stream.
◆ PlaybackStart()
void VideoOS.Platform.Client.RawSource.PlaybackStart ( )
inline
◆ RawLiveStatusEventHandler()
delegate void VideoOS.Platform.Client.RawSource.RawLiveStatusEventHandler ( object sender,
EventArgs eventArgs )
Parameters
senderThe sender of the event. Can be null
eventArgsThe containing status.
◆ RawVideoErrorHandler()
delegate void VideoOS.Platform.Client.RawSource.RawVideoErrorHandler ( string error)
Parameters
errorThe error message
◆ RawVideoSampleEventHandler()
delegate void VideoOS.Platform.Client.RawSource.RawVideoSampleEventHandler ( DateTime timeStamp,
byte[] content,
string privacyMask )
Parameters
timeStampTimestamp of the frame
contentThe frame
privacyMaskPrivacy mask information. If no mask on current frame it will be null. It is the consumer of this event who is responsible for how to handle privacy mask.
Member Data Documentation
◆ LiveStatusEvent
RawLiveStatusEventHandler VideoOS.Platform.Client.RawSource.LiveStatusEvent
Property Documentation
◆ IsInitialized
bool VideoOS.Platform.Client.RawSource.IsInitialized
get
◆ Item
Item VideoOS.Platform.Client.RawSource.Item
getset
◆ PlaybackFQID
FQID VideoOS.Platform.Client.RawSource.PlaybackFQID
getset
◆ Selected
bool VideoOS.Platform.Client.RawSource.Selected
getset
◆ StreamId
Guid VideoOS.Platform.Client.RawSource.StreamId
getset
Default value is Guid.Empty and will provide the default live stream.
When changing the StreamId while a live stream is being shown, call LiveStart to utilize the new StreamId.
Event Documentation
◆ ErrorOccuredEvent
RawVideoErrorHandler VideoOS.Platform.Client.RawSource.ErrorOccuredEvent
◆ NewRawVideoSampleEvent
RawVideoSampleEventHandler VideoOS.Platform.Client.RawSource.NewRawVideoSampleEvent
