NOTE: BETA. Might change in future release. A Human Interface Device (HID) plugin is very similar to the BackgroundPlugin with few members added to service human interface devices (keyboards, joysticks, trackballs, etc.).
For more information, refer into the BackgroundPlugin documentation.
More...
virtual void | Close () |
| Called by the Environment when the HidInstance is being closed. Override this to perform cleanup operations.
Task< ConnectResult > | ConnectAsync (string userDefinedName, IEnumerable< HidConfigurationProperty > configurationProperties, CancellationToken cancellationToken) |
| Connects to the instance asynchronously. This method is called by the Environment when a new instance is discovered or added manually by the user. Properties used for connecting to the device were passed as arguments to the HidPlugin.GenerateHidInstance and thus are not repeated in this call. If your HidInstance needs these properties, you should provide them in the constructor of your derived type.
Task | DisconnectAsync (CancellationToken cancellationToken) |
| Disconnects from the instance asynchronously. This method is called by the Environment when the user removes the instance, or it has been undiscovered.
virtual void | Init () |
| Called by the Environment when the HidInstance is created. It is called before the ConnectAsync method. Override this to perform some initialization operations.
Guid | Id [get] |
| The ID of the instance (i.e. device).
virtual string | Name [get, protected set] |
| Display name of the instance (i.e. device). Use this to distinguish multiple HID instances from one another.
◆ HidInstance()
VideoOS.Platform.Client.Hid.HidInstance.HidInstance |
Guid | id | ) |
inlineprotected |
Constructor for the base class of a HidInstance.
- Parameters
id | The ID of the instance (i.e. device). |
◆ Close()
virtual void VideoOS.Platform.Client.Hid.HidInstance.Close |
inlinevirtual |
◆ ConnectAsync()
Task< ConnectResult > VideoOS.Platform.Client.Hid.HidInstance.ConnectAsync |
string | userDefinedName, |
IEnumerable< HidConfigurationProperty > | configurationProperties, |
CancellationToken | cancellationToken ) |
abstract |
- Parameters
userDefinedName | Name of the HidInstance, optionally modified by the user. |
configurationProperties | The configuration properties used to connect to the instance. |
cancellationToken | Cancellation token which the Environment can use to cancel the operation. |
- Returns
- True if the connection was successful, false otherwise.
◆ DisconnectAsync()
Task VideoOS.Platform.Client.Hid.HidInstance.DisconnectAsync |
CancellationToken | cancellationToken | ) |
abstract |
- Parameters
◆ Init()
virtual void VideoOS.Platform.Client.Hid.HidInstance.Init |
inlinevirtual |
◆ Id
Guid VideoOS.Platform.Client.Hid.HidInstance.Id |
get |
◆ Name
virtual string VideoOS.Platform.Client.Hid.HidInstance.Name |
getprotected set |
