This class only exist in the EventServer MIP Environment. More...
Public Member Functions | |
virtual void | CreateAlarm (EventData eventData) |
Directly store an Event into the alarm database. Rule handling for when to store in the alarm database must be carried out before calling this method. | |
virtual void | ItemContextMenuChanged (Item item) |
When the map alarm context menu has been changed this method can be called to get the MAP item updated. | |
virtual void | ItemStatusChanged (Item item) |
When operational state has changed this method can be called to get the MAP updated. | |
Properties | |
static EventServerControl | Instance [get, set] |
This class is a singleton and be accessed through the Instance property. The 'setter' is for internal use only. | |
inlinevirtual |
eventData |
inlinevirtual |
item |
inlinevirtual |
item |
staticgetset |
