The alarm command token is a WCF client class used against XProtect Corporate to handle alarms. VideoOS.Platform.Proxy.AlarmClient.IAlarmClient for a description of the available methods. Use VideoOS.Platform.Proxy.AlarmClient.AlarmClientManager whenever possible instead. More...
Public Member Functions | |
void | Acknowledge (System.Guid id) |
Acknowledges a specific alarm. Acknowledge alarms wil get the state set to In Progress (state = 4) and the owner will be set to the user calling. | |
void | AcknowledgeMultipleAlarms (System.Guid objectId) |
Acknowledges multiple alarms. The method will acknowledge all alarms which is created by a specific object. The object is defined by the Alarm.EventHeader.Source.FQID.ObjectId. The acknowledge alarms wil get the state set to In Progress (state = 4) and the owner will be set to the user calling. | |
void | Add (VideoOS.Platform.Data.Alarm alarm) |
Add an alarm to the Event Server. No filtering and manipulation is done on the way to the database and the alarm structure is preserved in the database. This means that adding the alarm and getting it afterwards using the Alarm.Eventheader.ID will result in an alarm containing the same data fields. | |
void | AddEvent (VideoOS.Platform.Data.BaseEvent baseEvent) |
Add an event to the Event Server. The event is checked and filtered in the Event Server against the user defined alarm definitions. Alarms are created based on the baseEvent data on every matching alarm definition. The match criteria is the BaseEvent.EventHeader.Message which match the alarm definition event message and the BaseEvent.EventHeader.Source.FQID.ObjectId which matches the source. The alarms created gets the alarm definition details added as data and the alarm is given a unique id. | |
AlarmCommandClient () | |
AlarmCommandClient (string endpointConfigurationName) | |
AlarmCommandClient (string endpointConfigurationName, string remoteAddress) | |
AlarmCommandClient (string endpointConfigurationName, System.ServiceModel.EndpointAddress remoteAddress) | |
AlarmCommandClient (System.ServiceModel.Channels.Binding binding, System.ServiceModel.EndpointAddress remoteAddress) | |
void | AttachSnapshot (System.Guid id, VideoOS.Platform.Data.Snapshot snapshot) |
Attach a snapshot to a specific alarm. | |
VideoOS.Platform.Data.Alarm | Get (System.Guid id) |
Gets a specific alarm based on the input id. | |
VideoOS.Platform.Proxy.Alarm.AlarmHistory[] | GetAlarmHistory (System.Guid id) |
Gets the alarm history. This methods returns a collection alarm history objects which contains information on the changes made to the alarm. The alarm history reflects the alarm updates made VideoOS.Platform.Proxy.Alarm.AlarmHistory for details. | |
VideoOS.Platform.Proxy.Alarm.AlarmLine[] | GetAlarmLines (int from, int maxCount, VideoOS.Platform.Proxy.Alarm.AlarmFilter filter) |
Gets alarm lines based on alarm filter. The lines received is a subset of the full set of alarm lines that satisfies the filter conditions. The subset is received based on the "from" and "maxCount" input parameters. An example: Get the newest 100 alarm lines where the alarm state is In Progress (state = 4). The alarm lines should be returned in descending time order. Help on constructing the alarm filter matching this, see the Alarm filter documentation. The "from" parameter should be set to 0 meaning the start of the resulting matching set and the "maxCount" parameter is set to 100. | |
string[] | GetAlarmMessages () |
Gets all the different alarm messages received up to this point in time. The alarm message is the Alarm.EventHeader.Message field in the alarm. | |
VideoOS.Platform.Proxy.Alarm.AlarmUpdate[] | GetAlarmUpdateHistory (System.Guid id) |
VideoOS.Platform.Data.BaseEvent | GetEvent (System.Guid id) |
Gets a specific event based on the input id. | |
VideoOS.Platform.Proxy.Alarm.EventLine[] | GetEventLines (int from, int maxCount, VideoOS.Platform.Proxy.Alarm.EventFilter filter) |
Gets event lines based on event filter. The lines received is a subset of the full set of event lines that satisfies the filter conditions. The subset is received based on the "from" and "maxCount" input parameters. An example: Get the newest 100 event lines where the event name contains "My event". The event lines should be returned in descending time order. Help on constructing the event filter matching this, see the event filter documentation. The "from" parameter should be set to 0 meaning the start of the resulting matching set and the "maxCount" parameter is set to 100. | |
VideoOS.Platform.Data.EventHeader | GetHeader (System.Guid id) |
Gets the event header from a specific alarm. | |
AlarmUpdateData | GetSessionAlarmLines (int maxCount, Guid sessionId) |
EventUpdateData | GetSessionEventLines (int maxCount, Guid sessionId) |
VideoOS.Platform.Data.SnapshotList | GetSnapshots (System.Guid id) |
Get the snapshot list from a specific alarm. | |
VideoOS.Platform.Proxy.Alarm.Statistic[] | GetStatistics () |
Gets the alarm statistics. The statistics contains overall informations on alarm count based on different alarm properties like state and priority VideoOS.Platform.Proxy.Alarm.Statistic for more information about the content. | |
Guid | StartAlarmLineSession (VideoOS.Platform.Proxy.Alarm.AlarmFilter filter) |
Guid | StartEventLineSession (VideoOS.Platform.Proxy.Alarm.EventFilter filter) |
void | StopAlarmLineSession (Guid sessionId) |
void | StopEventLineSession (Guid sessionId) |
void | UpdateAlarm (System.Guid id, string text, int state, int priority, System.DateTime time, string assignedTo) |
Updates a specific alarm with the input parameters. Only valid input parameters is updated. | |
void | UpdateAlarmValues (System.Guid id, KeyValuePair< string, string >[] updates) |
Updates a set of fields on a given alarm. The alarm to update is identified by the id. | |
void | UpdateMultipleAlarms (System.Guid objectId, int oldState, int newState, System.DateTime time, string assignedTo) |
Updates multiple alarms. The method updates all alarms which is created by a specific object. The object is defined by the Alarm.EventHeader.Source.FQID.ObjectId. Both state and the assigned to will be updated. | |
inline |
inline |
inline |
inline |
inline |
inline |
id | Id of the alarm to be updated |
AlarmServiceFault | Thrown if the alarm is rejected by the Event Server |
Exception | Thrown on communications errors. |
Implements IAlarmCommand.
inline |
objectId | Object id of the alarms to update. The id is matched to Alarm.EventHeader.Source.FQID.ObjectId in the alarm. |
inline |
alarm | Alarm |
inline |
baseEvent | Event |
inline |
id | Alarm id |
snapshot | Snapshot to attach |
inline |
id | Alarm id |
inline |
id | Id of the alarm to get the history about |
inline |
from | Start of alarm lines. |
maxCount | Max count of received alarm lines |
filter | The alarm filter |
inline |
VideoOS.Platform.Proxy.Alarm.AlarmServiceFault | Thrown if the alarm is rejected by the Event Server |
inline |
inline |
id | Event id |
AlarmServiceFault | Thrown if the id is rejected by the Event Server |
inline |
from | Start of event lines. |
maxCount | Max count of received event lines |
filter | The event filter |
AlarmServiceFault | Thrown if the event id is rejected by the Event Server |
inline |
id | Alarm id |
inline |
inline |
inline |
id | Alarm id |
inline |
inline |
inline |
inline |
inline |
inline |
text | The text will not be added to the alarm but to the alarm history which contains the history of alarm updates VideoOS.Platform.Proxy.Alarm.AlarmHistory. If null no text is written |
state | The new alarm state. Only states greater than 0 is valid |
priority | The new alarm priority. Only priorities greater than 0 is valid |
time | The time of the update |
assignedTo | The new assigned to owner. If null no owner is assigned |
inline |
The updates parameter defines what fields to update, and what value to assign to them.
The following fields can be updated:
VideoOS.Platform.Proxy.Alarm.AlarmServiceFault | Thrown if invalid field key or value |
id | Id of alarm to update |
updates | KeyValuePair of fields to update |
inline |
oldState | Old state. Only alarms with the this state will be updated. |
newState | New state. |
assignedTo | New assigned to user |
